POV-Ray : Newsgroups : povray.binaries.images : Portal Pigment - Portal pigment.jpeg (1/1) Server Time
22 Mar 2026 20:41:18 EDT (-0400)
  Portal Pigment - Portal pigment.jpeg (1/1) (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Portal Pigment - Portal pigment.jpeg (1/1)
Date: 22 Jan 2001 04:09:23
Message: <3a6bf8c3@news.povray.org>
Chris Huff <chr### [at] maccom> wrote in message
news:chrishuff-484A65.16045221012001@news.povray.org...
> This is just a test scene for the portal pigment. The transparent blue
> thing on the left is an aid for moving the "other" end of the portal
> around.
> The way things work currently is:
> Step 1: Move the portal object to wherever you want the portal to view
> from.
> Step 2: Apply the portal pigment.
> Step 3: Move the portal object to wherever you want the actual portal to
> be.
Now that looks cool!!  Will the pigment be usable in pigment maps?
functions? How fast/slow is it?
Do you plan to remove the limitations re direct light coming through
a portal?
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 22 Jan 2001 05:08:59
Message: <3A6C066E.16B33891@skynet.be>
Chris Huff wrote:
> This really has nothing to do with normals, it is a pigment...
Wouldn't it be logical to use it as an image type in image_map ?
object {
       Stuff
               image_map {
                         portal {
                                camera {...}
                         map_type ...
                         once
The resulting pigment would be mapped onto 0,1 area, as usual, and
one could use image_maps keywords to control how the "image" (though
not a bitmap) is mapped onto the object.  If someone wants to make
a normal of it, there's the "pigment pattern" feature.
Just my 2 rays.
Fabien.
Date: 22 Jan 2001 06:01:03
Message: <chrishuff-3DE84C.06021022012001@news.povray.org>
In article <3a6bf3cf$1@news.povray.org>, "Bob H."
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ra
y:> wrote:
> I see now what you meant before.  The portal gets applied in a way
> just as pigments get applied so that even though it's a copied and
> pasted portion of the original scene it's not exactly a re-raytraced
> portion.
Um, no...there is no copy/pasting of scene code. It just moves rays to
another portion of the same scene.
> That is, it's essentially a 2D representation placed based on where
> the portal view is and where it exists. Guess I'm getting closer to
> the idea there.  Perhaps.
Rays hit the object, and new rays coming from the intersection points
are transformed using the transformations that have been applied since
the pigment was applied to the object. The color resulting from tracing
those rays is used as the pigment color.
Think of it as a "ghost object" that is left behind at the position of
the object when the portal pigment is applied...no matter where the
portal object is moved, rays hitting it will emerge from that ghost
object.
Christopher James Huff
Date: 22 Jan 2001 06:13:59
Message: <chrishuff-775E87.06150522012001@news.povray.org>
In article <3a6bf8c3@news.povray.org>, "Gail Shaw"
Thanks.
It should be.
> functions?
No...it requires ray and intersection information, so you can't use it
in functions or media density. I don't think it would be very useful
function anyway...and I think the media sampling would leave
unacceptable artifacts, though it might be possible to do something in
that case.
About as fast as transparent or reflective textures.
> a portal?
Not currently...the only way I can think of to do that would be to
create a duplicate version of all light sources that is transformed to a
position that would make it appear on the far side of the portal, and
only accept direct rays that hit the portal object...and this would only
work for type 0 portals, and wouldn't be easy to implement. Of course,
maybe it only makes sense for type 0 portals...
Date: 22 Jan 2001 06:17:02
Message: <chrishuff-6A1C91.06180922012001@news.povray.org>
In article <3A6C066E.16B33891@skynet.be>, Fabien Mosen
No more than it would be to make all the other pigments
image_maps...except for camera portals, it isn't very similar at all.
The only thing they have in common is that they produce colors, which
*all* pigments do.
But you can't map the portals to a 0, 1 area...they cover a 3D surface
defined by the object the portal pigment is applied to.
Date: 22 Jan 2001 06:46:00
Message: <3A6C1D7F.D7CEEEBE@atosorigin.com>
Can you have more than one portal in a scene?
If yes, how do you handle a portal which see another
portable which see the first... (i.e. Do you limit
the recursion level ?)
Date: 22 Jan 2001 07:48:36
Message: <chrishuff-E585B7.07494322012001@news.povray.org>
In article <3A6C1D7F.D7CEEEBE@atosorigin.com>, Jerome Grimbert
The number is limited only by the number of objects you can have...it's
just a pigment.
No special handling is required for this, it will just behave similarly
to a portal that looks directly into itself.
> (i.e. Do you limit the recursion level ?)
The recursion level is limited by max_trace_level, just like
transparence and reflection.
Date: 22 Jan 2001 09:24:00
Message: <3A6C4126.E2F07808@my-dejanews.com>
> object {
>        Stuff
>        pigment {
>                image_map {
>                          portal {
>                                 camera {...}
>                          map_type ...
>                          once                 }}}
This is a really cool feature you've developed, Chris. But perhaps it's
a limitation of my understanding in that I cannot grasp its use beyond
type of application proposed by Fabien.  While I'd love to do anims
where say there are TV monitors showing 2-3 extra views of the same
action,  I still don't comprehend the concept of "portal object."
Date: 22 Jan 2001 10:07:04
Message: <3A6C4C92.38C491C0@gmx.de>
> > a portal?
How about photons? does it work with them like reflection?
Nice idea BTW, not only for the 'picture in a picture' scene but also for
abstract stuff just like reflection, but with probably a lot less
geometric limitations.
When are you planning to publish it?
Date: 22 Jan 2001 11:20:50
Message: <3a6c5de2@news.povray.org>
Okay, the more I read the more I know  :-)
I just meant copy&paste in the sense that the "portal" is extracting a copy of
the rendered scene from a certain viewpoint and then pasting that in the way of
a pigment applied to any other object.
Bob H.
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-3DE84C.06021022012001@news.povray.org...
> object.
