POV-Ray : Newsgroups : povray.binaries.images : Music 3 (87k) Server Time
5 May 2026 02:33:26 EDT (-0400)
  Music 3 (87k) (Message 1 to 10 of 11)
Subject: Music 3 (87k)
Date: 9 Apr 1999 21:58:09
Message: <370EA34E.31C0E63C@home.com>
This is a semi final image. I plan on adding a few more objects and
tweaking the lighting/textureing but for all intense purposes this is
close to the final.
Download 'music store2.jpg' (87 KB)
Preview of image 'music store2.jpg'
Subject: Re: Music 3 (87k)
Date: 9 Apr 1999 22:14:53
Message: <370EA1DB.E48A1F35@pacbell.net>
oh, now that turned out real nice.   ;-]
You mentioned in a previous post that you resolved your lighting issues; mind
sharing what you did?
KB-
> close to the final.
Date: 9 Apr 1999 22:59:37
Message: <370EB1B9.AB0220E9@home.com>
Thanks!
Sure thing. It turned out to be a really silly problem, almost embarrassing, I
just had to turn the light's rgb value way down, all the way to 0.3. I just
didn't expect to have to turn it down so much. When I did however it fixed the
glarey affect the light in the other image had. However with the lower light
level I had to create a copy of the light and place it at the opposite end of the
counter.
> KB-
> > close to the final.
> >  [Image]
Date: 9 Apr 1999 23:03:15
Message: <370EB293.E10B5968@home.com>
I have one problem with the image that maybe someone can help me with? Well
actually it isn't with the image rather the posting of it. When I compressed
it on my HD I used a setting of around 10%, 90% quality. This looked fine when
I viewed it on my HD but at soon as I saw the posting I noticed a ton of JPEG
artifacts particularly the circles on the back wall around the light. Is this
just my version of netscape, a setting in it, or do other people see this?
> close to the final.
Date: 10 Apr 1999 01:45:51
Message: <370ED627.5BF162C2@pacbell.net>
What program are you using to convert the image to jpg ? I have noticed
with PSP that if you convert from .tga to .jpg you will not see any
artifacts in the image until you close the .jpg file and then reload
it. Why it behaves like this is a mystery (I suspect the save in buffer
feature ?) but it is something I practice to make sure that what I think
I see is what it really is.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 Apr 1999 02:10:28
Message: <370EDE75.9D3D30C5@home.com>
Ulead JPEG smart saver. I'm running it as a plugin out of Photoshop.
> I have noticed
Yes I know of this odd problem in PSP, same in photoshop, I think your right about
it being because of the image being in a memory buffer. However that is not the
problem. The image looks fine even after I reload it, even if I reload it in another
program. It only seems to happen when I post the image.
> Ken Tyler
Date: 10 Apr 1999 02:52:47
Message: <370EE5D6.48DF615D@pacbell.net>
  I have seen ambiguities with images I have posted here that looked
different localy. I wonder if it might be related to the data storage
method used on this server. I am pretty sure that every thing here
is stored with compression applied. I recall Chris Cason mentioning
that all image file posted here were in fact stored as a form of
plain text file. I no too little to guess more on this issue.
Ken Tyler
Date: 10 Apr 1999 13:37:43
Message: <370f7e57.0@news.povray.org>
Nice modelling. However, I have some suggestions about the texturing. First
and foremost, the brass instruments. The texture should have a higher
brilliance value and the pigment should be darker. Perhaps also a bit lower
saturation and hue (I love HLS)
The sound-box (?) of the violin should look a bit more shiny and less noisy
<g>. Right now, I really don't see it as lacquered veneer.
Margus
Thomas Lake wrote in message <370EA34E.31C0E63C@home.com>...
>close to the final.
Date: 10 Apr 1999 13:37:46
Message: <370f7e5a.0@news.povray.org>
I seriously doubt the images are modified on the server in any way. They are
in plain text format, i.e. they are UUencoded. This increases file size, but
decoded images are identical to their originals.
I can only guess, but here's one possibility: you have Windows, you possibly
have a high-colour (16 bit) desktop and you view the downloaded image in
Netscape or OE. AFAIK, these programs don't dither images. Most dedicated
image viewers do. Undithered 16-bit images often exhibit colour banding. So
do some 24 bit images.
Margus
Ken wrote in message <370EE5D6.48DF615D@pacbell.net>...
>Ken Tyler
Date: 10 Apr 1999 21:24:46
Message: <370FDBB5.8A5CFB8B@ndirect.co.uk>
This has come on leaps and bounds since the first version.  How
about a moth organ, recorder, malodica and some small percussion
instrumaents in the display case.
Maybe some small area lights above shaded objects such as the
keyboard, making it look asthough there might be a spot light
somewhere, but we can't quite tell where it is kind of thing.
Steve
> close to the final.
