POV-Ray : Newsgroups : povray.newusers : Simple 2D text on a cylinder's surface Server Time
13 Mar 2026 04:02:25 EDT (-0400)
  Simple 2D text on a cylinder's surface (Message 14 to 23 of 23)
Subject: Re: Simple 2D text on a cylinder's surface
Date: 14 Oct 2007 05:10:41
Message: <4711dd11$1@news.povray.org>
M_a_r_c wrote:
> 47113368$1@news.povray.org...
>> Marty Schrader wrote:
>>> The book references you gave me don't point to anything. My POV for
>>> Windows (3.6.1) help file goes up to 3.4.9, but you mention sections
>>> 3.4.11 and 12. The online help is even worse, since Chapter 3 is the
>>> reference in the help file, but it's about windows in the online docs.
>> The first number denotes a "book" not a "chapter". Since there are three
>> platform specific "books", but the online help cannot have three "books"
>> with the same number (yet it makes the most sense to have platform docs
>> first), the order is different, the actual chapter numbers are identical
>> though.
>> Thorsten, POV-Team
> I wonder how many dried frog pills were swallowed to keep that cool ;-)
LOL, eventually we should replace the first number with a unique letter (or
drop it altogether), then the complexity will go away :-)
	Thorsten
Date: 20 Oct 2007 19:15:00
Message: <web.471a8ac7ee0c3636892adb1d0@news.povray.org>
> > This subject has been beaten to death on this group, but to no
> > satisfactory conclusion.
> Here you go, Marty:
Hey Samuel can you tell me why I loose part of the first few characters?
see code below
Leef_me
//        orthographic
        location <0,0,-10.5> look_at <0,0,0>
light_source { <-10,-7,-40> color rgb 1}
light_source { <1,0,-1.5> color rgb 1}
// Create an infinite sphere around scene and allow any pigment on it
sky_sphere {
    gradient y
    color_map { [0.0 color rgb <0.7,0.7,1.0>] [1.0 color blue 0.5] }
// using text as a pigment on a plane, original code was in response to text
on a cylinder
//From: Samuel Benge
//Subject: Re: Simple 2D text on a cylinder's surface
//Date: 12 Oct 2007 06:39:40
// begin code
#declare my_text=
text{
  ttf"arialbd.ttf"
  "Test"
  1,0
//    translate<1.5,0,0>
//      Why is part of the first character or two lost?
// flat circular FINITE (no CSG) shape, center hole cutout is optional
disc {
  <0, 0, 0>  // center position
  z,         // normal vector
  5.0,       // outer radius
  //0.2        // optional hole radius
       pigment{
   pigment_pattern{
    object{my_text 0,1}
Date: 20 Oct 2007 19:55:41
Message: <471a957d$1@news.povray.org>
> see code below
> Leef_me
Yes, you are experiencing that old problematic artifact known as
coincident surfaces. The front of the text object occupies the exact
same space as the surface of the disc. Since the text object is 1 unit
deep, change it to this:
#declare my_text=
text{
  ttf"arialbd.ttf"
  "Test"
  1,0
  translate -z/2
Doing that will allow the text object to intersect the disc correctly,
thus displaying all of the text.
Sam
Date: 20 Oct 2007 21:35:01
Message: <web.471aabbaee0c3636892adb1d0@news.povray.org>
> > see code below
> > Leef_me
> #declare my_text=
> text{
>   ttf"arialbd.ttf"
>   "Test"
>   1,0
>   translate -z/2
> Sam
That does indeed <solved> the problem. And in understand the concept of
coincident surfaces. I failed to try translating the text in that axis.
I have experienced coincident surfaces as a random pixelation between the
two surfaces.
What I don't understand and what really through me was that it wasn't the
whole string. Just the top left at the start of the string was cut off at
an angle.
Thanks for the solution, now I start to comprehend the code.
Leef_me
Date: 21 Oct 2007 16:39:07
Message: <471bb8eb@news.povray.org>
> two surfaces.
> an angle.
Yeah, you would expect the same random pixelation to occur, not the
strange angled cut. It seems to be due to how POV handles object
pigments. I'm getting the same effect with every flat object I try.
You're welcome. It's nice to see somebody passing through a difficult
problem :)
If you *really* want to make sure it never happens again, you can make
the object pigment infinitely long in the z-axis by changing your object
pigment like so:
pigment_pattern{
  object{my_text 0,1}
  translate<1.5,0,0>
  warp{planar}
As long as you made the first 'translate' in the text object's
definition, this should work just fine.
Sam
Date: 23 Oct 2007 02:05:01
Message: <web.471d8e89ee0c3636ba3bb4f60@news.povray.org>
> pigment like so:
> pigment_pattern{
>   object{my_text 0,1}
>   translate<1.5,0,0>
>   warp{planar}
> Sam
Ok, that works as advertised. But I stumbled upon a new wrinkle.
I want to apply the 2D text to a flat object: disc, plane, sheet of paper,
or im my case a mesh.
(I'm looking the the scroll object at
                http://lib.povray.org/searchcollection/index.php     }
I've even succeeded in getting the text to run cross-wise or along the
length of the scroll. No code to share yey, it is very rough. Problem is
that the text 'bleeds through' and is visible from both sides of the
object.
Is there some way to apply a pigment to the 2D text and a different pigment
to the surrounding area including the opposite side, or maybe even a 3rd
pigment to the opposite side alone?
Leef_me
Date: 23 Oct 2007 17:42:19
Message: <471e6abb@news.povray.org>
Good work!
> object.
> Leef_me
Not having used the scroll object, I cannot say for certain if this will
work with it. You may want to try interior_texture. Since objects in POV
have two sides (inside, outside), there is a provision for texturing
both sides separately.
Try something like this:
object{ my_object
  texture{
   pigment{ my_text_pigment }
  interior_texture{
   pigment{ no_text_pigment }
Sam
Date: 23 Oct 2007 18:31:46
Message: <471e7652$1@news.povray.org>
> have two sides (inside, outside), there is a provision for texturing both
> sides separately.
> object{ my_object
>  texture{
>  interior_texture{
This should work fine, the scroll is a surface without a
clearly defined inside... the back is the interior_texture.
Date: 23 Oct 2007 19:15:01
Message: <web.471e7f8cee0c3636892adb1d0@news.povray.org>
> > sides separately.
> > object{ my_object
> >  texture{
> >  interior_texture{
Thanks Sam and Tim, and also to Gregjohn for his original question
I found out about interior_texture a little while ago by reading and
experiments
I found that I had to use keyword uv_mapping or the text was pixelated as
before
For anyone else, here is an example of a disc with text and background on
one side and background only on the other side
#declare my_text= text{   ttf"arialbd.ttf"      "This is a test"    1,0
  translate -z/2
// suggested by fellow pover Samuel Benge  Date: 21 Oct 2007 20:39:07
// Re: Simple 2D text on a cylinder's surface
  scale .2
  //rotate <0,0,90>
  translate<-.7,0,0>
   // when the Z rotation is 90, then these parameters are y,x,z
   // when the Z rotation is 0, then these parameters are x,y,z
disc {
  y,         // normal vector
  1.0,       // outer radius
    uv_mapping
      texture {                     // one side has background and text
      pigment{
        pigment_pattern{
          object{my_text 0,1}
        pigment_map{
            [0 color Black]
            [1 color White]
    interior_texture {             // the other side has another background
            color Blue
    rotate x*-45
    rotate x*90*clock             // look at both sides of the disc
Leef_me
Date: 15 Nov 2007 17:31:18
Message: <473cc8b6$1@news.povray.org>
This appears to be the solution I will have to employ. My original intent was to
make use of POV-Ray as a very low (like, zero) cost solution for a complex and
tedious problem. However, POV itself has turned out to be a complex and tedious
system that has more flaws and shortcomings than the manual solution provided by
other tools.
So, it's back to Google to shop for 3D design tools that won't bust the budget.
Thanks for all the help, folks. See you around.
Marty Schrader
Embedded Technology Consulting from
Parsec Systems, Inc.
0N107 Cottonwood Drive
Wheaton, IL  60187
(630) 588-0241
www.parsecsystemsinc.com
mar### [at] parsecsystemsinccom
