POV-Ray : Newsgroups : povray.off-topic : Win7 woes... Server Time
12 Oct 2024 21:13:58 EDT (-0400)
  Win7 woes... (Message 1 to 10 of 17)
Subject: Win7 woes...
Date: 23 Jun 2010 15:25:23
Message: <4c225fa3$1@news.povray.org>
I recently got Win7 and am now using it as my primary OS. It's certainly
flashy, but the sluggishness of the UI is really getting me down.
When opening new windows (especially File Manager) there's a much too
noticeable delay as different portions of the window get filled. First
I'll see the outer edge of the window, then the different panels fill
in, then the panels get populated with objects. The navigation pane is
especially painful, as it needs to display the new folder libraries,
homegroup, favorites, etc. It happens pretty frequently that I'll try
and click on an item, and in the interim in which I try to point the
mouse at it the position of the item changes because new stuff got
filled in. The "Open File" and "Save File" dialogs and the new grouped
taskbar items suffer from the same problem.
Maybe my PC is too weak (2.4GHz single core Celeron with 3GB RAM), but
I'm starting to really regret switching from XP.
http://isometricland.com
Subject: Re: Win7 woes...
Date: 23 Jun 2010 17:28:06
Message: <4c227c66$1@news.povray.org>
At work, I run Win7 *in a VM* and don't notice much speed difference.
(The install took *years*, however.) I'm running on a 2.0 GHz Core2 Duo
with 2GB RAM. (Only 1GB is actually assigned to the VM, and only a
single core.) So I'm guessing your PC is too weak. (Or, more accurately,
Win7 is too inefficient.)
http://blog.orphi.me.uk/
Date: 23 Jun 2010 17:35:21
Message: <4c227e19$1@news.povray.org>
I find that usually windows seems sluggish when there is either heavy disk
activity or something running at a normal priority and taking up a bunch of
CPU time that you don't notice. (Moreso the former.)
If you just installed Win7 within a day or two, you might be feeling the
pain of it trying to index the entire hard drive for searching, or some such.
When you open the resource manager, do you see something running that takes
up a lot of time?
I had some driver problems with Vista (the hard drive virtual raid bit
interfering with the sound card or something weird) that had a system task
repeatedly crashing and then starting up at full bore over and over. If you
have a pre-install, it might be conflicting drivers or something.
In any case, open up the resource manager (which you can get to from the
task manager in Vista) and see what's making it slow - disk or CPU or memory
swapping or what.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 23 Jun 2010 23:27:34
Message: <4c22d0a6$1@news.povray.org>
> disk activity or something running at a normal priority and taking up a
> bunch of CPU time that you don't notice. (Moreso the former.)
> such.
It's been a bit over two months. I've got all my favorite apps
installed. Most everything is set up like it was on XP.
> takes up a lot of time?
I use a combination of Process Explorer and Process Lasso to control
process priorities. Running at idle the CPU usually stays under 5%
utilization. It will start sputtering when my antivirus wants to update.
Also, I messed up Thunderbird somehow so that now it always wants 15-20%
for no reason, so I don't leave it running anymore like it was. Will
have to try and reinstall that...
> task repeatedly crashing and then starting up at full bore over and
> over. If you have a pre-install, it might be conflicting drivers or
> something.
> memory swapping or what.
I will try and take a screenshot after a fresh reboot. I don't
understand the values enough to interpret them myself.
Date: 23 Jun 2010 23:30:48
Message: <4c22d168$1@news.povray.org>
Will a better video card help? I bought the cheapest video card I could
find, an nVidia GeForce 210. Better than the onboard video.
Date: 24 Jun 2010 00:33:43
Message: <4c22e027$1@news.povray.org>
Well, it should be pretty straightforward. There's either something eating
up a lot of CPU, or something eating up a lot of disk. If neither the CPU
nor disk is busy and your machine is still slow enough to watch it repaint,
then there's something you probably need more expertise to analyze. Probably
looking in the event logs would be one step. (Altho I heard something about
Win7 doing away with those or something absurd like that.)
If the disk is busy, sort it by read bytes per minute then write bytes per
minute and see if you can tell what file is busy or what process is doing
the disk thrashing.
If it's the CPU, sort the list by CPU utilization and see if you recognise
the name of the process.
If you don't recognise what's going on, post the names of the files and/or
processes and I'll see if I can guess for you.
Date: 24 Jun 2010 00:36:54
Message: <4c22e0e6$1@news.povray.org>
Oh, and also look at how much memory is used up. I don't know about Win7,
but on Vista, the "resource monitor" is pretty good for naive analysis of
performance problems.
Does Win7 have the whole "welcome center" bit with the "system performance"
measurement? That might point out where the problems are too. Maybe if your
graphics card doesn't support 3D graphics and you're still telling the
system to do that anyway, it could be a problem. Try switching the theme to
an older theme (Areo Basic or Classic or something) and see if it's still
slow. If not, you've found the problem.
And again, this is all based on Vista info. I don't know if the same things
are in the same places on Win7.
Date: 24 Jun 2010 02:45:14
Message: <4c22fefa$1@news.povray.org>
I bet it will. The problems you're describing sound almost like you
don't have hardware acceleration.
Try this and see if it makes anything better: Right click on desktop,
personalize, scroll down to "basic and high contrast themes" and choose
"windows 7 basic." This turns off a lot of flashy features like
transparency on the window borders.
If that partly helps but not all the way, I would definitely try a
better video card.
  - Slime
Date: 24 Jun 2010 04:14:57
Message: <4c231401$1@news.povray.org>
> such.
Isn't this fun?
By the way, for reasons beyond my comprehension, OpenSUSE comes with a
cron job set up to periodically reindex all the manpages. (WTF? WHY??)
And of course the automatic updates which I've repeatedly turned off and
yet they still run... Trying to run this thing in a VM is so frustrating!
Date: 24 Jun 2010 12:05:00
Message: <web.4c2381af1a21a33c3771cd8e0@news.povray.org>
> better video card.
>   - Slime
I'm running Win7 64bit on a Athlon64 X2 4000+ with a Geforce 6600 (256MB) with
Aero active and it's not really sluggish, so the Geforce 210 should be more than
sufficient to handle Aero.
You might have a resource hungry virus scanner for example.
Disconnect your PC from the Network and disable the Antivir. If this speeds
things up you should look for a smarter Antivir.
Regards
Aydan
