POV-Ray : Newsgroups : moray.win : does MORAY export this correctly yet?? Server Time
28 Sep 2024 11:19:23 EDT (-0400)
  does MORAY export this correctly yet?? (Message 1 to 10 of 24)
Subject: does MORAY export this correctly yet??
Date: 7 Mar 1999 18:19:04
Message: <36E30A5D.7E2A7D31@europa.com>
When attaching a light to an object, moray extrapolates the position and
then places the light with the others in the front of the script.  Does
the latest build of moray STILL do this??  It's annoying when you want
to animate something and the transformations get complex because of
CSG's parenting all the down to "great grandchildren."
I want the light to be *included* in the object declaration JUST as I
have placed it in the modeller- I want it actually attached!  grrrrr....
Sorry if I sound angry but I spent about two hours last night trying to
figure out what the h$%^ was going on in an animation involving 750
objects (300 of them in one csg thingy that I don't even want to
contemplate anymore).
At any rate- hand attaching it isn't a problem except that the file is
thousands of lines long and I need to generate hundreds of these things
and yes, *I'M LAZY!*.
So... Lutz, how about it?  What does the latest windows build do and/or
can you make this an option or a fix?
Stuff for POLYRAY, some raytraced images, and
DTA can be found at:
http://www.europa.ccom/~dearmad
Subject: Re: does MORAY export this correctly yet??
Date: 7 Mar 1999 22:25:45
Message: <36E342FE.D8753097@mninter.net>
Dearmad wrote:
*SNIP*
Lazy? Lazy? Just the thought of doing this stuff makes the sweat break out
on my brow.
Only I can prevent narcissism!
Date: 8 Mar 1999 07:29:28
Message: <36e3c2a8.0@news.povray.org>
Alex Magidow schrieb in Nachricht <36E342FE.D8753097@mninter.net>...
>on my brow.
And modellers were made to make this kind of stuff unnnecessary, otherwise
we could just as well hand code everything, not using Moray at all <g>.
Rudy Velthuis
Date: 8 Mar 1999 08:31:30
Message: <36E3D079.BA21A4BE@pacbell.net>
> >on my brow.
> Rudy Velthuis
  You mean to tell me that Moray is a modelling program and not just a
friendly guy that helps everybody with their scenes ? I think I missed
that connection somewhere along the line. I always thought that hand
coding was the only option available. Gee !
Ken Tyler
mailto://tylereng@pacbell.net
Date: 8 Mar 1999 14:58:43
Message: <36e42bf3.0@news.povray.org>
Ken schrieb in Nachricht <36E3D079.BA21A4BE@pacbell.net>...
things
out
>> >on my brow.
otherwise
>> Rudy Velthuis
Dunno exactly how to answer this.
What I was trying to say, you don't have to be *lazy* to expect a modeller
to output exactly what you (tried) to input. I think a modeller like Moray
should really keep the light sources in the group, if you can group them
anyway. What's the use of grouping otherwise? So it should either not allow
to group them in, or really keep them there.
But then perhaps I just didn't understand your answer. :-)
BTW Moray is also a kind of fish, afaik.
Date: 8 Mar 1999 15:53:33
Message: <36e43881.523622@news.stmuc.com>
Hi Dearmad, you recently wrote in moray.win:
The current build still extracts the lights to the beginning of the
script. The reason is partly historic (the raytracer I started writing
Moray for needed them seperate from the objects) and partly because
POV-Ray doesn't handle spotlight in non-uniform scaled groups
correctly and it was too much of a headache to account for this with
the wireframe. I realize that not many people will run into this
problem, so I will see if I can leave the lights in the CSG in the
next release (hopefully this year).
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 8 Mar 1999 23:33:25
Message: <36E4A45C.28B04120@mninter.net>
Hey, sorry, I was just expressing respect for a very nice member of the POV-Ray
community. I, personally, upon running into a problem of similar complexity,
given up pretty quickly, and not persevered quite as much as Dearmad did. I give
him my complete respect, and I also give Moray my complete respect.
 Actually, an eel...or a social no-no....
Subject: sorta long explanation... (was my MORAY/LAZY topic)
Date: 8 Mar 1999 23:42:52
Message: <36E4A7C7.C90418B9@europa.com>
You know... I can never start a thread when I want to... and now... :o)
Seriously, Lutz puts out a dman fine program- it's just that he's the
unwitting victim of me using MORAY as a keyframe generator for my
Tweener program, which needs to parse the scripted output (as I have no
access to the .MDL format) and so I NEED, I say I *NEED* to have
CONSISTENCY (sp) in the data so my Tweener program knows where to grab
digits from and how to place them in the heirarchy.  I just noticed that
a light wasn't tracking correctly in a little scene I made and then I
realized *why*.  I have yet to attach anything to the *camera* heaven
forbid and won't bother doing that! ;o)
I've been able to program around a LOT of the little oddities MORAY does
when it outputs scriptfiles but this one was too much for me to think of
a way to let my program figure out where to replace the light so it
tracked correctly in a particularly nasty CSG set that goes about 7
levels deep (due to joint needing to bend a certain way).
-er-  my only little point here is that my "Lazy" paragraph was more a
bow or a nod to Lutz' hard work.  From my perspective as an amateur
programmer I can only imagine the details Lutz must go through for moray
and I wanted him to realize that I wasn't coming across as a whiney
user- I've reg'ed v2.02 DOS and am "upgrading" to v2.5 in a bit, so I'm
behind the times with MORAY anyway!  :o)
-Peter
Date: 8 Mar 1999 23:44:54
Message: <36E4A841.7769E9BE@europa.com>
hehe... and after that version has been out for a year or so I'll get
around to using it... I'm just about ready to upgrade my v2.02 to 2.5
here soon... ;o)
thanks a ton for all the other stuff you're doin'.
> - Lutz
Subject: Re: sorta long explanation... (was my MORAY/LAZY topic)
Date: 9 Mar 1999 06:46:35
Message: <36e50308.901516@news.stmuc.com>
Thanks for the kind words. Much appreciated.
Yes, and there is no way round it, because the information just where
that light is located in the object hierarchy is not exported.
Now if you were using the plugin interface added in Moray V3.1 you'd
be able to completely integrate Tweener into Moray......<g>
- Lutz
