Been some time since my last image from Gancaloon. Steady changes and
steady progress since then. Main development being the replacement of
the city blocks by 'real' geometry. Progress still under way and only as
first version without doors and windows. Potentially however, I have now
the possibility to make any street scene I want, wherever in the city.
Further, I make extensively use of Edouard Poor's proximity pattern
macro which is the one I prefer at this moment. Sam Benge's comes as
close second ;-)
Download 'gancaloon_river harbour3_05.jpg' (284 KB)
Preview of image 'gancaloon_river harbour3_05.jpg'
> close second ;-)
> Thomas
Hi Thomas,
a nice view of Gancaloon again. Two nitpicks: You should consider the use of the
occulsion map baking for the statue and a higher camera position to see the
water between the paths.
Best regards,
Michael
You should have a website for this series. (As if you need any more
demands on your time.) :-)
I don't agree with Michael about a higher camera position. Then you
would not get the handrail view. And I think that you have spent a lot
of time, refurbishing that boat. :-)
Regards
Subject: Re: A new view from Gancaloon's harbour
Date: 19 Feb 2013 16:01:09
Message: <5123e815@news.povray.org>
great view from the ship!
The two right-most figures appear a bit "headless" to me ;)
Likely an effect of dark head against dark background.
Also I wonder if the water lanes should be wider? From economy
of building I'd expect they should fit two ships side by side.
> close second ;-)
And you are probably very fond of the effects you can create
with this, but don't overdo it. I would hope a prestigous statue
in a shiny harbour could be a little better maintained ;)
I agree that the statue's texture is a bit extreme. I still need to come
up with a better overall texture and, in particular, make better use of
the proximity pattern. Baking the occlusion map is a next option indeed.
About the camera position, I shall see. I don't want to loose the
contact with the ship ;-)
Indeed for both points ;-) I have no plans in that direction however.
Yes, that might be the problem indeed. However, I shall consider the
possibilities.
You don't want to know /how much/ time that is, and still not finished.
About nothing is left of the original geometry/textures and many have
been added.
Date: 20 Feb 2013 03:35:45
Message: <51248ae1@news.povray.org>
Thanks!
Ah yes! Just a matter of contrast indeed.
Believe it or not, there is ample room for two ships side by side in
most if not all of the docks! Perspective is playing a bad trick here.
>> close second ;-)
Oh well.... the intention is indeed bad maintenance and age. I agree
with you however and shall work a bit more towards a more believable
aspect ;-)
Date: 20 Feb 2013 03:53:29
Message: <51248f09@news.povray.org>
So I am proved a liar ;-)
Somehow I have not paid attention to some proportions and sizes and
shall have to reconsider.
I remember that my original intention was to have docks for all kind of
vessels, large but also small. This might need proper attention...
Download 'gancaloon.png' (557 KB)
Preview of image 'gancaloon.png'
Not too bad. The most narrow docks are 5m wide. Considering that on the
river there are a score of small vessels, from the pirogue-scale
upwards, those would be reserved for them.
No real need for rebuilding ;-)
Am 20.02.2013 13:33, schrieb Thomas de Groot:
5m wide = max. 1.5m width per ship.
I doubt that such small ships would be moored directly sideways to a
solid stone quay. After all, what heavy or bulky load could they
possibly carry? And how would they get out of the ships at low tide?
More likely you'd have narrow wooden walkways for such small vessels,
floating on pontoons; and you'd moor multiple vessels side by side to those.
