Several combinations of threshold, strength
scaling and rotations seem to do this to my
blobs :((
Can anyone explain what is going in here.
See code below.
Tor Olav
mailto:tor### [at] hotmail com
#version 3.1;
blob {
threshold 0.01
cylinder {
-y, y, 1
strength 1
scale <2, 0.5, 1.0>
rotate 20*z
sturm
pigment { color rgb <0, 1, 1> }
translate -(x + z)/2
blob {
threshold 0.1
sphere {
<0, 0, 0>, 0.7
strength 1
scale <2.0, 0.5, 1.0>
rotate 30*z
sturm
pigment { color rgb <1, 1, 0> }
translate z*3/2
background { color rgb <1, 1, 1>/2 }
light_source {
<10, 8, -5>
color rgb <1, 1, 1>
location <2, 3, 2>
look_at <0, 0, 0>
Download 'brokenblob01.jpg' (8 KB)
Preview of image 'brokenblob01.jpg'
"Tor Olav Kristensen" <tto### [at] online no> wrote in message
news:39B4064A.5F6FC3E3@online.no...
| blobs :((
Can't explain it but if threshold for the cylinder is 0.075 and for the
sphere 0.21 they both seem okay at that point.
Changing the scale to 5 times larger (and applying *5 to camera location,
light position and the translations of sphere and cylinder too) doesn't fix
them. I was trying to see if there were too small because that's a know
problem with the primitives if they get too small. These aren't in the
range of size that would be a problem normally to begin with though.
It has to do with the scale... try changing the offending scale to a
negative... i.e... <-x,y,z> vs <x,y,z> why this is i don't know... It happened
to me when using the <matrix> w/ blobs...?
> | blobs :((
> Bob
> | blobs :((
Thank you for looking into the problem Bob.
I have some blob images that have "faults" in
them because of this (methinks).
And even if I could make the faults go away with
simpler blobs (by altering settings as you describe
above), I wouldn't know how to tweak the settings
for the more complicated blobs I made.
I too was afraid that I used to marginal values,
so therefore I tried to find more "normal" values
that also damaged the blobs.
I'm not sure yet if this problem qualifies as a bug.
Are there any TAG-people out there that can
cast some light on this problem ?
Tor Olav
Thank you for this information.
Do you have any examples of blobs that was destroyed
and that could be fixed that way?
Tor Olav
In article <39B4440C.35D5F8BB@online.no>, Tor Olav Kristensen
It might simply be a result of the rendering method..."fixing" it might
be either very difficult or result in a rendering slow down.
You might be able to get around the problem by using an isosurface, just
use the blob pattern as the isosurface function. You might even get a
speed up...and just for fun, apply some warps to the pigment function.
I have found that turbulence makes a nicely bumpy corroded-metal surface.
Hmm, I suppose I should come up with some witty remark about casting
light in a raytracer, maybe including photons, but I can't think of
anything right now. :-)
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
On Mon, 04 Sep 2000 22:30:02 +0200, Tor Olav Kristensen
>blobs :((
>See code below.
Looks like a bug in the internal bounding hierarchy for the blob
objects, as disabling it seems to fix the problem.
I hope this gives enough insight to those who know where to look for
the bug in the source code.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
> >blobs :((
> >See code below.
Thank you Peter.
Are you saying that it is possible to tell POV-Ray
(without recompiling) to disable internal bounding ?
And that the defects disappears when you're doing this ?
If so, then I'm a happy man again !
Tor Olav
> >blobs :((
> >See code below.
Agreed, at least for the bug coming from the bounding hierarchy.
I did not try to disable it, I find the bug instead.
Bug found, and a correction has now been proposed in povray.general
(and I even made a web page in french about it, but you'd better be patient
or have a T1 connection (lot of pictures))
http://grimbert.cjb.net/pov/correct/blob.html
Have a nice day!
On Fri, 08 Sep 2000 02:56:59 +0200, Tor Olav Kristensen
>Thank you Peter.
hierarchy off
Does that help? Oh, and BTW it's in the docs :))
Yup.
Glad to hear that.
