POV-Ray : Newsgroups : povray.binaries.images : Blurred reflection comparison Server Time
15 Jul 2026 14:12:04 EDT (-0400)
  Blurred reflection comparison (Message 19 to 28 of 28)
Subject: Re: Blurred reflection comparison
Date: 17 Feb 2018 18:24:41
Message: <5a88b9b9$1@news.povray.org>
On 2/17/2018 4:01 PM, dick balaska wrote:
> On 02/17/2018 03:28 PM, Mike Horvath wrote:
>> I posted five images to Flickr showing my experiments with blurred
>> reflections.
https://www.eurobricks.com/forum/index.php?/forums/topic/159291-pov-ray-surface-realism/
>> I asked on Eurobricks which is the most realistic image? I will also
>> ask here. Which do you think look the most like real LEGO bricks?
>> Mike
> I like #1 and #2. In all cases, the black road is way too reflective for
> lego (although I like black reflective on principle).  Unless Lego has
> changed a lot since I was a kid.
All my bricks are so old and scarred I can't really come to a conclusion
on my own. For instance, holding a brick so it reflects light from my
lamp, I can make out the bulb pretty clearly as well as the lamp shade.
But other nearby objects are barely visible. I don't know if brand new
bricks would reflect more.
Mike
Date: 18 Feb 2018 06:25:01
Message: <web.5a8962621a4227fab244fcf0@news.povray.org>
> >> reflections.
> >> Mike
> Mike
I have another observation for some blur reflection material, some surface is
more blur when you look it perpendicular. Just like variance reflection(aoi
pattern reflection amplitude), the blur has its aoi pattern.
But I don't know this is suitable for lego.
Date: 18 Feb 2018 07:00:09
Message: <5a896ac9$1@news.povray.org>
Am 17.02.2018 um 21:28 schrieb Mike Horvath:
> reflections.
> I asked on Eurobricks which is the most realistic image? I will also ask
I find it difficult to judge, as I'm not used to such large LEGO models.
I'd consider a closeup helpful.
Another tip you may or may not already be aware of: For best realism,
make sure to use a modern (v3.7.1/v3.8.0) version of POV-Ray, and make
use of the finish-level `fresnel` statement, e.g.:
    #declare MyLegoMaterial = material {
      interior { ior 1.6 }
        pigment { ... }
        finish {
          ambient 0
          diffuse albedo DIFF
          specular albedo SPEC roughness ROUGH
          fresnel on
          reflection { SPEC fresnel on }
          conserve_energy on
        normal { ... }
Presuming you're using normal-based blurred reflections, DIFF and SPEC
should probably be exactly 1.0 each(!), and ROUGH should be very low
(e.g. 0.0001).
Setting the finish-level `fresnel` parameter to `on` causes both the
diffuse component and specular highlights to vary with the viewing angle
in a realistic manner, making specular highlights more pronounced at
shallow angles (just like reflection-level `fresnel on` does for
specular reflection), while reducing the diffuse component's brightness
accordingly (just like `conserve_energy` does for transmitted light).
Date: 18 Feb 2018 18:16:30
Message: <5a8a094e@news.povray.org>
>> reflections.
>        texture {
>          pigment { ... }
>          finish {
>            ambient 0
>            diffuse albedo DIFF
>            fresnel on
>            conserve_energy on
>          normal { ... }
> (e.g. 0.0001).
Thanks for the tip. However, I changed the finish to this:
#local ldrawPlasticFin=finish {
  ambient			0
  diffuse albedo		1
  specular albedo	1
  roughness			0.0001
  fresnel			on
  reflection {1 fresnel on}
  conserve_energy
Now I see no reflections at all on the bricks.
Mike
Date: 18 Feb 2018 20:03:29
Message: <5a8a2261$1@news.povray.org>
Am 19.02.2018 um 00:16 schrieb Mike Horvath:
>  ambient            0
>  diffuse albedo        1
>  specular albedo    1
>  roughness            0.0001
>  fresnel            on
>  conserve_energy
Make sure that your materials have an `interior { ior FLOAT }` setting.
For LEGO materials, I recommend a value of 1.6.
When `fresnel` is set to `on`, the intensity of reflections not only
depends on the viewing angle, but also on the ratio between the
refractive index of the material and the refractive index of the medium
around (typically the "atmosphere", which has an ior of 1.0). The more
this ratio deviates from 1.0, the stronger the reflections will be.
By default, POV-Ray materials have an IOR of 1.0.
Date: 18 Feb 2018 21:07:12
Message: <5a8a3150$1@news.povray.org>
Thanks, that worked. Would you be willing to take a look at each of the
different LDraw materials? Currently, there are about 7 different ones,
I think.
Mike
Date: 18 Feb 2018 21:54:38
Message: <5a8a3c6e$1@news.povray.org>
Am 19.02.2018 um 03:07 schrieb Mike Horvath:
> I think.
Dunno. Let me know what those materials are, and I'll try to give
recommendations.
I don't currently have the time to set up some LDraw->POV-Ray workflow
myself.
As mentioned before, LEGO's standard opaque plastic has a refractive
index of about 1.6, which also happens to be a good approximation for
LEGO's standard transparent plastic (both clear and tinted).
Date: 19 Feb 2018 04:10:27
Message: <5a8a9483@news.povray.org>
>> I think.
> recommendations.
> myself.
I attached the latest render as well as a copy of the material
definitions I used to make the render. Currently, only the
`ldrawPlasticABSFin` and `ldrawPlasticPolyFin` finishes are configured
to your specifications. Good luck.
Mike
Download 'wrapper_townview_close_06.jpg' (408 KB) Download 'materials_mjh_shadowno.inc.txt' (22 KB) Download 'blurred_reflection.inc.txt' (1 KB)
Preview of image 'wrapper_townview_close_06.jpg'
Date: 19 Feb 2018 04:23:17
Message: <5a8a9785@news.povray.org>
I forgot to make some important changes to the material definitions.
I've attached the updated file.
Mike
Date: 24 Feb 2018 10:47:39
Message: <5a91891b$1@news.povray.org>
> Mike
Christoph, do you have any tips on these materials? Thanks.
Mike
