POV-Ray : Newsgroups : povray.off-topic : Game opinions Server Time
17 May 2026 08:35:24 EDT (-0400)
  Game opinions (Message 63 to 72 of 112)
Subject: Re: Game opinions
Date: 4 Feb 2008 10:14:08
Message: <op.t5z9vafic3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 14:46:52 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> Phil Cook wrote:
>> Just annoying, repetitive and boring. Hey look it's a Strider, oo and
>> another, and another, and another, and another, and another, and
>> another, and another, and oh wait we're done. Nope silly me here's
>> another Strider, and another, and another, and another, and another.
>> Gee wasn't that fun?
> More fun than that battle in EP1 that takes place in a dark room waiting
> for the lift to arrive.
I was more annoyed by the Mr Benn approach - As if by magic the Head-crab
zombies appeared. Then again the scripted events in HL2 are getting tired
especially the second time around - ran around as much as like with no
enemies until you step in the magic area/pull the lever at which point you
get a Mr Benn.
> [Honestly, no matter how many zombies I killed, there always seemed to
> be more of them... Not to mention that killing things with a crowbar
> isn't easy. But hey, if you have no ammo left, what else can you do?]
Hmm shotgun for the speedy little sods, grav-gun plus HE barrels (minding
you don't hit Alyx) for the others. Don't head for the lift until it's
down, then run for it; the speedy ones will get to you anyway and there
seems to be more slow-walkers closer to the lift.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 4 Feb 2008 10:27:11
Message: <47a72ecf$1@news.povray.org>
> (minding you don't hit Alyx) for the others. Don't head for the lift
> until it's down, then run for it; the speedy ones will get to you anyway
> and there seems to be more slow-walkers closer to the lift.
I still don't "get" how you can kill anything with a gravity gun.
[Except yourself, that is.]
Seriously. You point it at a gas cylinder and it picks up a tiny pebble
6 feet to the left of the gas cylinder. FTW? It's just so *hopelessly*
inaccurate. It takes 10 minutes to do anything useful with it - far too
slow to be of use turing a tense battle scene.
http://blog.orphi.me.uk/
Date: 4 Feb 2008 10:39:39
Message: <op.t50a1lo0c3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 15:27:11 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> anyway and there seems to be more slow-walkers closer to the lift.
Again I'm on a PS3 so the aiming's tweaked, but yeah it's still a bit too
precise and it's damned annoying that you've just picked up that splinter
of wood and not the buzzsaw blade right next to/beneath it; some sort of
priority system needs to be put in there.
It's also fun to kill the head-crabs with if you want to save ammo don't
want to use the crowbar; takes a couple of hits, bt at least it's a range
weapon.
For a device that's supposed to be used in handling hazardous materials
I've also found it amusing that a) it's difficult to manipulate an object
you're holding i.e. rotate it; and b) that for any object of around
briefcase size it obscures your forward vision.
That was the other annoying thing about the pathetically fragile bombs in
Ep2 pick one up and watch the Strider disappear. 'Aim at the Strider',
'What Strider? All I can see is this bloody bomb in front of my face'.
Phil Cook
Date: 4 Feb 2008 10:49:03
Message: <47a733ef$1@news.povray.org>
>> pebble 6 feet to the left of the gas cylinder. FTW? It's just so
>> *hopelessly* inaccurate. It takes 10 minutes to do anything useful
>> with it - far too slow to be of use turing a tense battle scene.
1. There exists a PS3?
2. You own one?
3. EP2 is available for something other than PC?
4. OMG, how do you *play* with only 3 buttons??
> too precise and it's damned annoying that you've just picked up that
> splinter of wood and not the buzzsaw blade right next to/beneath it;
> some sort of priority system needs to be put in there.
Like I said, it tends to pick up things I'm not even remotely pointing
at. Point it directly at the huge boulder and it picks up something
several feet to one side or another. Hmm.
> range weapon.
Yeah, but you can *never* find anything to throw when you actually want
to use the gravity gun. Only when you're *not* trying to use it. That's
why it's useless in any kind of battle. You can never find ammo in time,
it takes 12 attempts to pick up the ammo, now you can't see where you're
aiming... oh, NM, you're already dead.
> object you're holding i.e. rotate it; and b) that for any object of
> around briefcase size it obscures your forward vision.
It does, however, reset the fuse on grenades. Note disable it, just
reset it at the moment you pick it up. WTF?
Date: 4 Feb 2008 11:12:32
Message: <op.t50cj3r8c3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 15:49:02 -0000, Invisible <voi### [at] devnull> did
spake, saying:
Yes.
> 2. You own one?
Yes.
Even availble for the Xbox360. Not the Wii though (yet).
Assuming you're vaguely serious I've got 14 buttons plus two analogue
joysticks, that's a standard pad. Let's see if I can recall my setup Lef
t
analogue = WASD, right analogue stick = mouse. The 4-way directional
 D-pad
selects weapons. Of the shoulder triggers I've got R1 (right top) as fir
e
primary, R2 secondary, L1 jump, L2 crouch. Triangle is torch on/off,
circle is grav-gun toggle, X is use, and square is reload.
>> but yeah it's still a bit too precise and it's damned annoying that
>> you've just picked up that splinter of wood and not the buzzsaw blade
>> right next to/beneath it; some sort of priority system needs to be pu
t
>> in there.
I second that hmm, I've not had it that bad.
>> don't want to use the crowbar; takes a couple of hits, bt at least it
's
>> a range weapon.
t
s
e,
re
The fixed POV is damn annoying with the gun, make the pick-up
semi-transparent to simulate looking around the thing. I'm so surprised
this got past the beta with no complaints.
ls
Never noticed, I always assumed it wouldn't so I'd just run away from it
rather then switch and grab it or more often the loose board is happened
to passing at the time. I love the way that the Dog catch game is suppos
ed
to teach you to catch thrown grenades except the objects thrown by Dog a
re
about four times larger and don't explode.
Phil Cook
Date: 4 Feb 2008 11:20:43
Message: <47a73b5b$1@news.povray.org>
> Yes.
I'd heard there was a PS2 out, but PS3 is news...
Er, isn't the Xbox made by Micro$oft?
Oh, OK. I've only seen a PS1. [Isn't that the one with the circle,
square and triangle? Makes me feel like it should be a kids' toy...]
>> want to use the gravity gun. Only when you're *not* trying to use it.
>> That's why it's useless in any kind of battle. You can never find ammo
>> in time, it takes 12 attempts to pick up the ammo, now you can't see
>> where you're aiming... oh, NM, you're already dead.
All the weapons seem to have some kind of "drawback" to them. E.g., the
crossbow is leathal and has a cool sniper scope (WTF?), but reloads
painfully slowly and you aim extremely slowly while scoped. The SMG
fires a continuous stream of death - but it's wildly inaccurate and
delivers approximately 3% per damange per hit. And so on. And the
gravity gun is an instant kill if you ever hit anything - but it's not
possible to hit anything.
I once pluged keepy-uppy with the gravity gun and a grenade. If you pick
up the grenade, drop it, pick it up, drop it, pick it up... each time
you pick it up the fuse resets to 4 seconds. Just so long as you do it
quickly enough, you can keep it from exploding indefinitely.
> supposed to teach you to catch thrown grenades except the objects thrown
> by Dog are about four times larger and don't explode.
...you can catch thrown grenades??
I know you can pick them up off the floor, but mid-air? Hmm, I'll have
to try that some day...
Date: 4 Feb 2008 11:39:08
Message: <op.t50dr4tkc3xi7v@news.povray.org>
And lo on Mon, 04 Feb 2008 16:20:42 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>>  Yes.
In the EU since Nov 2006.
Yep both the Xbox and Xbox360 are made by the Devil's minions.
and X, it's a standard PS joypad they've all had the same layout. The
current rumbleless PS3 ones are a little lighter, but don't feel plastic-y
http://gameplanets.blogspot.com/2007/11/new-cod4-ps3-screenshots.html yup
kiddie-stuff
I enjoy combining it with the saw blades and slicing the zombies, takes a
few more hits for those carrier zombies.
>> it rather then switch and grab it or more often the loose board is
>> happened to passing at the time.
Let's see if that's the same for the PS3.
>> I love the way that the Dog catch game is supposed to teach you to
>> catch thrown grenades except the objects thrown by Dog are about four
I've done it occasionally when I've had the grav-gun out and empty and
spotted it in time, poinked it back where it came from and watched the
combine go boom.
Phil Cook
Date: 4 Feb 2008 14:01:44
Message: <47a76117@news.povray.org>
  FPS games cannot be played with a game controller. It's like trying to
play with the keyboard only (no, the analog joysticks don't make it any
easier, they actually make it harder). It's a royal pain in the ass.
http://warp.povusers.org/grrr/consolefps.html
Date: 4 Feb 2008 14:49:38
Message: <47a76c52$1@news.povray.org>
Phil Cook wrote:
> standing', 'Yeah run around him and press that concealed switch to turn
> off the invincibilty shield', 'How the hell I was I supposed to know that?'
Yeah, like in Half-Life, where some of the bosses can't be damaged
except at certain times, and there's no indication of that.
At least in Undying, it's part of the story that the bosses are
invulnerable to certain things. You could almost deduce what you needed
to do.
     On what day did God create the body thetans?
Date: 4 Feb 2008 22:43:29
Message: <47a7db61$1@news.povray.org>
Invisible wrote:
> [Now Benny has one of those 1337 game keyboard with 40+ extra keys that
> are programmable on a per-game basis to do whatever you want. Hmm...]
The one I liked was the one where the keys were (I think) RF-driven, and
just post-it stickied to the keyboard wherever you wanted them, so you
could space them exactly how you wanted.
