POV-Ray : Newsgroups : povray.binaries.images : Granites Intermezzo Server Time
21 May 2024 08:38:41 EDT (-0400)
  Granites Intermezzo (Message 67 to 76 of 86)
Subject: Re: Granites Intermezzo
Date: 9 May 2021 02:41:43
Message: <60978427$1@news.povray.org>
Op 08/05/2021 om 23:19 schreef Dave Blandston:
>> Oho... bounced back with following message:
> It looks like part of the address may have been obscured and/or scrambled
> somewhere along the way. I'll break it up to stymie the system. The first part
> should be isnomore then the circled a symbol then the domain which is protonmail
> then a dot then the letters ch. I also just took the opportunity to update my
> profile with the e-mail address so hopefully that will help.
> Kind regards,
> Dave Blandston
> POV-Ray rebel: proudly using gamma 2.2 since POV-Ray had gamma
OK. I sent the code again and this time correctly it seems. Your initial
mail address was indeed different from this one. You got also the latest
version, on its way to the macro structure I have in mind. Easier to use
and: many more options to select from!
Warning: A couple of things do not work (correctly) as yet. The polished
version of the granite (Pol=on), and the veined version (Typ=2). Neither
does the subsurface light transport. And finally, the colour space
switch (SCS) is not implemented either.
Good luck, and let me know your thoughts about the code.
Date: 9 May 2021 03:30:00
Message: <web.60978ef7cfb077e479416a1f607c1b34@news.povray.org>
Got it!
Kind regards,
Dave Blandston
Date: 9 May 2021 19:10:00
Message: <web.60986abecfb077e479416a1f607c1b34@news.povray.org>
> ...on its way to the macro structure I have in mind. Easier to use and: many more
Based on your demo images I was expecting the StepNoise version to look best but
the crackle solid version seemed slightly more realistic in this particular
scene. The option to select which function to use is very useful.
LIGHTSYS is a much better lighting method than I've been able to achieve so some
realism was lost in my scene but I think you and your collaborators have created
an awesome material. Maybe LIGHTSYS can be applied to this scene in order to
take full advantage of the subtle nuances of your granite but that will have to
be a project for another day...
The attached image shows how great the new granite looks in spite of my poor
scene lighting ability. This type of granite turned out to be a little too
"busy" for this scene but I think the Flanders Gray will be perfect. (Just as
you described in your posting!) The coloration of the Flanders Gray sample is
spectacular in my opinion and I hope that variation makes it into the final
product.
Thanks for letting me beta test your granite!
Kind regards,
Dave Blandston
Download 'dakotagrainshighlight.jpg' (147 KB)
Preview of image 'dakotagrainshighlight.jpg'
Date: 10 May 2021 02:10:12
Message: <6098ce44$1@news.povray.org>
Op 10/05/2021 om 01:05 schreef Dave Blandston:
Good.
Sure, especially for landscapes.
> product.
You could try the 'blend' option here and see if it looks better. The
template of the Dakota Red will be used for the other granites too later
on, with the necessary adaptations of course to those particular granites.
And thanks for testing! In the meantime, I have finished a preliminary
macro architecture including also the polished version and the veins.
Very soon now, I shall post a beta for everybody to shoot at. Stay attuned!
Date: 10 May 2021 04:20:00
Message: <web.6098ec72cfb077e479819d986cde94f1@news.povray.org>
hi,
super, thanks.  looking forward to it.
regards, jr.
Date: 11 May 2021 03:55:00
Message: <web.609a36f4cfb077e479416a1f607c1b34@news.povray.org>
I do have one suggestion, which is to replace "#declare" with "#local" for
everything except the finished materials. I ran into one conflict. (It was a
function denoted by the single letter "K.")
I am very excited about this project! After experimenting a little more I'm
convinced this is a major development and will certainly be replacing the old
granite in my project with this wonderful new concoction.
By the way, what is the meaning of "Granites Intermezzo?"
Have an awesome day!
Kind regards,
Dave Blandston
Suggested motto: "With POV-Ray anything is possible, but nothing is easy"
Date: 11 May 2021 04:23:31
Message: <609a3f03$1@news.povray.org>
Op 11-5-2021 om 09:50 schreef Dave Blandston:
Which is/will be done indeed in the upcoming macro version.
"K" would point to the Bald Eagle Step Noise contribution. It is not yet
entirely well-integrated. However, I never had conflicts with it, so
maybe you got a special case?
Thanks indeed. I am certainly satisfied with the results too. Still a
couple of things to take care of, but nothing really serious at this stage.
I consider this series of posts as 'intermediary' between the original
exchange, starting with the Daniel Mecklenburg code upgrade, and the
upcoming beta version of a first granite set. More will follow after
that one.
<grin>
Date: 11 May 2021 06:20:00
Message: <web.609a59ffcfb077e41f9dae3025979125@news.povray.org>
Mmm, yes.  I suppose that anything that could be released upon exit from the
include file ought to be declared locally, if for no other reason that to
practice good form going forward from this point.
K is pretty much just a straight copy-paste from from Wikipedia / Inigo Quilez /
ShaderToy / The Art of Code / GLSL ...  I just used the same variable names to
make reading and potential debugging easier upon a first read-through.
Ken Perlin has suggested an improved version, no idea how that would affect the
appearance of the texture.
I suppose there are a lot of variations that would be nice to look at, exploring
different interpolation formulas and splines.
Date: 11 May 2021 07:30:00
Message: <web.609a6a17cfb077e479416a1f607c1b34@news.povray.org>
Yep, that would be good - keep everything local that can possibly be kept local.
There is at least one other single-letter function designator ("N") so the
chance of a conflict with other variables in a scene definitely exists. The
reason I had a collision with "K" is because I use the letter "I" to control
loops (short for "Index") then for nested loops I just keep going with "J," then
"K," et cetera. "N" is probably popular because it's the first letter of
"Number." There is no downside to using "#local" wherever possible, but there is
a benefit.
Kind regards,
Dave Blandston
Date: 11 May 2021 08:05:03
Message: <609a72ef@news.povray.org>
Op 11-5-2021 om 13:27 schreef Dave Blandston:
> a benefit.
I am presently looking at Bald Eagle's code with the intention to
implement it inside the granite macro. In that case, all declares will
become locals obviously and stop giving problems like you encountered.
Another consequence will be that I shall need to define at least three
additional parameters for the granite macro: Start, End, Turbulence.
@Bald Eagle: in your original code you also defined a parameter "Scale"
which subsequently was not used. Where did you want to place it? It
might be an interesting fourth addition.
My reworking of the code would look like this:
//---start code---
#ifndef (SN_Start) #local SN_Start = 0.2; #end
#ifndef (SN_End)   #local SN_End   = 0.8; #end
#ifndef (SN_Turb)  #local SN_Turb  = 0.325; #end
#ifndef (SN_Scale) #local SN_Scale = 0.25; #end
// smoothstep function
#local K = function (t1, t2, T) {max (0, min(1, (T-t1)/(t2-t1) ) )}
#local Smoothstep = function (t1, t2, T) {pow (K(t1, t2, T), 2) *
(3-2*K(t1, t2, T))}
// mod function that plays nice when crossing 0
#local Mod = function (T) {select (T,  1-mod (abs(T), 1),  mod (abs(T),
1) )}
// smooth step function
//#local N = function (NN) {floor (NN-0.5) + Smoothstep (SN_Start,
SN_End, abs(Mod(NN-0.5)-0.5) )}
#local N = function (NN) {floor (NN) + Smoothstep (SN_Start, SN_End,
Mod(NN) )}
/* usage
#declare StepNoise =
   function {f_noise3d (N(x), N(y), N(z))}
   turbulence SN_Turb
//---end code---
