POV-Ray : Newsgroups : povray.general : Specularity mapping Server Time
16 Nov 2024 13:20:43 EST (-0500)
  Specularity mapping (Message 1 to 10 of 13)
Subject: Specularity mapping
Date: 18 Aug 1998 10:04:11
Message: <35D97BA2.7B64@nettally.com>
Anybody got any good ideas about how to do specularity mapping within
POVRAY?  Since specularity is a "finish" function, it seems to be tired
to a particular texture.  I've got a couple of way-out ideas that MAY
work, but if there's a better way that I've overlooked, then I'd hate to
re-invent the wheel (using flint axes and duct-tape).
Tim Glover
tgl### [at] nettallycom
Subject: Re: Specularity mapping
Date: 18 Aug 1998 10:41:21
Message: <35d98481.0@news.povray.org>
On Tue, 18 Aug 1998 09:03:30 -0400, Tim Glover <tgl### [at] nettallycom> wrote:
Try a down-to-earth texture map.
Date: 18 Aug 1998 12:28:26
Message: <35D99D71.7BAE@nettally.com>
Good idea, but...
I've considered this, but texture mapping is (like all textures in
POVRAY) a procedural thing.  It's got to conform to (some)
pre-determined mathematical formula.
What I'm looking for is more like a bump map, but instead of perturbing
the surface normals, the function perturbs the specularity.
Thanks anyways....
Tim G.
Date: 18 Aug 1998 12:56:41
Message: <wb90kmuvws.fsf@tycho.intervett.no>
[Tim Glover <tgl### [at] nettallycom>]
// RTFM once in a while, would you?
#declare lowspec =
texture{
  pigment{color rgb <1,1,1>}
  finish{specularity 0}
#declare hispec =
texture{
  finish{specularity 1}
sphere{ <0,0,0>,1
     spotted
     texture_map{
       [0.2 texture lowspec]
       [0.8 texture hispec]
Now all you're missing is a light source and a camera. :)
A penny for your thoughts.
Mine are more expensive.
Date: 18 Aug 1998 13:44:21
Message: <35D9AF3C.2107@nettally.com>
Nice code.  But still doesn't solve my problem.  Thanks for the try,
though.
I did read the FINE manual.  POVRAY doesn't support specularity based on
an image map as it does support normal perturbation based on a (bump)
image map.
Perhaps an example might help.
Imagine a sheet of shiny stainless steel with hundreds of small dirty
bronze rivets.
Imagine a bump map of the rivet heads applied to cause small bumps
Now imagine a specularity map applied so that the rivet heads do not
gleam like the shiny stainless steel.
Now instead, imagine trying to do this by modeling each rivet and
attaching a different
texture (with varying specularity) to rivets and background stainless
steel.
By the way - POVRAY is a little misleading in it's use of the term
specularity, having both specular highloghts (controlled by ROUGHNESS
and SPECULAR keyords) and specular reflection (controlled by the
REFLECTION keyword).  It looks like what I want is specular highlights.
Thanks again.
Tim G.
<snip>
nice code deleted here
<end snip>
Date: 18 Aug 1998 16:52:28
Message: <35d9db7c.0@news.povray.org>
On Tue, 18 Aug 1998 12:43:40 -0400, Tim Glover <tgl### [at] nettallycom> wrote:
>image map.
You are correct.  For some reason, I had assumed that image_map could be
used wherever any other pattern type could.  I wonder why not.  It looks like
your best bet is a material map, though I'm not sure if it will work in your
specific application.
Date: 18 Aug 1998 19:53:48
Message: <35DA05FC.CC1A8752@flash.net>
I also am surprised that a raster image (ie image map analog) can't be
used anywhere a pattern can.  Given the highly modular form of the POV code
it would seem the natural implementation.
Instead of bump_map and image_map (and specular_map...), one could
then just have map... like any other function.
Dan
http://www.flash.net/~djconnel/
Date: 19 Aug 1998 00:36:27
Message: <35da483b.0@news.povray.org>
Try the following... haven't tested it as I'm typing while I am downloading
new msgs, but give it a shot:
#declare woodWithRivets =
plane
{ y, 0
  texture
  { pigment
    { DMFWood1 } // on top of my head
    normal
    { bump_map
      { sys "rivets.bmp" // not sure, wasn't there one
                         // in the Windoze directory?
        interpolate 2
        bump_size 0.5
      rotate 90*x
  texture
  { material_map
    { gif "circles.gif" // same as rivets but only two colors:
                        // black for plane white for rivet
      texture { finish { Dull  } pigment { Clear } }
      texture { finish { Shiny } pigment { Glear } }
You get the idea. Not sure... should work. Please try and report the
results, I'm curious (I wanna see my skill in poving a prima vista).
--Peter
pet### [at] usanet
Tim Glover wrote in message <35D### [at] nettallycom>...
>Tim Glover
Date: 19 Aug 1998 03:38:03
Message: <wbbtphpjej.fsf@tycho.intervett.no>
| though.
My mistake. Material map seems to be your best bet here. I once made a
material_map that had 255 seperate textures (a while loop), one for
each colour. Might be worth a shot.
Date: 19 Aug 1998 14:53:40
Message: <35DB10FB.2DA0@nettally.com>
Wow - not bad for off the top of your head.  This is pretty close to
what I wanted.  It took a few tweaks -- like Glear -> Clear <grin> --
and still having trouble using bumpmap and texture map together, but
DEFINITELY a good lead for further experimentation.  First tries have
been exciting.  Guess it'll be a LATE night tonight.
bye bye duct tape.
Thanks for the excellent lead!
Tim Glover
<snip>
