POV-Ray : Newsgroups : povray.binaries.images : double_illumination + radiosity (37.2kb jpg) Server Time
5 Jun 2026 13:17:52 EDT (-0400)
  double_illumination + radiosity (37.2kb jpg) (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: different lighting (37.6kb jpg)
Date: 21 Jun 2002 19:58:34
Message: <3D13BDA5.4000200@caltel.com>
Hugo wrote:
> I don't know why or how you are able to continue posting images of higher
> quality than most of us.
Sure you do! A person just keeps learning new tricks and storing them
away for future use. You think of an idea or feature and expand on it.
>These are some of the best radiosity scenes I've
> seen in POV!
With time you'll see more. The developers of POV(official and
unofficial) have made radiosity faster and easier to use. More people
are using it now, and more will be using it in the future.
> I'm especially impressed by the apparently small amount of time you need to
> code these things. You must have a lot of experience.
I've been using POV since version 3.1(about 4-5 years ago?).
Samuel Benge
sbe### [at] caltelcom
Subject: Re: double_illumination + radiosity (37.2kb jpg)
Date: 21 Jun 2002 20:08:47
Message: <3D13C009.2000807@caltel.com>
Artis wrote:
> Nice idea and image....
> ...but that's just a cheap trick, you have to use media (^&
The problem with subsurface scattering via media is that the light still
passes through in a straight line. The light isn't made diffuse after
exiting the object, so all you get on the other side are objects that
have clean shadows. I can only imagine how long a render would take with
radiosity and media coupled together! This trick actually simulates the
effect rather accurately, as far as I can tell.
But I know you must just be kidding, because who would want another
person to endure a month-long render? ;)
Samuel Benge
Date: 22 Jun 2002 00:21:48
Message: <3d13fb5c$1@news.povray.org>
I absolutely AGREE!!!
Please post the source or render a 1152x864 version for my desktop...... :-P
And now for animation......!
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 22 Jun 2002 01:18:58
Message: <3D1408EC.DE08AE2C@infomagic.net>
Of course, having a fast machine helps. Your lamp image, for instance,
is apparently using fairly high-quality radiosity, with normal on, and
an area light to boot. I don't want to think about how long it would
take MY machine to render that.. or to do the requisite test renders to
make it look good.
-Xplo
Date: 22 Jun 2002 01:33:11
Message: <3D140C43.2EC6BB3E@infomagic.net>
My tests with MegaPOV show that radiosity and media don't seem to work
together in the way you imply. In fact, I'm not really sure how they
work together at all; maybe radiosity is affected by emission media or something?
I've no idea if this was fixed in 3.5.
-Xplo
Date: 22 Jun 2002 03:44:45
Message: <3D142AEC.D21A5347@gmx.de>
Samuel Benge wrote:
> I'm glad that POV 3.5 now supports radiosity interaction with double
> illumination. When MegaPOV came out with it's double_illumination
> keyword, I tried a similar experiement with no apparent effects from the
> radiosity.
> This is just a simple test of this interaction involving a barn made
> from wood beams and fiberglass panels. Sun shines past a tall box
> casting partial light onto the barn, thus simulating scattered light inside.
> Questions, Comments?
Very neat, i never thought the effect could be that realistic.
One thing that i'm missing about double_illuminate is a possibility to
diminish the amount of light from the back surface, something like an
additional float parameter between 0 and 1. Of course for such scenes
where only the back side is visible there is no need for it.
Last updated 14 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Jun 2002 10:51:20
Message: <3d148ee8@news.povray.org>
> I think I can render one next time I go on a hike
That'd be very much appreciated!
>  (when I'm home, the only things to do are done through the computer).
I know how that is ;) I just finished two more than a day long renders..
Pretty scary when you start thinking of how much time you spend in front of
the computer.. And how hard it is to do something else when you're at home
> I will! Someday I'll even finish a scene!
I think the pictures you posted qualify for 'scene', more than 'test'. Looks
more finished than my few finished scenes ;)
-Peter
Date: 22 Jun 2002 11:55:32
Message: <3D149DEF.5080204@caltel.com>
 From the 3.5 docs:
"Media and Radiosity
Radiosity estimation can be affected by media. To enable this feature,
       add media on to the radiosity{} block. The default is off"
Samuel Benge
Date: 22 Jun 2002 12:00:03
Message: <3D149EFD.5060002@caltel.com>
I'm with you there. Even more than that, there should be optional
double_illuminate keywords for texture_maps so you could make, for
example, realistic leaves. You could simulate the effect of variable
thickness on a very minute scale without having to use impossible media
settings.
Samuel Benge
Date: 22 Jun 2002 13:03:49
Message: <3d14adf5@news.povray.org>
Oooo... That looks photoreal in some spots...
