POV-Ray : Newsgroups : povray.newusers : SU2POV USERS Server Time
7 Apr 2026 15:27:56 EDT (-0400)
  SU2POV USERS (Message 1 to 9 of 9)
Subject: SU2POV USERS
Date: 22 Aug 2010 00:10:01
Message: <web.4c70a1fcb56cb53871f7a4730@news.povray.org>
Hello
First, an apology. My English is not very good, but try to explain. I'm at
Pov-Ray to render,and made the model with Sketchup. I wonder if there is any
user working with this plug-in. I've done some work as a hobby, but I still need
much to learn. I use version 3.6 for export files, and finally rendered with the
latest beta version.
I would appreciate if someone could tell me some website where I could  find
information about materials, especially crystals, which is difficult to me to
understand.I visited many websites related to this program, but all are of
direct users, I mean, they do not export the model, and its hard to me to
understand how  to include materiales changes I need. The type of images that
I've done are architectural design.
    thanks for your time.
Greetings.
Subject: Re: SU2POV USERS
Date: 22 Aug 2010 17:37:30
Message: <4c71989a@news.povray.org>
> understand
Do you wish to export materials from sketchup or do you wish
to know how to apply materials to the exported geometry from
sketchup? In the latter case, people can help without knowing
sketchup, just post a small sample how the exported code looks
like and what you wish to change.
Date: 27 Aug 2010 10:20:14
Message: <4c77c99e$1@news.povray.org>
On 8/21/2010 10:06 PM, arq3design wrote:
> Hello
> Greetings.
I don't know if this will specifically answer your question, but perhaps
it will point you in a useful direction.
I use SU2POV on some of my projects and you'll need to "hand edit" the
.pov file that SU2POV plugin exports (saves) to get your material
changes accomplished. SU2POV does not, at the present, allow much
adjustment of textures directly from inside the plugin and many of the
finish and texture parameters can only be done by hand editing.
Here's what I do:
1. Create the objects in SketchUp.
2. Attach some basic "place holder" textures to the objects. These
textures will be saved in the .pov file in the next step.
3. Invoke the SU2POV plugin and save the file.
4. Do a simple test render to make sure that the scene is pretty much
how I want it.
5. Open the .pov file in either a text editor or the IDE (Windows only)
and hand edit the "place holder" textures to get the results you want.
You can change practically all the parameters for textures, color,
finishes, etc. by hand.
5. Set up final rendering, etc.
As for learning about materials, etc in POVray, about the only thing I
can suggest is to read the POVray documentation, most of what you'll
need to know it there. There are a number of .inc in the POVray install
directory that you can study or use to create your textures.
I'm afraid I can't help you much with your "crystal" question other than
to advise you to continue searching the 'net.
Cheers.
Date: 27 Aug 2010 21:26:33
Message: <4c7865c9$1@news.povray.org>
> Hello
> Greetings.
When you mention "crystals", are you thinking of tranparent materials,
or geometric shapes like those the crystals can grow into?
Anyway, for the first case, and many examples of the second, you need
mostly transparent pigments, some reflection, an index of refraction and
some colour fading.
I can give you a sample of what it can look like:
material{
pigment{rgbt 0.97} // mostly transparent
finish{diffuse 0.1 ambient 0 specular 0.7 roughness 0.001
reflection{0.1, 0.99 fresnel} conserve_energy}
// add some highlights and variable reflection
// fresnel usualy make reflection look more natural
interior{ior 1.9
// turn on refraction and can cause total internal reflection
dispersion 1.01 dispersion_samples 10
// causes chromatic dispersion to occurs
fade_color<1,1,0> fade_distance 1 fade_power 1001
// colours the interior of the object. The exact tint
// depends on the length of the trajectory inside the object
// and the fade_distance.
For this to show the best result, you need some environment and possibly
a few light_source.
Date: 2 Sep 2010 14:25:01
Message: <web.4c7fe85ed6ddfbb7dd90e9900@news.povray.org>
> > understand
 Hello, Christian:
    I wish to know hoy to change material properties  to the exported geometry
from Sketchup, specifically glass material. I can't get a realistic temperate
glass ( for a dining table). I've tried with all the F_Glass types, and the
glass still not look as well as I wanted, it looks more like a dark mirror.
This is the material :
#declare Cristal_Mesa = texture {
    pigment { color rgbf <0.05,0.05,0.05,0.40>}
    finish { F_Glass5 }
I wish to  know how to work the Glass_Interior.
                  Thanks a lot for your time.
Date: 2 Sep 2010 14:40:01
Message: <web.4c7fee2dd6ddfbb7dd90e9900@news.povray.org>
> > Hello
> > Greetings.
> Here's what I do:
> how I want it.
> Cheers.
 Hello JR:
      Thanks for you time. I'm already know hoy to make materials changes in the
POV-RAY  file,basic changes, but when I'm tried to adjust glass, I just don't
get what I wanted, and unfortunately there is not much Spanish pages where to
learn. But the good one is that recently, the SU2POV plug in have a new release
that include more predetermined materials. I will see what I can get with this
new plug in.
     Have a nice day.
Date: 2 Sep 2010 14:50:01
Message: <web.4c7ff1b7d6ddfbb7dd90e9900@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> > Hello
> > Greetings.
> some colour fading.
> material{
> interior{ior 1.9
> a few light_source.
> Alain
    Hello Alain:
      First of all thanks. I mean "Glasses", specific, architectural or
furniture glasses.
As I said to Christian and JR, I want to get a good material for a tempered
glass dining table. I tested with different types of F_Glass, and do not get the
result I want. I tried to include the variation of Interior glass, but can not
get to run the file.
This is an example of how the material I have currently, is the closest thing
I've gotten what I need, but are, for my taste, too much reflection. Could you
give me some advice?.
    finish { F_Glass5 }
Thank you again.
Good Day
Date: 2 Sep 2010 17:49:00
Message: <4c801bcc$1@news.povray.org>
Below is your texture extended into a material so you
can add a interior, and the F_Glass5 expanded into the
values from glass.inc so you can play with the parameters.
To reduce the reflection you can decrease specular as
well as the min/max value in the reflection block.
#declare Cristal_Mesa = material
   texture
     pigment { color rgbt 1}
     finish
       specular 0.7
       roughness 0.001
       ambient 0
       diffuse 0
       reflection
         0.2, 1.0
         fresnel on
       conserve_energy
  interior {ior 1.5}
// sample usage
sphere {0,1 material {Cristal_Mesa}}
Date: 3 Sep 2010 20:42:35
Message: <4c8195fb@news.povray.org>
>> closest thing
>> Could you
> texture
> finish
> specular 0.7
Reduce this if the highlights are to importent.
> roughness 0.001
If you reduce this value, the highlights will get sharper.
> ambient 0
> diffuse 0
> reflection
> 0.2, 1.0
Adjust the first value to set the minimal reflective value. That valus
is used when the surface is viewed perpendicularly.
Adjust the second value to set the maximal reflective value. That value
is used when the surface is vewed at a grazing angle.
> fresnel on
You can add an optional "exponent Float" here. It will affect the
falloff of the reflection.
> conserve_energy
Important. Keep that.
> interior {ior 1.5}
If you change the interior, the reflection will change as the fresnel
reflection is ior dependent.
> // sample usage
You can try with: reflection{0.05, 0.7 fresnel}
This will gives you a notably less reflective glass.
