POV-Ray : Newsgroups : povray.off-topic : I need a new computer: RAID and other questions Server Time
15 Mar 2026 08:58:10 EDT (-0400)
  I need a new computer: RAID and other questions (Message 26 to 35 of 55)
Subject: Re: I need a new computer: RAID and other questions
Date: 27 Jan 2013 04:32:40
Message: <5104f438$1@news.povray.org>
On 26/01/2013 04:25 PM, Warp wrote:
> Orchid Win7 v1<voi### [at] devnull>  wrote:
>> For a home setup, I would suggest that RAID is way overkill, and a
>> simple offline backup now and then is what you actually want.
> The problem with this is that it's easy to forget or to just be lazy and
> procrastinate (until the day that your HD breaks.)
Yeah, well that's true enough.
(For example, I don't have any backups whatsoever. Then again, about the
worst thing that could happen is that I lose all my photos, so...)
> The best option would be to use an external storage device and an automatic
> backupping program. This way you always have a very recent backup without
> having to do anything.
Perhaps a network storage device? IDK.
> The most typical backup program for other systems is something that you
> have to run manually, and most often than not with a horrible nightmare
> of a user interface.
I love how even extremely expensive enterprise backup systems like
Symantec BackupExec have a horrifically awful GUI and minimal
documentation...
Date: 27 Jan 2013 05:25:46
Message: <510500aa$1@news.povray.org>
On Sun, 27 Jan 2013 09:30:06 +0000, Orchid Win7 v1 wrote:
> On 27/01/2013 02:12 AM, Jim Henderson wrote:
>> rsync + cron = backup goodness.
> Fine if you know your way around the CLI. Not so great for your typical
> computer user who doesn't understand all that stuff...
Fortunately, there are forums where people can ask questions about how to
set it up. :)
Jim
Date: 27 Jan 2013 05:31:33
Message: <51050205$1@news.povray.org>
> to set it up. :)
That is, if they can't figure out a Google search that will explain it to
them:
http://bit.ly/WplQf2
Jim
Date: 27 Jan 2013 05:53:32
Message: <5105072b@news.povray.org>
> > of a user interface. (For example you wouldn't believe how complicated
> > it is to restore one single file with OpenSuse's system backup utility.
> > Something that takes like 5 seconds with Time Machine can take at
> > minimum 5 minutes with OpenSuse's system backup, often more. And of
> > course it's in no way automatic.)
I don't think rsync does incremental backups. In other words, if you
wanted to restore an earlier version of a file, it's not possible.
Date: 27 Jan 2013 06:40:44
Message: <5105123c$1@news.povray.org>
Le 27/01/2013 11:53, Warp nous fit lire :
If you want to keep track of various version of a file, you need a
revision control system (and then backup the repository), such as
(<start holy war>): mercurial, cvs, rcs, svn, git, ...
( holy wars never stop, no end tag)
If hardlinks are a reality on the receiving file system, you might keep
more than one backup on the same media without doubling the actual used
size. But this starts requesting a bit of discipline.
Date: 27 Jan 2013 08:10:56
Message: <51052760@news.povray.org>
>> > you have to run manually, and most often than not with a horrible
>> > nightmare of a user interface. (For example you wouldn't believe how
>> > complicated it is to restore one single file with OpenSuse's system
>> > backup utility.
There are ways to accomplish that, sure.
The search I suggested to Andy, for example, has a couple of examples of
how to do exactly that.
Jim
Date: 27 Jan 2013 08:25:01
Message: <web.510529f6ca79cfd9c2d977c20@news.povray.org>
Yeah, very true. I certainly don't back-up as often as I should. My basic
philosophy is to 'believe' in the MTBF specs of modern hard drives (probably a
mis-placed belief!) But I generate so *little* data during the week (even
usually during a month) that I don't worry too much about a loss of 'important'
data. (Except POV-Ray files!!) I do need to be more vigilant, though.
Date: 27 Jan 2013 12:16:15
Message: <510560df$1@news.povray.org>
 From what I've seen, several revision control systems *claim* to
support large binary files, but barf if you actually try it...
There are plenty of other ways to achieve this though. E.g., find all
the files with the "archive bit" set, dump them into a dated folder,
reset the archive bit on all the files you just copied. (That's why this
file attribute exists in the first place, after all...)
Date: 27 Jan 2013 17:28:59
Message: <5105aa2b@news.povray.org>
subversion seems to handle them fine, FWIW.  I've seen it used to handle
multiple revisions of multiple-gigabyte vmdk files without a problem.
It's not terribly efficient at non-text files (it doesn't diff them, it
just stores each revision of the entire file).
I've also seen it used for binary FrameMaker files extensively, and it
versions those fine as well (though with the same caveat).
Jim
Date: 28 Jan 2013 02:59:45
Message: <51062ff1$1@news.povray.org>
Yes, svn is fine... as long as no-one activate the keywords substitution
on the binary file (and a binary file can be a word document) (and hell
opens with keywords set on, when Murphy put a $Rev$ or similar in the
binary)
