POV-Ray : Newsgroups : povray.unofficial.patches : MegaPOV 1.2.1 and reflection blur Server Time
13 Apr 2026 18:25:10 EDT (-0400)
  MegaPOV 1.2.1 and reflection blur (Message 1 to 10 of 12)
Subject: MegaPOV 1.2.1 and reflection blur
Date: 4 Jan 2006 09:15:00
Message: <web.43bbd7d5c553dc914d24a2b10@news.povray.org>
I have discovered MegaPOV 1.2.1 since 1 month (I like the HDRI feauteres
very much!) and I'm working with HDRI global illumination that works very
well. My only concerning is about the decision of removing the
"reflection_blur" feature from this release (see rev. 0.7) which, for me,
could add more realism to reflective surfaces. Six years ago I was writing
a personal raytracer and this was one of the first features I added!!
One thing more is why do not consider the possibility to declare light
objects that generate only photons to be used in conjuction with the HDRI
global lighting (Radiosity). The problem is that otherwise you have double
illumination only to generate caustics and reflection.
Bye.
Subject: Re: MegaPOV 1.2.1 and reflection blur
Date: 4 Jan 2006 09:45:58
Message: <43bbdfa6@news.povray.org>
  Blurred reflections (and refractions) can already be used in the
official POV-Ray (since quite long time, actually), and in fact they
can be used in a more versatile and diverse ways. That might be one
reason why they didn't bother keeping the reflection_blur hack in
megapov.
  Granted, the trick to do it is a bit more complex, but at least
it is possible. See:
http://tag.povray.org/povQandT/languageQandT.html#blurredreflection
Date: 4 Jan 2006 10:30:00
Message: <web.43bbe9a0e28d25494d24a2b10@news.povray.org>
> megapov.
Thank you very much, I will try to use this trick!
GP
Date: 4 Jan 2006 10:50:05
Message: <dpgqlp$p9r$1@chho.imagico.de>
> megapov.
That's right (although it wasn't the question whether to keep the patch
but whether to reintegrate it).  A reflection blur patch with adaptive
sampling would be very welcome though.
Concerning photons-only light sources - you can accomplish this by
shooting the photons in a first pass (with only 1 pixel size output) and
using load_file in the actual render without the light sources.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 5 Jan 2006 02:25:01
Message: <web.43bcc903e28d2549dd9bbf200@news.povray.org>
> Christoph
Yes, yesterday I've used the trick of the avaraged textures but I don't like
very much the results. In any case I will try to improve it in some way...
Anyway if the reflection blur features could be reintegrated... Perhaps I
should have to study the phisics of this phenomenon and propose something!
In fact I have started my ray-tracing study since DKB-Trace when I was a
student and then for a lot of years I didn't have any more time for it. Now
it is the moment to start again perhaps also collaborating!
Thanks for the photons trick!
GP
Date: 5 Jan 2006 04:32:33
Message: <43bce7b0@news.povray.org>
  You should not dismiss the trick just because you didn't get it to
work immediately.
  You are writing as if you aren't getting the same result as with
megapov. However, the trick in question can be tuned to simulate
basically exactly what megapov was doing. Thus if you are not getting
the same result it's because you didn't set it up correctly, not because
it's not possible.
  Just read the text behind the url carefully. It explains everything.
It feels that you just quickly tried the example code given without
reading the explanatory texts carefully enough. The example code is
just *one* way of doing it (and it does it differently from what the
megapov patch does it).
  The trick can not only be tuned to do almost exactly what the megapov
patch was doing, but it can be made to do a whole lot of other things
too. Why would you want the limited megapov patch to be reintegrated?
Date: 5 Jan 2006 08:05:01
Message: <web.43bd191ce28d25494d24a2b10@news.povray.org>
I apologize, I don't "want" the limited megapov patch to be reintegrated. I
was only searching a way to generate blurred reflection to add realism to
my renderings (Perhaps this wasn't the right discussion group to ask).
In any case I would be very happy if an efficient way to have blurred
reflections with physically correct behaviour will be included in future.
I will continue to experiment with avareged textures; it is not my intention
to discard this solution!
GP.
Date: 5 Jan 2006 08:35:19
Message: <43bd2097@news.povray.org>
  I'm afraid that's next to impossible.
  The only way in a generic raytracer like povray to get accurate blurred
reflections is to shoot many rays. There just aren't any better alternatives.
  One alternative is to use an environment map. However, this technique
has several problems:
  - It's not physically accurate (especially with objects close to the
reflecting object).
  - It cannot be used for self-reflection.
  - It cannot be used for mutual reflection of two reflecting objects.
  - It's limited by the pixel size of the map and consumes tons of memory.
Date: 5 Jan 2006 10:55:00
Message: <web.43bd4016e28d25494d24a2b10@news.povray.org>
Yes, I fully agree with you: when I say "efficient" I have in mind something
like applying adaptive methods to shot rays like in area lights objects. I
don't know if this could be useful or not but it's an idea...
Moreover would be necessary to model the fact that normally the blur effect
is maximum when the angle between view and surface normal is minimum and
vice versa... (something like (and also related to) the min/max reflection
amount). Perhaps there is a big amount of physics to consider...
So I will try to look at real objects behaviours to trim the avarage texture
method!
GP
Date: 14 Jan 2006 16:35:00
Message: <web.43c96e2be28d2549504224b0@news.povray.org>
Hi GP70, hi Warp
I tried the blur-trick and it works. At least for small blurring with
BlurAmount < 1. But if I like to do really strong blurred surfaces (big
BlurAmount ex: > 5) then the result tend to look as fully reflectiv (like
BlurAmount = 0) which seems to come from the self-reflection effect.
I tried to locate this in source code and found that if eye-vector is behind
bonzo-normal-surface then the reflection algo uses the unperturbated normal
of the object thats then looks very unblurry....
Do I something wrong? I feel that in reality there are surfaces that are
more blurred than BlurAmount=1 do... Whats about a better self-reflection?
Thanks for any comment on this, best regards
zuegs
