POV-Ray : Newsgroups : povray.advanced-users : Radiosity flouroescent lighting troubles Server Time
22 Mar 2026 04:23:03 EDT (-0400)
  Radiosity flouroescent lighting troubles (Message 41 to 47 of 47)
Subject: Re: Radiosity flouroescent lighting troubles
Date: 29 Nov 2002 16:00:16
Message: <web.3de7d420e77700b4978071460@news.povray.org>
Rohan Bernett wrote:
>I tried these settings and the scene slowed down terribly. As I'm writing
>this, the render has been going 56min and is only on line 258.
Which sounds reasonably fast... esp. if you consider that these ones could
serve as not too bad settings for the final render.
>The lo-res
>preview and what's done so far looks pretty good, although there are some
>odd blotches near the light sources.
>I hate having to wait ages for just a test render. I think anything over 5
>minutes for an 800*600 image with no AA, is too slow.
hmm I've waited hours for 320x240 test renders (and we all know of users who
wait days for that)... what's the matter? When I build up a scene, I use a
simpler lighting setup, no radiosity (or very low settings), no reflections
etc. As soon as the final render begins, it could last days, I couldn't
care less (as long as the scene is worth it...)
>I hate slow renders.
Everybody does, but remember, first comes quality.
Jonathan
Date: 2 Dec 2002 05:11:28
Message: <3DEB3420.D7210BB1@frege.mathematik.uni-freiburg.de>
> Ahh! If you used a unit circle to do the repulsion thing then you are
> quite right - you do not get an even distribution at the edge: all the
> outermost points would be pressed against the rim.
> This is why I used a 2 radius circle when I was doing the Delaunay
> triangulation, and adding samples until I had enough in the unit circle.
> That way you get an even distribution right across the unit circle -
> right to the rim of the hemisphere.
I am uneasy about this. I fear you do not solve the problem
but only make it less visible by moving the edge farther out.
I would prefer doing the thing without any edges at all: Use
the unit square as a torus, find an even distribution there,
map it onto the unit circle via
  phi <- 2*pi*x
  r <- sqrt(y)
and then proceed as you suggested.
  Mark
Date: 3 Dec 2002 07:49:26
Message: <3deca856$1@news.povray.org>
Michael Andrews wrote:
> I suppose it could be, and I've thought about doing this. However you
> would have to calculate an array for each level of radiosity recursion
> because the code reduces the number of samples taken at each subsequent
> recursion level. And the results wouldn't be very different anyway.
I've had another think about this, and I don't think it would work in
some cases.
The code uses the apparent (texture modified) surface normal and checks
whether a particular sample can be used or is going behind the actual
surface. If the sample can not be used then it takes a fresh sample.
So you can not know a priori how many samples you need at a particular
recursion level because it may alter at each sampling point.
This is why you not only need an even sample distribution but also to
have the distribution as even as possible over the first N samples of
the distribution where N can be any number up to the maximum possible
number of samples.
And this is why I was looking at an iterative Delaunay triangulation -
to get a 'good enough' even distribution for the first N samples of the
distribution.
For something like a repulsion algorithm which sets the position of all
the sample points at once you would then need to choose the sampling
order carefully to get a good distribution for any number of points.
Enough babbling ...
Bye for now,
	Mike Andrews.
Date: 3 Dec 2002 09:58:55
Message: <3DECC6AC.A41B0178@gmx.de>
> number of samples.
Exactly, like i said in
news://news.povray.org/3DE76813.8B1CB162%40gmx.de
Yes, that's the idea how to do it.  Generate a number of point using an
arbitrary algorithm (but chosen for a uniform but non-regular
distribution) and then sort them for maximum uniformity at lower sample
counts too.  I can't think think of a different method that does not
produce a regular distribution.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 4 Dec 2002 03:55:05
Message: <web.3dedc1fbe77700b4c571aa6c0@news.povray.org>
>wait days for that)
Man is that slow!
>etc.
I don't think I can simplify my lighting setup. I only have the neccessary
number of light sources to match the locations in the real world scene. As
for no radiosity, for the flouro lights that's a no-can-do.
Only if you have a second computer to handle the slow rendering.
As for test renders, hours or days is far too long. For test renders, 10
minutes is getting too slow, I'd definatly prefer 30 second test renders.
I should probably stop grumbling and go and read a different thread now.
Rohan _e_ii
Date: 4 Dec 2002 05:35:21
Message: <afmruusgb4mglsm7ip1vg5g61qrhke121c@4ax.com>
On Wed,  4 Dec 2002 03:51:07 EST, "Rohan Bernett" <rox### [at] yahoocom>
I think you should either stick to simple scenes or use another
program :) But even in "fast" renderers like MAX, a scene with
raytraced soft shadows, reflections, radiosity and so on will not fall
within your expectations of a render time.
Peter Popov ICQ : 15002700
Date: 6 Dec 2002 20:55:03
Message: <web.3df1546fe77700b4b2769afa0@news.povray.org>
Lucky for me I'm using soft shadows, reflections and radiosity, yet.
Although by the time I get to the final render, I probably will be. That'll
probably mean a render of several days, given the ambitious complexity of
the intended final scene.
Rohan _e_ii
