![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Impressed by the recent knot images posted recently on this newsgroup by
Bill Pragnell and others, I decided to try something in this direction
too. The knot shown here is Ashley knot #2334 (see
http://www.cs.ubc.ca/nest/imager/contributions/scharein/Ashley/).
The circuit was done entirely with Wings3D, using as a guide a model
exported from knotplot. The grass texture is taken from Rune's website,
and the car is nothing but G. Tran's mini.
All comments are welcome. I am particurlary interested by ideas about
the background: I have tried a few things without much success.
Thibaut
Download 'circuitd_33.jpg' (163 KB)
Preview of image 'circuitd_33.jpg'
![circuitd_33.jpg](/povray.binaries.images/attachment/%3C440a18b8%40news.povray.org%3E/circuitd_33.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm thinking of a very tedious and tiresome (no puin intended) animation as
viewed from the drivers seat of one of those cars as it traverses the entire
knot. Only joking. Very ingenious use of a knot. While I wondered if two
lanes might have been better for traffic I followed it around and found you
have all the cars going in the same direction, so guess that'll be okay. ;)
Now I must ask... Were you able to place the cars using the same method the
road is done? I figure they are, somehow, but being unevenly spaced that
might not be so, so I am asking please. Got to know. :)
Bob H www.3digitaleyes.com
http://3digitaleyes.com/imagery/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
My idea at first was with two opposite traffic lines, but this makes car
two times smaller on the picture, which is somewhat problematic.
The cars are simply placed in pov, using position and angle infos read
in Wings3D. I just chose the points where I wanted the cars to be, read
the corresponding position (and angles) in Wings, and then
translate/rotate the car object as needed in pov. I wish a had the
spline describing the car path along the whole knot, so I could for
example make an animation, but this would require to read manually the
position of a few hundreds vertices in wings :-/ I could not figure an
easy/lazy way to get this info yet...
Thibaut
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is really nice. Took me a couple of seconds to 'see' what I was looking
at! I sympathise with the background problem - I too had trouble thinking of
anything simple and effective. I'm now spending longer on the background
than I am on the knots...
Suggestion, to be used/recoiled from as you see fit: Put a layer of cloud
beneath the knot, then a moonlit landscape (fields, etc) below that. The
effect would then be of the knot floating 1000s of ft in the air, with the
viewpoint even higher but looking straight down.
Another option would be to use trace().
> I wish a had the
I specifically looked for parametric functions describing knots so I could
generate them algorithmically. If there's some way of persuading knotplot
to give up a mathematical function, it'd be no problem. It might be worth
contacting the author in this regard...
It'd be great to see some more of this work - keep it up!
Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Not sure if it is easy/lazy enough but I sometimes make use of the
ability in Wings to assign materials. When selected polys are then
exported into .obj format, the material assignment can be used as a sort
of label to identify vertices in the .obj file. I then parse the file
with an external script ( I like Python ) which puts the vertex/normal
info into sdl format, arrays for example.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Ashley 2334 circuit (WIP, ~160k)
Date: 6 Mar 2006 15:22:08
Message: <440c99f0@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> at!
This couple of seconds interests me ! Can you say if it is because of a
"technical"problem (image too dark, not enough contrast,...), or because
it is due to the complexity of the object shown ? I guess many people
(including me) won't often make the effort, in usual life, to look
longer at a picture which seems unclear or confuse at first sight.
Thanks, I will try something in this vein for the background. I am quite
conviced now that what is lacking is a feeling of depth behind the knot.
In fact, I use both: I perform a trace to get the angle between the
local normal and the vertical (y axis), and the wings info to get the
rotation angle in the horizontal plane.
I may have a look at the math formulae behind this knot. But it is too
late for my image now: my knot does not follow exactly the one given by
knotplot.
> Bill
Thanks for the support !
Thibaut
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Mar 2006 15:25:54
Message: <440c9ad2@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hum, parsing the .obj export sounds interesting, even if it not totally
lazy :-) The car trajectory is a single edge loop in my Wings object,
so I guess I can bevel it, assign a material to the faces, and export.
Thanks for the tip !
Thibaut
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In my case, a lack of clues about the scale. It wasn't obvious
immediately that the little dots of lights were automobiles.
Personally, I like that little delay. It's what art is about.
"I think these anchovies are spoiled.
They're not flat."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thibaut Jonckheere <tua### [at] yahoo fr> wrote:
>I wish a had the
> Thibaut
You might check out my knotsplines macro, where I describe how to get a
spline from the povray-exported bicubic patch done by KnotPlot.
Basically, I use Microsoft Word (Python or something similar would be much
easier, I'm guessing), to take the first vertex point from each patch (I
know, it would be more accurate to take one of the interior ones, since the
"edge" vertices are control points....), and put them into an array, and
form the spline from the array -- the readme/macro shows how:
http://tinyurl.com/lfvar
(although, when I try to save the zip file over the web view, it comes
through corrupted; when I try to download it with the newsreader it works
fine. I'm not sure why.)
If you'd like a copy, I can send you one.
Dave Matthews
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't think that KnotPlot ever figures an explicit parametric
representation. I think it works from points (the "beads") and splines.
That's a frustration for those of us more used to calculus and closed-form
solutions; but, I think, once one gets used to approximating from spline
points, the calculations can be much quicker and simpler (I'm still working
out a few of these, when I get the time, which is scarce right now....)
Also, I'd imagine that the parametric equations for some of the more
complicated knots would be hideous.
Dave Matthews
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
