POV-Ray : Newsgroups : povray.binaries.images : Corrosion test Server Time
30 Jul 2026 21:03:50 EDT (-0400)
  Corrosion test (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Corrosion test
Date: 5 Sep 2008 06:34:05
Message: <48c10b1d@news.povray.org>
48c1017b@news.povray.org...
> And another one, this time I tried a high-pass filter on the ambient
> occlusion image before using it in the image to localise the placement
> of the corrosion/dirt/mold. I think the effect is a bit better for it.
> What do you think?
> Cheers,
> Edouard.
I agree it's better (maybe due to textures as well as process on the
occlusion image.
I see more moss than corrosion though :-)
Marc
Date: 5 Sep 2008 07:02:53
Message: <48c111dd$1@news.povray.org>
> occlusion image.
Heh - that's why I changed the statue to cheesy marble - it looked more
like moss or something else organic to me too.
> Marc
Cheers,
Edouard.
Date: 5 Sep 2008 09:38:25
Message: <48c13651$1@news.povray.org>
This one looks good indeed!
The metal in the previous image seems too shiny to me, in combination with
the corrosion. You could try to tarnish it some more. Maybe the corrosion
should be a paler greenish tint?
Date: 6 Sep 2008 17:50:01
Message: <web.48c2fac3d73c1c3296fb5cd20@news.povray.org>
Edouard Poor <pov### [at] edouardinfo> wrote:
> What do you think?
I think you are on the right track! This last image looks good, but not like
bronze, IMO. More like turquoise. This could be due to my monitor's gamma
setting, though. How are you applying the image? Rune's illusion.inc?
Dirt-mapping is something I always go back to. Lately I've found that Blender
can produce good UV maps that you can burn ambient occlusion onto.
Keep up the good work. I look forward to seeing more interesting images from you
Sam
Date: 7 Sep 2008 05:28:16
Message: <48c39eb0@news.povray.org>
>> What do you think?
Since the first one looked so little like bronze with corrosion, I tried
  more of a stone with mold look for the second one.
I'm applying the image with Rune's illusion.inc - I only started using
that a week or so ago, and there's so much that you can do with it! I
tried to do the mapping myself, but failed badly - luckily there are
plenty of people out there who are much better with maths than me...
Hmmm, just had a thought - I wonder if you can do this trick in a single
pass using the camera_view pigment in Megapov? Divide the universe into
the same scene twice, one with AO and one with final lighting, then
camera_view + illusion.inc's maths to pull the AO data into a
pigment_pattern? Sounds both doable, and far trickier than I could
possibly pull off. :-)
I downloaded Blender the other day. I'm frankly a little lost in it - I
need to find some good tutorials or similar...
Thank-you very much!
I'm still trying to get my head around your proximity and related SSS
macros. Applying the AO image works nicely for some scenes, but your
proximity macro is a global solution, and not just a camera specific one.
> Sam
Cheers,
Edouard.
Date: 7 Sep 2008 06:35:01
Message: <web.48c3ae03d73c1c327d55e4a40@news.povray.org>
I sympathise. If you just want ambient occlusion baking then maybe it's worth
looking at xnormal (http://www.xnormal.net/2.aspx). Either way, baking the
occlusion effect into texture maps is likely to be the most efficient solution
for all-mesh scenes (if you're lucky enough to have them).
Tom
Date: 7 Sep 2008 17:20:14
Message: <48c4458e@news.povray.org>
Rune's illusion.inc is *very* useful! I wonder if he knew how it would
be used when he made it? I too tried to map an image to the viewing
area, but failed miserably. Thank goodness he figured it out for us ;)
He should get some sort of award for that file!
The camera pigment takes render options from the whole scene file. I
suppose you could place a copy of the mesh in an ambient cube with
radiosity applied, but you would have to use radiosity for the final
image. But with MegaPOV, can't you turn radiosity off for certain
objects? If so, you can probably do it without having to use radiosity
for the final output.
I recommend that you don't give up on learning Blender. While looking at
tutorials, keep your eye on the keyboard shortcuts, as they make the
program much easier to use.
But you can't use the proximity macro for mesh objects :( If POV
supported calling inside() for mesh objects, it would work. I wish
somebody would figure out a way to get inside() working with meshes!
Sam
Date: 7 Sep 2008 17:47:26
Message: <48c44bee$1@news.povray.org>
You can make solid meshes now, which *should* work with inside().
Define a mesh using the inside_vector modifier, and see if that works.
William Tracy
"Given a signal with a 2-Hz bandwagon, the Nyquil frequency must be 1-Hz
to avoid aliening of the furrier transformer."
     -- phdcomics.com
Date: 7 Sep 2008 19:02:47
Message: <48c45d97@news.povray.org>
I've tried it, and it did not work :( I used the simplest mesh I could
think of--a tetrahedron--yet still I had no success. If you get it
working, by all means, post the code! I'd love to bypass the whole
AO-burning process altogether :)
Sam
Date: 7 Sep 2008 19:28:29
Message: <48c4639d@news.povray.org>
It's so useful it should be built into POV... "map_type rune" :-)
>> single pass using the camera_view pigment in Megapov? Divide the
>> universe into the same scene twice, one with AO and one with final
>> lighting, then camera_view + illusion.inc's maths to pull the AO data
>> into a pigment_pattern? Sounds both doable, and far trickier than I
>> could possibly pull off. :-)
My AOs are done with a simple light dome. So you'd make a copy of the
object off in it's own universe (some random place a long way away).
Stick it in a giant sphere if nessessary. Then create a light_group of
the AO lightdome (so as to not have those lights interfere, or slow, the
real scene). Then use a camera_view to generate the pigment for the
pigment_map on the real object. Probably be mostly achievable in a
clever macro? But it almost sound like more work that it's worth
considering how multiple renders are easy... Would get points for "extra
degree of difficulty" though :-)
>> I need to find some good tutorials or similar...
I'll stick with it :-)
Can't you just do multiple traces to some point outside the object's
bounding box? If you had to shoot an odd number of rays, then the
location is inside, otherwise it's outside. Exactly the same as POV does
  for meshes internally?
> Sam
Cheers,
Edouard.
