POV-Ray : Newsgroups : povray.advanced-users : Radosity, memory, and always resample Server Time
8 Mar 2026 01:55:51 EST (-0500)
  Radosity, memory, and always resample (Message 1 to 8 of 8)
Subject: Radosity, memory, and always resample
Date: 23 Jun 2006 08:40:01
Message: <web.449be0e863afbb2d8af060f60@news.povray.org>
I'm creating an image that involves a large patch of grass. This eats up a
bit of my RAM, but the image will parse and start rendering just fine.
Unfortunately fter about 8 hours into the render it quits with a memory
error "unable to allocate.."
This is the second image I've had the problem on. Both high resolution with
HDR environments and radiosity. I'm starting to think that it's the
additional samples of radiosity during the rendering that's causing the
memory overload.
I've restarted the rendering with always resample set to off and hope this
will fix it but won't know for about 8 hours if it did.
Any ideas?
Phil Brewer
Subject: Re: Radosity, memory, and always resample
Date: 23 Jun 2006 10:44:55
Message: <449bfe67@news.povray.org>
how many light sources do you use ?
news:web.449be0e863afbb2d8af060f60@news.povray.org...
with
> memory overload.
> Any ideas?
> Phil Brewer
Date: 23 Jun 2006 10:55:00
Message: <web.449bfffd80eb3ffe8af060f60@news.povray.org>
Currently none. Just the HDR image mapped to a hollow sphere around my
scene. Sorry to not mention that I'm using megapov 1.2.1 for that
functionality.
Radiosity if providing all of the light for my scene.
Date: 23 Jun 2006 11:10:03
Message: <e7h05p$td8$1@chho.imagico.de>
> memory overload.
It might or might not, depending on your settings, scene and your memory
limits.
You have two options:
- use more reasonable radiosity settings (if the render takes more than
8 hours with just a patch of grass they most likely are not).
- make more memory available to POV-Ray (by changing your OS settings or
getting a computer system with larger address space).
http://www.imagico.de/ (Last updated 01 Jun. 2006)
Date: 23 Jun 2006 11:55:00
Message: <web.449c0ec180eb3ffe8af060f60@news.povray.org>
Here's my current radiosity block that crashed:
global_settings {
    radiosity {
      pretrace_start 0.1
      pretrace_end   0.001
      count 50
      nearest_count 5
      error_bound .15
      recursion_limit 1
      low_error_factor .01
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 1
      adc_bailout 0.01/2
      normal on
      adaptive 1
      save_file "golf_rad.rad"
The scene consists of three golf balls and a putter sitting on a 2000 blade
square patch of grass mesh copied 580 times to fill the visible scene. I'm
using a focal blur of 90 samples, and the above radiosity. I'm rendering at
1680x1050. Is there any improvement I can make to my radiosity settings to
ease memory usage?
> limits.
> Christoph
Date: 23 Jun 2006 12:45:01
Message: <web.449c1a8880eb3ffe8af060f60@news.povray.org>
Here's a low-quality test-render of the image with a smaller grass density
and no focal blur. Sorry for the white block, but the putter is a
proprietary design and I can't disclose it.
http://www.brewerdigitalarts.com/golf_temp.jpg
Date: 23 Jun 2006 12:55:06
Message: <e7h676$vt6$1@chho.imagico.de>
P Brewer wrote:
>       adaptive 1
That's a MegaPOV feature.  And the adaptive pretrace is something you
have to use with care to make it work successfully.  And in this kind of
scene it will hardly be very useful.
> ease memory usage?
That's quite impossible to tell from the settings alone.  Decreasing
error_bound and nearest_count will surely be what to start with.
Date: 23 Jun 2006 13:10:00
Message: <web.449c202080eb3ffe8af060f60@news.povray.org>
Thanks Cristoph. If my current render fails I'll try those tweaks out.
Phil
Christoph Hormann <chr### [at] gmxde> wrote:
> P Brewer wrote:
> >       adaptive 1
