POV-Ray : Newsgroups : povray.advanced-users : Fast media sampling Server Time
30 Jun 2026 17:33:50 EDT (-0400)
  Fast media sampling (Message 1 to 7 of 7)
Subject: Fast media sampling
Date: 12 Jul 2002 14:21:00
Message: <3d2f1e0c@news.povray.org>
I was just looking around www.digitalblasphemy.com and looking at all the
pictures he has with rays of light shooting through trees.
Now, I'm aware that other programs like lightwave are able to create this
effect much faster than POV-Ray does. But how do they do it? I'd be
interested in reading a bit about the algorithm used. Obviously it's not
just sampling a ray at intervals, because that would be as slow as POV-Ray
is about it. Does anyone know how it's done with other programs?
They must be storing information about the media or something. But still...
And is there a reason why POV-Ray doesn't implement one of these other
techniques?
 - Slime
[ http://www.slimeland.com/ ]
Subject: Re: Fast media sampling
Date: 12 Jul 2002 14:57:13
Message: <3d2f2689@news.povray.org>
I suppose their media can only have constant density and it only works with
meshes, am I right?
Otherwise I wouldn't see a way of doing it that much faster than POV-Ray's
media.
I saw this at a friend of mine who has Cinema 4D and asked him if he could
assign a pattern to the density of the media and he said no. He could only
turbulate it.
Simon
Date: 12 Jul 2002 15:29:40
Message: <chrishuff-1B19F3.14265712072002@netplex.aussie.org>
In article <3d2f1e0c@news.povray.org>, "Slime" <slm### [at] slimelandcom>
As you said, they don't sample a ray. Most likely, they use a scanline
method, projecting layers of media onto the screen to build up an
additive media effect.
Also, those programs are able to use assembly level optimizations and
SIMD instructions, which POV can't take advantage of.
> techniques?
POV-Ray is a raytracer, not a scanline renderer. (Persistance Of Vision
*Raytracer*)
Date: 13 Jul 2002 02:03:34
Message: <r2gviuorinpbdkmm2vr4v5r6r8vfsd67a0@4ax.com>
On Fri, 12 Jul 2002 14:20:58 -0400, "Slime" <slm### [at] slimelandcom> wrote:
It's simple - they construct a separate shadow map for media for every
scanline by projecting the meshes onto the plane defined by the
scanline and the camera origin using the light source as a projection
origin (multiple overlayed shadow maps merged into one in the case of
multiple light sources).
Peter Popov ICQ : 15002700
Date: 13 Jul 2002 15:45:26
Message: <3d308356$1@news.povray.org>
Ah! That makes sense! If I'm understanding correctly.
Too bad POV-Ray can't do this.
 - Slime
Date: 13 Jul 2002 20:50:52
Message: <3d30caec$1@news.povray.org>
with
> meshes, am I right?
> media.
> turbulate it.
Mmm. Well, that's not really the worst restriction in the world. It still
allows for large areas of fog, which is what you really need the speed for,
usually.
 - Slime
Date: 13 Jul 2002 20:52:39
Message: <3d30cb57@news.povray.org>
> > techniques?
> *Raytracer*)
Yes... I figured it would probably have to do with the scanline method these
programs use, though I was still unsure how they did it using that method.
 - Slime
