POV-Ray : Newsgroups : povray.off-topic : Emacs Server Time
14 Oct 2024 19:20:42 EDT (-0400)
  Emacs (Message 1 to 10 of 349)
Subject: Emacs
Date: 14 Apr 2009 06:40:56
Message: <49e46838$1@news.povray.org>
OK, so somebody had to ask...
What is it, exactly, that makes Emacs so fantastic? What does it
actually *do* beyond being a text editor?
(I mean, aside from the obvious fact that "Emacs" is actually just a
Lisp interpretter that defaults to running a text editor application
written in Lisp...)
Presumably there is a way of making Emacs read the content of a text
file, use the various keys on the keyboard to edit that text, and save
the result. But hey, Notepad can do that too! So what is it that Emacs
does that's so awesom? What can it do that Notepad can't?
Subject: Re: Emacs
Date: 14 Apr 2009 08:00:53
Message: <49e47af5@news.povray.org>
> written in Lisp...)
Customizable
Extensible/Programmable
Ported to many platforms
Internationalization
Runs in both text terminals and GUI environments
Many editing modes
Self documenting with built in tutorial
Detailed and well written manulas
Free and open source
AFAIK notepad is/has none of the above.
Try it for a while - and I bet you won't regret it.
Tor Olav
http://subcube.com
Subject: Re: Emacs
Date: 14 Apr 2009 08:28:07
Message: <49e48157$1@news.povray.org>
My editor of choice is currently SciTE, so let's see how it compares
against this checklist...
> Customizable
Check. (If only it didn't take so damned long to configure each time you
install it...)
Well, not so much. You can reprogram the syntax hilighting to handle
some unknown language if it matches a known one closely enough. And you
can program it to run external commands for you (e.g., compile my
program, run this through LaTeX, open XDVI...)
SciTE runs on both Windows and Linux, and that's all I need.
Not important to me.
Could be useful...
> Many editing modes
...and?
> Detailed and well written manuals
Nice, but secondary. It's good to know a tool is easy to learn, but the
question is whether it's *worth* learning in the first place.
As is SciTE.
Agreed. Notepad fails in many, many basic ways. But SciTE is quite nice
in general.
On the other hand, nobody rants on about how amazing SciTE is, but Emacs
is considered the One True Editor. I'm just trying to figure out why -
and if it's worth trying to use it.
Well, I don't know. IIRC, last time I tried to use it, I had to reboot
the computer to exit it.
(Of course, had I known about virtual terminals back then, I could have
just killed it from another vterm... Presumably on Windows it would be
even simpler.)
Subject: Re: Emacs
Date: 14 Apr 2009 08:40:18
Message: <49e48432$1@news.povray.org>
Mine is TextPad, suits the job nicely for me, I especially like the tabbed
browsing through documents similar to a lot of modern software.
http://www.textpad.com/products/textpad/features.html
I've not heard this anywhere, every time I've heard emacs mentioned it is
usually in a bad way.  Even my 2 friends at Universtiy who were totally into
Linux stuff laughed when we were told to use emacs in one of our practical
lessons, and proceeded to use something else (I forget what).
Subject: Re: Emacs
Date: 14 Apr 2009 09:15:01
Message: <web.49e48c14be8f6db963a1b7c30@news.povray.org>
I'm into vi myself, so I'll take your question to mean, "Why would you need
something other than Notepad anyway?"  Really?  I mean, really?  No, seriously?
 Are you referring to something like Notepad++ or just Notepad?  If you know a
good editor well, you can work about as fast as you can think.  Based on my
experience, I'd compare it to the difference between Dvorak typing and the
two-finger method.
http://www.gnu.org/software/emacs/manual/html_node/emacs/index.html
http://vimdoc.sourceforge.net/htmldoc/usr_toc.html
 - Ricky
Subject: Re: Emacs
Date: 14 Apr 2009 09:22:41
Message: <49e48e21$1@news.povray.org>
Well, I actually use SciTE myself - but nobody has ever heard of that.
Yes, Notepad sucks. Massively. It fails at the most basic tasks. Then
again, if all you need to do is quickly edit some INI file somewhere,
Notepad can usually manage that, and it's always available. If you want
to do anything more, get a real editor.
> If you know a good editor well, you can work about as fast as you can think.
I'm just curios to know what makes people think that Emacs (or Vi for
that matter) is a good editor. I mean, SciTE has configurability, syntax
hilighting and the ability to invoke external commands, but nobody
thinks it's a good text editor. So what do Emacs and Vi have that SciTE
doesn't?
Subject: Re: Emacs
Date: 14 Apr 2009 09:38:45
Message: <49e491e5$1@news.povray.org>
I avoid Notepad like the black plague. I use Notepad2, which is also
scintilla-based, free, and has basic syntax highlighting.
Strangely, I like the SDI interface it provides. It's lightweight, but
at the same time much more powerful than notepad.
> doesn't?
I tried Emacs under Windows once. I gave up on it. Vi is something I'd
rather forget.
~Mike
Subject: Re: Emacs
Date: 14 Apr 2009 09:47:44
Message: <49e49400$1@news.povray.org>
>> want to do anything more, get a real editor.
Like I said, you can edit text with it, and every Windows PC has it
installed. That's all it has going for it. If you want to do more than
quickly edit one line of text, get a real editor.
I use SciTE, which is also Scintilla-based and does syntax hilighting.
(And XML tag completion, if you can remember how to enable it...)
Also, you can use it without having to "install" anything. Just
download, unzip, and go. (Well... spend 3 days customising and *then* go.)
> rather forget.
A glowing recommendation if ever I saw one...
Subject: Re: Emacs
Date: 14 Apr 2009 09:55:00
Message: <web.49e494b0be8f6db963a1b7c30@news.povray.org>
Thanks for clarifying.  You're right that I've never heard of it, but my basic
answer would then be: If you think there's enough room for improvement in what
you currently use, or you're not sure what the hype is about, learn it.  Don't
just give it the old college try and give up though; give it a week or two and
see.  That sounds easy enough to say, so to be fair, I'm officially going
cold-turkey on vi.  The only vi command the guy I work for knows is ":q!", and
the only Emacs command I know is C-x C-c.  It makes for endless frustration.
It's Emacs or nothing from here on in.
 - Ricky
Subject: Re: Emacs
Date: 14 Apr 2009 09:55:01
Message: <web.49e49563be8f6db963a1b7c30@news.povray.org>
> rather forget.
Don't worry.  I won't evangelize, but the word 'once' is clearly the problem, as
in, "I tried running once, but I didn't win, so I gave up."
 - Ricky
