POV-Ray : Newsgroups : povray.unofficial.patches : Bug in isosurface using pigment function? Server Time
15 May 2026 22:45:15 EDT (-0400)
  Bug in isosurface using pigment function? (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Bug in isosurface using pigment function?
Date: 24 Nov 2000 09:16:18
Message: <chrishuff-2CD9BB.09164624112000@news.povray.org>
In article <3a1e6b2a@news.povray.org>, "Wlodzimierz ABX Skiba"
<abx### [at] abxartpl> wrote:
> first I prepare CSG than I declare function{pigment{object{...}}} to
> describe interior of it and then I clone this as isosurface.
> Isosurface has artifacts even with accuracy 0.00005.
> I have calculated value (with eval) of max_gradient as 200000 but this
> not help.
The object pattern has two states: on and off. It doesn't have any
"in-between" values. Patterns like this have an infinite gradient, and
cause the isosurface algorithm problems. Other patterns that have this
problem are checkers, hexagon, brick, and any pigment that has sharp
lines. Warp is using the boxed pattern, which does vary smoothly, but
his color_map is [0 rgb 1][0 rgb 0][1 rgb 0], which looks like a mistake
to me...it is completely black, with no variation at all, basically a
big, slow rendering 0. I think he wants [0 rgb 1][1 rgb 0] instead.
Christopher James Huff
Date: 24 Nov 2000 09:20:24
Message: <chrishuff-E00AB6.09205224112000@news.povray.org>
In article <3a1e53fd@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
You declared your pigment as:
#declare ObjectFunc =
function {
    pigment {boxed
        color_map {[0 rgb 1][0 rgb 0][1 rgb 0]}
What are you expecting this color_map to result in? It starts out as
white, but goes to black in 0 distance and ends in black, basically a
black pigment...isosurfaces require a smoothly varying function. My
guess is you want either this:
color_map {[0 rgb 1][1 rgb 0]}
or something similar to this:
color_map {[0 rgb 1][0.5 rgb 0][1 rgb 0]}
Date: 24 Nov 2000 09:36:10
Message: <3a1e7cda@news.povray.org>
Chris Huff wrote in message ...
this
> > not help.
> lines.
I know this but unfortunatly in current (unoficial) state of pov this is
only way to play with described week ago nonlinear transformations.
Everything is ok but normals.
hmmm
perhaps the problem can be resolved just like in smooth_triangle ?
in 2D description:
1. take point at equipotential surface
    P
2. take value at corners of cube around of it (size of cube depends of
accuracy)
   V1---V2
    | P |
   V3---V4
3. find points on edges where value is like in P
4. aproximate normal
ABX at babilon at org
Date: 24 Nov 2000 10:56:58
Message: <3A1E8FCA.A806F53B@schunter.etc.tu-bs.de>
I don't think so, AFAIK, every surface could somehow be approximated with
a smooth isosurface function, although it can be quite complicated and i
agree that it would be nice to use an object pattern for this purpose.
> in 2D description:
>     P
> accuracy)
>    V1---V2
>     | P |
>    V3---V4
But there is no point in pigment { checker color rgb 0 color rgb 1 } where
the value is 0.5 so there is also no equipotential surface for this value.
Date: 24 Nov 2000 11:19:02
Message: <3a1e94f6@news.povray.org>
Christoph Hormann wrote in message
<3A1E8FCA.A806F53B@schunter.etc.tu-bs.de>...
this is
with
i
I use this feature only to explore iso-functions possibilities of my
non-linear transformation. But if I want make usefull macro it should be
possible modify any object, not only described as functions. First one
is csg, second one is iso-non-linear-transformation, there is place for
third one but I'm working on it:
http://www.abx.art.pl/pov/nonlinear/twist.jpg
where
value.
hmmm
Date: 24 Nov 2000 11:42:27
Message: <3A1E9A74.B6428D71@schunter.etc.tu-bs.de>
Every CSG made of cylinders, spheres, cones, boxes, torii should be quite
easy to convert to a smooth isosurface function, the more difficult things
are lathe, prism and meshes.
Date: 24 Nov 2000 11:49:39
Message: <3a1e9c23@news.povray.org>
<3A1E9A74.B6428D71@schunter.etc.tu-bs.de>...
quite
things
yes, I know
but as I said I'm looking for universal method (equations)
perhaps to code in source code
ABX -> just look -> http://www.mdk.art.pl/
Date: 24 Nov 2000 14:11:02
Message: <3A1EBD44.ECD07DE8@club-internet.fr>
> this
> > > not help.
> > lines.
The couple of images I posted a few weeks ago didn't use the object
pattern, but proximity.
I don't know if this is what you were talking abut though.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 24 Nov 2000 18:01:31
Message: <chrishuff-EA7F65.18015924112000@news.povray.org>
In article <3a1e7cda@news.povray.org>, "Wlodzimierz ABX Skiba"
The proximity pattern will be better for this, but in it's current state
is too slow to make a practical pigment function.
I don't see how...in a smooth triangle, you manually specify the normal
at each corner. Isosurfaces don't have such convenient control
points...and the results would probably look horrible.
Date: 24 Nov 2000 18:06:39
Message: <chrishuff-53E619.18070724112000@news.povray.org>
In article <3A1E9A74.B6428D71@schunter.etc.tu-bs.de>,
A sor should be pretty easy, a lathe shouldn't be extremely difficult. A
mesh may not be a huge problem either. Simple convex prisms also
wouldn't be hard, but concave or self-intersecting prisms could be a
bigger problem.
Basically the distance of the nearest point on the surface, with a
negative sign if inside the object and a positive sign if outside.
This is what my proximity pattern will eventually do.
