POV-Ray : Newsgroups : povray.advanced-users : splines Server Time
19 Jan 2025 03:19:56 EST (-0500)
  splines (Message 1 to 9 of 9)
Subject: splines
Date: 22 Sep 2002 06:15:11
Message: <B9B355CF.4E04%fidel.viegas@artrecognition.co.uk>
Hello guys,
Is there any macro that supports hermite curves? Does povray support hermite
curves? And what are they really good for? Isn't cubic splines enough to
create any kind of smooth camera or object animation?
Thanks in advance.
Fidel.
Subject: Re: splines
Date: 22 Sep 2002 06:21:02
Message: <3D8D9AB0.23843B23@pacbell.net>
Fidel viegas wrote:
> Hello guys,
http://www.geocities.com/emory_stagmer/povherm/
Ken Tyler
Date: 22 Sep 2002 19:21:01
Message: <3d8e505d@news.povray.org>
hermite
The term "cubic" refers to the degree of the equations used to calculate the
spline path.  All the cubic splines (Bezier, Catmull-Rom, Hermite,
Kochanek-Bartels) are just different ways of specifying the inputs for the
spline, and it's not too difficult to perform conversions from one to
another.
My Spline Macro File allows you to define and use cubic splines, with a
choice of input types (including Hermite).  A POV 3.5 compatible version is
available on request, although I intend to review and revise the file to
make best use of POV 3.5's inbuilt spline functions.  You can download the
file and a tutorial from http://www.geocities.com/ccolefax
Date: 22 Sep 2002 22:39:45
Message: <B9B43C96.4E3C%fidel.viegas@artrecognition.co.uk>
> another.
Thanks for the info. I spent a while reading on that subject and just
implemented a java application that converts from one to another.
I had that on my include path, but had never used it. Anyway, as I mentioned
above, I just implemented an application that allows me to design the
splines visually with mouse clicks. I then export it to povray (I am too
lazy to be doing trial and error experiments with povray sdl until I get the
correct curve).
Thanks for all the support.
All the best
Fidel.
Date: 23 Sep 2002 22:25:37
Message: <pan.2002.09.24.02.24.44.755861.210@gte.net>
On Sun, 22 Sep 2002 19:20:02 -0400, Chris Colefax quoth:
> hermite
>> to create any kind of smooth camera or object animation?
> the spline path.  All the cubic splines (Bezier, Catmull-Rom, Hermite,
> the spline, and it's not too difficult to perform conversions from one
> to another.
There's also a "natural cubic spline" type that can't easily be converted
to/from.  POV-Ray 3.5's "natural_spline" is a natural cubic spline.  The
"cubic_spline" type is a Catmull-Rom spline.
Mark
Date: 24 Sep 2002 06:02:21
Message: <B9B5F5D1.4F12%fidel.viegas@artrecognition.co.uk>
Hi Mark,
> to/from.
There is always a way around it. I haven't looked into it yet, but I am sure
that is a way of converting it to other types of splines and vice-versa,
even though it is hard.
I haven't looked into that.
 At the moment I am only using Hermite, Bezier and B-Splines. I'll look into
the others later. Mostly I use Bezier for almost everything, but I wanted to
learn how they work internally.
Once again, thanks very much.
Fidel.
Date: 24 Sep 2002 16:34:20
Message: <3d90cc4c$1@news.povray.org>
Would you be willing to share you program? Sounds like it might be very
useful.
Best,
D
"Fidel viegas" <fid### [at] artrecognitioncouk> wrote in message
news:B9B5F5D1.4F12%fid### [at] artrecognitioncouk...
> Hi Mark,
converted
> > to/from.
sure
into
to
> Fidel.
Date: 24 Sep 2002 18:02:37
Message: <B9B69EA0.4F72%fidel.viegas@artrecognition.co.uk>
in article 3d90cc4c$1@news.povray.org, Dennis Miller at dhm### [at] attbicom
wrote on 24/9/02 9:32 pm:
> useful.
Hi Dennis, I will share the program when I finish it. I built it
intentionally to study splines and to generate povray code for me. That way
I can design the splines visually and export it as a prism or as a lathe. At
the moment, it isn't something special. So, I decided to write a real
application and I plan to extend it further and add bicubic patches as well.
But, I am learning the internals of curves and surfaces so that I can  take
it further.
I was thinking something similar to sPatch. Since I now use Mac mostly, I
can't use sPatch. So, I just write special purpose tools to aid my
understanding of povray internals visually.
As soon as I release it, I will alert the pov community since this
application will be specifically for povray.
Anyway, all the best
Fidel.
Date: 25 Sep 2002 15:57:38
Message: <3d921532$1@news.povray.org>
Good luck with your work. Sounds very interesting!
d.
news:B9B69EA0.4F72%fid### [at] artrecognitioncouk...
> > useful.
way
At
well.
take
> it further.
> Fidel.
