POV-Ray : Newsgroups : povray.binaries.images : Two broken Blobs (Bug ?) (8KB) Server Time
19 Nov 2025 03:49:35 EST (-0500)
  Two broken Blobs (Bug ?) (8KB) (Message 1 to 10 of 10)
Subject: Two broken Blobs (Bug ?) (8KB)
Date: 4 Sep 2000 16:35:42
Message: <39B4064A.5F6FC3E3@online.no>
Several combinations of threshold, strength
scaling and rotations seem to do this to my
blobs  :((
Can anyone explain what is going in here.
See code below.
Tor Olav
mailto:tor### [at] hotmailcom
#version 3.1;
blob {
  threshold 0.01
    cylinder {
      -y, y, 1
      strength 1
      scale <2, 0.5, 1.0>
      rotate 20*z
  sturm
  pigment { color rgb <0, 1, 1> }
  translate -(x + z)/2
blob {
  threshold 0.1
    sphere {
      <0, 0, 0>, 0.7
      strength 1
      scale <2.0, 0.5, 1.0>
      rotate 30*z
  sturm
  pigment { color rgb <1, 1, 0> }
  translate z*3/2
background { color rgb <1, 1, 1>/2 }
light_source {
  <10, 8, -5>
  color rgb <1, 1, 1>
  location <2, 3, 2>
  look_at <0, 0, 0>
Download 'brokenblob01.jpg' (8 KB)
Preview of image 'brokenblob01.jpg'
Subject: Re: Two broken Blobs (Bug ?) (8KB)
Date: 4 Sep 2000 18:31:49
Message: <39b422d5@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:39B4064A.5F6FC3E3@online.no...
| blobs  :((
Can't explain it but if threshold for the cylinder is 0.075 and for the
sphere 0.21 they both seem okay at that point.
Changing the scale to 5 times larger (and applying *5 to camera location,
light position and the translations of sphere and cylinder too) doesn't fix
them.  I was trying to see if there were too small because that's a know
problem with the primitives if they get too small.  These aren't in the
range of size that would be a problem normally to begin with though.
Date: 4 Sep 2000 19:44:36
Message: <39B2F3C0.B080338B@earthlink.net>
It has to do with the scale... try changing the offending scale to a
negative... i.e... <-x,y,z> vs <x,y,z> why this is i don't know... It happened
to me when using the <matrix> w/ blobs...?
> | blobs  :((
> Bob
Date: 4 Sep 2000 20:59:06
Message: <39B4440C.35D5F8BB@online.no>
> | blobs  :((
Thank you for looking into the problem Bob.
I have some blob images that have "faults" in
them because of this (methinks).
And even if I could make the faults go away with
simpler blobs (by altering settings as you describe
above), I wouldn't know how to tweak the settings
for the more complicated blobs I made.
I too was afraid that I used to marginal values,
so therefore I tried to find more "normal" values
that also damaged the blobs.
I'm not sure yet if this problem qualifies as a bug.
Are there any TAG-people out there that can
cast some light on this problem  ?
Tor Olav
Date: 4 Sep 2000 21:03:15
Message: <39B44506.F72745F4@online.no>
Thank you for this information.
Do you have any examples of blobs that was destroyed
and that could be fixed that way?
Tor Olav
Date: 5 Sep 2000 13:44:29
Message: <chrishuff-65FAA7.12461105092000@news.povray.org>
In article <39B4440C.35D5F8BB@online.no>, Tor Olav Kristensen
It might simply be a result of the rendering method..."fixing" it might
be either very difficult or result in a rendering slow down.
You might be able to get around the problem by using an isosurface, just
use the blob pattern as the isosurface function. You might even get a
speed up...and just for fun, apply some warps to the pigment function.
I have found that turbulence makes a nicely bumpy corroded-metal surface.
Hmm, I suppose I should come up with some witty remark about casting
light in a raytracer, maybe including photons, but I can't think of
anything right now. :-)
Christopher James Huff
Date: 5 Sep 2000 16:08:39
Message: <bvgars8d5jmeluodf4cduqdl53trhccv6k@4ax.com>
On Mon, 04 Sep 2000 22:30:02 +0200, Tor Olav Kristensen
>blobs  :((
>See code below.
Looks like a bug in the internal bounding hierarchy for the blob
objects, as disabling it seems to fix the problem.
I hope this gives enough insight to those who know where to look for
the bug in the source code.
Peter Popov ICQ : 15002700
Date: 7 Sep 2000 21:02:29
Message: <39B8395B.C0B2BF4@online.no>
> >blobs  :((
> >See code below.
Thank you Peter.
Are you saying that it is possible to tell POV-Ray
(without recompiling) to disable internal bounding ?
And that the defects disappears when you're doing this ?
If so, then I'm a happy man again !
Tor Olav
Date: 8 Sep 2000 07:08:05
Message: <39B8C8A6.18DCE9B3@atos-group.com>
> >blobs  :((
> >See code below.
Agreed, at least for the bug coming from the bounding hierarchy.
I did not try to disable it, I find the bug instead.
Bug found, and a correction has now been proposed in povray.general
(and I even made a web page in french about it, but you'd better be patient
or have a T1 connection (lot of pictures))
http://grimbert.cjb.net/pov/correct/blob.html
Have a nice day!
Date: 9 Sep 2000 16:41:06
Message: <a6vkrs8579a79lspksg3mhgb8idphgj9ui@4ax.com>
On Fri, 08 Sep 2000 02:56:59 +0200, Tor Olav Kristensen
>Thank you Peter.
hierarchy off
Does that help? Oh, and BTW it's in the docs :))
Yup.
Glad to hear that.
