POV-Ray : Newsgroups : povray.unofficial.patches : OpenGL support idea Server Time
5 Jul 2026 17:27:45 EDT (-0400)
  OpenGL support idea (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: OpenGL support idea
Date: 15 Jan 2001 22:01:38
Message: <chrishuff-ED9D55.22025915012001@news.povray.org>
In article <3a63a872@news.povray.org>, "David C" <dav### [at] satnet>
wrote:
>  I have thought about some of these things too. I might have a framerate
> problem if I tried to render the animation in real time. There is no fps
> option in povray as well, so I wouldn't know the user's desired
> framerate. I think definitely that each frame should be rendered and
> written to a file. I'm not sure about real time previewing.
Real time previewing definitely wouldn't be possible...the parse time
would reduce it to a couple seconds a frame for simple scenes, and I've
had scenes that went for nearly an hour just parsing. To get an animated
preview, you would pretty much have to save the frames as they are
calculated, and then display them. It would be simpler and more
consistent to treat OpenGL rendering just like ordinary rendering.
> There is also the matter of how to get the frame from opengl to a
> file. I know some libraries support offscreen rendering, but that
> again would be platform dependent.
I'm pretty sure there are standard functions for getting the image data
(glReadPixels()?), and the code for setting up the OpenGL context and
stuff should be separated out into a platform-dependant section anyway.
> Ah well. Maybe I should play with opengl and get comfortable with it
> for a few weeks first.
If you need help, I am also learning OpenGL and may be able to help you
find some resources...
Christopher James Huff
Date: 16 Jan 2001 01:34:29
Message: <ckq76t877dnmmv8huc0fie4pfuf30cpkhh@4ax.com>
On Mon, 15 Jan 2001 21:00:55 +0600 David C wrote:
>Well I wasn't thinking of fully supporting all of povray's stuff like
>some of the different light types that don't have a native equivelent in
>opengl. And then, there's transparency, reflections, refractions,
>povray's function-textures, media, imagemaps, and maybe a few more
>I havn't thought of.
  David, I think it comes down to whether or not you want to spend the
time to write the OpenGL code with its inherent limitations or be
satisfied with using the already built-in quality settings in POV-Ray,
as per docs section 3.2.6.1 "Quality Settings".
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 16 Jan 2001 03:39:00
Message: <3A640955.A9981B76@aetec.ee>
David C wrote:
> I am wondering about adding an OpenGL preview for animations. I have three
> questions.
> - Would it be legal to distribute since OpenGL would be doing the
> rendering and povray would only be doing the parsing?
> - Is it being done already?
> - Is it somthing that the povray comunity would be interested in using?
> (besides me)
> I am thinking of just using it for very fast test renders, using quick
> colors instead of real textures and simple lights so you can see how the
> objects look and how the camera moves. You could then tweak it very
> finely for animations since the edit/render/view cycle would be shorter.
I haven't followed Moray development recently, but at some time it had
animation plugin, which allowed to see animations relatively easy from
Moray (but rendering was done with Polyray dll, IIRC). Moray is for
Windows only of course, so not much for multiplatform support, but if
one can stand modeller and uses Windows, then it might be solution.
Then, couple of years ago Johannes Hubert wrote basic POV-Ray animation
program in OpenGL for the IMP. He used POB  patch for handling POV-Ray
objects and displaying them. IIRC this program worked with primitives
only and was written in very short time so it didn't provided very much
functionality. Johannes is not seen recently and AFAIK he didn't
released source code for this program. Additionally, POB patch was for
older version of POV-Ray and AFAIK it is not updated for recent
version(s).
So, seems like you are on your own. RT animation would be nice, but I'm
not sure, that POV-Ray is the best program for doing this...
Date: 16 Jan 2001 06:05:11
Message: <3a642ae7@news.povray.org>
> Have you thought much about how you would handle CSG?  I don't know
> anything about Warp's tesselation patch that Chris referred to, but CSG
can
> be a show-stopper.  Finding an algorithm to generate meshes for arbitrary
> CSG combinations is difficult.
Moray manages to evaluate csg quite happily (with opengl) however it can be
slow for complex operations, so for use in a animation preview system it may
take (in some cases) almost as long to evaluate the csg as it would to
render it normally.
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 16 Jan 2001 13:17:18
Message: <3a64902e$1@news.povray.org>
I'd encourage you to do this.  There is a real need for this kind of
functionality.
Also, please ignore the nay-sayers.  Every time this subject comes up, a
number of POV participants jump on the head of the suggestor and flog the
suggestor mercilessly.  Ignore them and do what you think is right.
Jim
http://www.kressworks.com/
"David C" <dav### [at] satnet> wrote in message news:3a632dad@news.povray.org...
> questions.
> (besides me)
Date: 16 Jan 2001 13:19:44
Message: <3A648F67.26055491@my-dejanews.com>
> (besides me)
I have some particle-based animations that would be neat to let run like all
day as either a screensaver for entertainment value  or to explore the "steady
state" condition after thousands of frames.   I'd like to keep it in povray
scene language syntax because then I could easily put it all back to make
"real" animations when I'm done.
Date: 16 Jan 2001 16:16:47
Message: <chrishuff-07183F.16174816012001@news.povray.org>
In article <3a63b91e@news.povray.org>, "David C" <dav### [at] satnet>
I certainly wasn't suggesting you should try to support all of
that...just shadowless point lights, ambient lighting, solid colors, and
orthographic and perspective cameras would be enough, at least at first.
> I think, if I do actually start building it, that I'd try to mimic
> the behavior of native rendering as much as possible.
Probably a good idea.
> For me, this is all just talk so far. I'd love to do it, but I'm not
> sure I will.
It would be an interesting project...and might keep Warp's mesh patch
alive long enough for someone to fix it. ;-)
Date: 17 Jan 2001 00:43:57
Message: <3A652FE4.1E416192@faricy.net>
thinking 'Huh? What's this?' scrolling up, 'oh, David C' a "senior moment" as
it were
Date: 17 Jan 2001 01:06:45
Message: <3A6536C8.70DFA792@pacbell.net>
> functionality.
It's blasphemy, Jim. I say nay ! We never had it before so why do we
need it now ? OGL is crappy compared to raytracing. Might as well add
gif output support as long as we are going backwards. I don't like the
idea. You want to do what ? Never had it, never will.
<g>
Date: 17 Jan 2001 01:23:20
Message: <3a653a58@news.povray.org>
LOL!
You've decided to become a "say nayer" rather than a "nay sayer"?
Jim
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3A6536C8.70DFA792@pacbell.net...
> > functionality.
the
> <g>
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
