POV-Ray : Newsgroups : povray.binaries.images : HDRI tests (200 kbu) Server Time
4 Jun 2026 09:59:32 EDT (-0400)
  HDRI tests (200 kbu) (Message 21 to 30 of 30)
Subject: Re: HDRI tests (200 kbu)
Date: 23 Dec 2002 20:26:24
Message: <1976600.qA3ka4jJYh@3-e.net>
For lighting (rather than reflection mapping) you would not need more than
the brightest 10% of pixels in the image, these could be lights behind a
translucent sphere that held the matching image map so that you still had
reflection/environment mapping. The lights would need to be directed at the
center of the sphere so as to avoid them illuminating the dark parts of the
map/sky.
John Pallett wrote:
> That's a good idea - though I'd hate to think of the number of lights
> created for a 1024x768 image... :)
> I'm wondering if there's a way to crank up the ambient value of the sky
> sphere, perhaps after darkening the 'dark' parts of the image, so that the
> end result is an approximation of an HDR radiosity solution.  Right now
> when I use a sky sphere, it gives a nice effect, but the effect is too
> subtle.
> Perhaps adjusting the contrast (keep the bright parts bright, darken the
> rest) of an image, then setting its ambient value to 10, would do the
> trick
> and could simulate an HDR image.  I'll have to experiment, it probably
> depends upon which image is used.
> JP
> "Daniel Matthews" <dan#@3-e.net> wrote in message
> news:100### [at] 3-enet...
>> Something more complex than mapping the image to a sky sphere?
>> Such as converting the image to an array of light sources distributed
>> over
> a
>> sphere? There are examples of both pixel data to object conversions and
>> spherical distribution of objects, you will need to look through the
>> older news post to find them, both are in the last 6 months.
>> There is also a Lighting inc that could be upgraded to perform such
>> lighting.
>> John Pallett wrote:
>> > Is there a way to coerce POV-Ray 3.5 into doing this without the patch?
>> > Perhaps a pre-processing step on the HDR image and then the appropriate
>> > radiosity parameters?
>> > JP
>> > "Gilles Tran" <git### [at] wanadoofr> wrote in message
>> > news:3e04e8bf@news.povray.org...
>> >> Here are some tests of the HDRI (high dynamic range illumination)
>> >> patch by Mael.
>> >> The model is the Lego Ferrari by Kenneth Storm (see  the p.b.i thread
>> > "Lego
>> >> Ferrari" on Sept 2).
>> >> The HDR maps are those available at Paul Devebec's site (I put the
> probes
>> >> name for reference) http://www.debevec.org
>> >> There's nothing much to it actually : just the HDR map, no lights,
>> >> same standard radiosity parameters. There are some visible artefacts
>> >> in the
>> > maps
>> >> that have many strong light sources (like the Galileo probe), but the
> way
>> >> the HDR map seems to replace light sources is really amazing (apart
>> >> the
>> > lack
>> >> of specular highlights, of course).
>> >> I still have to test it on "real" scenes though, where the
>> >> illumination
>> > also
>> >> comes from regular objects. I really can't take credit for anything in
>> > these
>> >> tests ! Before I tested it, I couldn't figure out whether HDRI was
> really
>> >> better than plain radiosity, but it really is.
>> >> Important note : the patch is not publicly available yet (there's a
>> > Megapov
>> >> version somewhere) but I hope that Mael will release it soon.
>> >> G.
>> >> http://www.oyonale.com
>> >> - Graphic experiments
>> >> - POV-Ray and Poser computer images
>> >> - Posters
>> Your connection failed because: Lightning strikes.
Your connection failed because: Redundant ACLs.
Date: 23 Dec 2002 23:15:51
Message: <3e07df77$1@news.povray.org>
I know it can do the tiling, but I couldn't tell from the French
documentation how to "map" the texture of one image on to another, which is
what the "texture transfer" effect is. Can you tell me the syntax for this?
Thanks much,
D.
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3e0746c0$1@news.povray.org...
> Xns### [at] povrayorg...
> > Yes it's the "Synthese Patch" section
> Btw, I've tested this feature too. It works, but it's a little
disappointing
> : it's OK for small maps made of smaller maps, like those in the examples,
> but computing a not very large map (1200*1200) took several hours on my P4
> and getting a "synthese" map right requires a lot of trial and error.
There
> goes my hope of creating 4000*4000 realistic wall and bark maps out of
> 500*500 samples...
> G.
> - Posters
Date: 24 Dec 2002 04:18:33
Message: <3e082669$2@news.povray.org>
Hello,
the patch doesn't implement the texture transfert, only the synthese (which
is, i agree, quite slow and has nothing to do in a ray tracer :)
M
Date: 24 Dec 2002 11:45:40
Message: <3e088f34$1@news.povray.org>
Smart thinking - I'll have to give that a try.  :)
JP
news:197### [at] 3-enet...
the
the
> map/sky.
the
> > subtle.
> > trick
> > JP
> >> over
> > a
> >> lighting.
patch?
appropriate
> >> > JP
> >> >> patch by Mael.
thread
> >> > "Lego
> > probes
> >> >> in the
> >> > maps
the
> > way
> >> >> the
> >> > lack
> >> >> illumination
> >> > also
in
> >> > these
> > really
> >> > Megapov
> >> >> G.
> >> >> - Posters
Date: 24 Dec 2002 17:03:08
Message: <3e08d99c@news.povray.org>
the
the
> map/sky.
In fact before I tested HDRI I tried the following method with radiosity (to
use with an environment sphere):
texture{
    image_pattern{jpg "mymap"} // grayscale map used to create variations in
light intensity
    texture_map{
        [0 T_Sky {finish{ambient 0}
        [i T_Sky {finish{ambient j}
        [1 T_Sky {finish{ambient 10}
I didn't manage to get good results though. HDRI is much easier to set up
(of course having HDR maps helps a lot...).
G.
- Posters
Date: 25 Dec 2002 02:02:40
Message: <130103783.bbecjdu0SW@3-e.net>
I bet it does! I just found the stuff I was doing ages ago,
3d Max -> MaxMan -> BMRT
It was very tedious.
Did you get that scale issue worked out, or was that really a giant lego car
in St Peters?
:o)
Your connection failed because: overflow error in /dev/null
Date: 25 Dec 2002 02:07:05
Message: <3e095919@news.povray.org>
> texture{
> light intensity
>     texture_map{
This is the same method  I have used for my vermeer things, but you should raise the
ambient value. The dynamic range for daylight images covers a much higher range
as 0.0 to 10.0. Go up 'till 500 or even 1000. In fact this is the same as using a High
Dynamic Range Image as a backdrop. BTW the I in HDRI stands simply for Image
and those images are among many other things useful for global illumination.
The probes from Paul Devebec's page are in the Radiance format wich uses usually
the extension .rgbe or .pic (not to be confused with the mac pic format) so if you are
looking for light probes you can also use files with this extensions. (But I do not
know
how this is implemented in mlpov so maybe you have to rename the files.)
so long
-Ive
Date: 25 Dec 2002 05:30:04
Message: <web.3e0987e380aec5e889e867a00@news.povray.org>
Hi all,
I've been trying to use the same technique with beach probe, and so far the
results are not good.
Here is the relevant part of the pov file
#declare QUAL = 3;  // Quality level, 0=BBox, 1=no refr, 2=normal,
3=studlogo
#declare SW = 0.5;  // Width of seam between two bricks
#declare STUDS = 1;  // 1=on 0=off
#declare BUMPS = 1;  // 1=on 0=off
#declare BUMPNORMAL = normal { bumps 0.01 scale 20 }
#declare AMB = 0.0;
#declare DIF = .9;
#version unofficial mlpov 0.8;
global_settings {
  radiosity {
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.04           // end pretrace at this size
    count 100                      // higher -> higher quality (1..1600)
[35]
    nearest_count 5               // higher -> higher quality (1..10) [5]
    error_bound 1.8               // higher -> smoother, less accurate [1.8]
    recursion_limit 3             // how much interreflections are
calculated (1..5+) [3]
    low_error_factor .5           // reduce error_bound during last pretrace
step
    gray_threshold 0.0            // increase for weakening colors (0..1)
[0]
    minimum_reuse 0.015           // reuse of old radiosity samples [0.015]
    brightness 1                  // brightness of radiosity effects (0..1)
[1]
    adc_bailout 0.01/2
    normal on                     // take surface normals into account [off]
sphere {
  0,1350
  pigment { image_map { hdr "beach_probe.hdr" once interpolate 2 map_type 7
  finish { ambient .8 diffuse 0.8 }
  hollow
// create a box that extends between the 2 specified points
box {
  <-500, -500, -500>  // one corner position <X1 Y1 Z1>
  < 500,  500,  500>  // other corner position <X2 Y2 Z2>
  translate 515*y
  pigment { color rgb <0.9,0.9,0.9> }
  finish { ambient 0.2 diffuse 0.9 }
...... (part of the lego car is here, without the lights and the camera and
global settings of its file)
Any idea of what's wrong?
Best regards and Merry Xmas / Fernando
Date: 25 Dec 2002 14:30:52
Message: <3e0a076c@news.povray.org>
130### [at] 3-enet...
car
> in St Peters?
After checking, it's big. Hmm, looks like JP2 developed a particular liking
in mammoth models of toy cars. I wonder about that 40m-tall Barbie (TM) doll
in Castelgandolfo. I'm not sure what this means for the future of
Christendom.
On other news, when HDR doesn't work it gives the *** worse *** radiosity
artefacts ever.
G.
- Posters
Date: 25 Dec 2002 15:25:02
Message: <web.3e0a13ab80aec5e8978071460@news.povray.org>
>artefacts ever.
Nah, worse than a scene lit by a lilliputian -ambient 1000- sphere?
But I have to agree that the galileo_probe pic gave me the worst artefacts I
have ever got. And I still have to get over it...
Jonathan.
