POV-Ray : Newsgroups : moray.win : problem with duplicating objects Server Time
29 Jul 2024 06:22:51 EDT (-0400)
  problem with duplicating objects (Message 1 to 10 of 11)
Subject: problem with duplicating objects
Date: 22 Mar 1999 16:36:08
Message: <36F6B724.1EE954E5@metrolink.com>
Hi, I'm using the most current build of Moray 3.1 (downloaded today) and
I'm having a problem when I duplicate an object - the duplicate goes to
0,0,0 and resets the scale and everything else.  Is there some option I
checked that I shouldn't have?
|Colin Scott McDonald                                  Metro Link, Inc.|
|                veni, vici, volo in dominum redirre                   |
|sco### [at] metrolinkcom                                  www.metrolink.com|
Subject: Re: problem with duplicating objects
Date: 22 Mar 1999 16:41:32
Message: <36F6B869.D6AB726B@metrolink.com>
Note - this doesn't happen with all objects.  It's a scene file I
created with Moray 3.0, and only seems to happen with one Taper Sweep
object I created.  If I select the object by itself, the duplicate goes
to 0,0,0 - if I select the group the object belongs to, that duplicates
normally.   This is very confusing.
Date: 23 Mar 1999 18:47:48
Message: <36f82824.0@news.povray.org>
I have a similiar problem with adding patches, sweeps, and lofts to CSG's..
even though they're checked to leave in current position, they'll wind up
WAY out (sometimes as much as 20000+ units out).
Scott McDonald wrote in message <36F6B869.D6AB726B@metrolink.com>...
Date: 23 Mar 1999 21:16:38
Message: <36F84ADD.4989084D@mninter.net>
Lofts? What do you mean by that?
Only I can prevent narcissism!
Date: 24 Mar 1999 03:18:21
Message: <36f89f5e.2558278@194.174.214.110>
Hi Lue Ebra, you recently wrote in moray.win:
If the checkbox 'Leave in current position' is checked, then that
means that the object should remain where it was in world space when
added. It does not mean 'do not change the transformations'. If you
uncheck it, then the transformations of the opbject to be added remain
unchanged, but the object will move if the parent you're adding it to
is not at the origin.
If you are seeing different behaviour, it may be a bug and I'd like
more details.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 24 Mar 1999 03:19:06
Message: <36f89fcf.2671581@194.174.214.110>
Hi Scott McDonald, you recently wrote in moray.win:
How exactly are you duplicating it?
- Lutz
Date: 24 Mar 1999 22:21:54
Message: <36F9AC21.876C65FF@metrolink.com>
pressing 'CTRL-D' and leaving the default values - no translation, no
scaling, etc.  This is very peculiar because it only happens on
occasional objects (a trans-sweep in this case) and I can't figure out
any similarities between objects that copy correctly and ones that
don't.   I may be checking off something that I shouldn't be somewhere,
but the same values in the duplicate dialog work correctly on other
objects.
Date: 24 Mar 1999 23:48:04
Message: <36f9c004.0@news.povray.org>
In Moray, it's called a Translational or a Tapered Sweep.. some other
programs (TruSpace comes to mind) refer to them as sweeps.
Likewise, Moray's equivelent to a spline is a Rotational Sweep.
Alex Magidow wrote in message <36F84ADD.4989084D@mninter.net>...
CSG's..
and
to
I
Date: 25 Mar 1999 08:06:15
Message: <36FA349F.A914E9ED@mninter.net>
hmm, you obviously haven't used splines very often...the only freeware/shareware
program that comes to mind that REALLY does splines, spline extrudes, and
loft/skinning- all NURB related functions...a translational sweep, in most
programs, is simply called an extrusion. A tapered sweep is an extrusion to a
point...but not a loft. A loft, AFAIK, is connecting twosplines to create a NURB
cage.
> CSG's..
> and
> to
> I
Date: 26 Mar 1999 06:02:16
Message: <36fb6899.12449201@194.174.214.110>
> don't.
I just tried this:
New Scene
Create | TransSweep
Translate, Scale, Rotate as desired
Ctrl-D
Reset to Defaults
OK
The copy appears exactly at the same place the other one was.
Is the one you're trying to copy in a group? Does it happen with any
other objects?
- Lutz
