POV-Ray : Newsgroups : povray.off-topic : XBOX fun (or trying not to take a hammer to my router...) Server Time
1 Mar 2026 07:48:25 EST (-0500)
  XBOX fun (or trying not to take a hammer to my router...) (Message 1 to 10 of 15)
Subject: XBOX fun (or trying not to take a hammer to my router...)
Date: 4 Nov 2008 19:09:42
Message: <4910e446$1@news.povray.org>
OK... Anyone here have an XBOX 360 and a Linksys WRT150N router, and can
tell me why the hell if fails to connect in the test phase for getting
an IP?
Note, its using WEP, not WEP2, so that's not the issue. Filtering of MAC
is on, but that isn't the issue, since the only MAC in the filter is not
the one for the XBOX. I even tried setting a static IP, and even
assigning that IP as the "default" IP for that MAC address (umm, does
the name for the computer/device need to be the same, since the XBOX
doesn't seem to ID itself and setting a default IP for the mac requires
the name too... But, the same error happened when simply setting the
address in the XBOX, *and* when leaving it on "automatic".
I get the sense this is a common, and unbelievably stupid, problem with
the 360 and wireless, from the net, but the "solutions" are things I
have either already tried, am not 100% sure how to do right, or would
have an effect (I mean, what the hell would setting it DMZ matter if it
isn't getting a fracking IP in the first place?). Or, just unbelievably
stupid, like opening my network up, including disabling encryption,
which would let any idiot that drove by have access to a network with
two other computers on it, one on 24/7...
Apparently, this problem also, often, doesn't happen with people
connecting computers via wifi, just the damn 360... I have run out of
ideas at this point, and I would hate to think I just wasted $100 on
something that won't connect me..
Note: If all else failed I could try a hard line, but that runs into two
doors. I.e., where the XBOX is, and the router, its a ceiling fan, the
door out of the room, and the door of the closet. Kind of
"inconvenient", even if I didn't just lose $100 on something that won't
work. lol
Thanks.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: XBOX fun (or trying not to take a hammer to my router...)
Date: 4 Nov 2008 21:02:10
Message: <4910fea2$1@news.povray.org>
> an IP?
I just spent 3 hours running a hardwire under the carpet to mine, so I
have to assume you're talking wireless. :-)
My guess is that's the issue, depending on how you have the filter set.
If there's only one MAC address, I'm assuming it's an "allow" filter,
and you're not allowing the XBox's MAC address?
Try turning off the MAC filter to start with.
Depends on whether you're relying on your router or the ISP to serve the
DHCP?
Don't you have return policies there? :-)
> Kind of "inconvenient",
Tell me about it. My hips still ache. 30+ feet of fishtape under the
carpet. :-)
Date: 5 Nov 2008 02:46:51
Message: <49114f6b@news.povray.org>
As Darren hinted to, I would first turn off all encryption and MAC filtering
and any other special features on the router and see if you can get it to
work.  You could even try a reset of router to reset any settings that might
have been changed from the defaults.  Hopefully it will work then, and you
can gradually enable the security features and see which one messes it up.
Date: 5 Nov 2008 13:51:59
Message: <4911eb4f@news.povray.org>
>> can tell me why the hell if fails to connect in the test phase for
>> getting an IP?
>> MAC is on, but that isn't the issue, since the only MAC in the filter
>> is not the one for the XBOX.
Its in the "don't allow" filter, since someone logged in the first day I
had the thing up, and I wanted to keep them out while trying to work out
  how the encryption worked. I tried shutting it off, and it didn't do
anything, but I suppose I could try again. But, wouldn't that reject it
entirely? It does connect, it just isn't being given an IP.
>> (I mean, what the hell would setting it DMZ matter if it isn't getting
> DHCP?
Hmm. Interesting point. I think I have a permanent IP, but I am not
sure, but the router *is* using the ISP to get the DHCP. Still, this
makes no sense, since the router's own IPs not "static", they get issued
to anything trying to connect to them on an "as needed" basis. I had to
manually "reserve" two for my two networked PCs, so that any wireless
system couldn't "steal" the IP and screw up stuff like the EverQuest
emulation server, which uses a "static" IP for connecting (it won't
allow anyone to connect unless they come from the same IP they last
connected from).
Again, since its my router that need to be giving out the IP for **its**
network... I don't get why the heck the thing would be complaining it
can't get one, or the router won't provide one. Still, can look to see
if I can DMZ by MAC address...
You kidding? This is Wallmart. Most of the time the policy is, "You
opened it, you can't bring it back!" Mind, this may not be the case
here, but still, would rather fix the problem, if possible.
> carpet. :-)
Gah.. Not going to go that far, just run it "around" the doors, if I
have to. But, what a damn pain. Can't help but think that MS just fucked
the design of the XBOX software here, and the problem is some insanely
stupid setting, which normally no one ever changes... :p
void main () {
   else
Date: 5 Nov 2008 13:54:12
Message: <4911ebd4$1@news.povray.org>
> filtering and any other special features on the router and see if you
> can get it to work.  You could even try a reset of router to reset any
> settings that might have been changed from the defaults.  Hopefully it
> will work then, and you can gradually enable the security features and
Gah.. All I need, an open network with two other machines already on it,
for how ever long it takes for me to figure out that the frell the
problem is.. Note, it **can't be** the security though, since I already
got "past" that part. If it was, then it would have failed, as it was
initially doing, at step 2, not step 3. Its almost certainly something
else, some place. :p
void main () {
   else
Date: 5 Nov 2008 14:46:20
Message: <4911f80c$1@news.povray.org>
OK. Nevermind then.
I'm not sure how "connected" you are. :-)
> connected from).
OK. You're probably good there then.
> network...
Yeah.
> can't get one,
I don't know. I'm kinda stumped too. Google for "xbox" and the model
number of your router?
There are actually things in the Windows DHCP packet (in the "reserved
for proprietary use" fields) that Windows requires that others don't,
and maybe your router isn't providing them? Can you get dynamic IPs on
your other windows machines?
Really? I've never had a problem returning stuff to wal-mart. I suspect
I could bring back a half-eaten box of ice-cream and get my money back.
> have to.
Check out your fry's to find wiring that's flat and will stick to the
walls. It looks way nicer. They might or might not have it there.
Alternately, what I did (for one length of speaker wire) was go to the
hardware store and buy a roll of the stuff you use to recauck your
bathtub. It's a strip of white plastic with a crease in the middle and
glue on the underside. You can cover any wiring with it and it'll likely
look better.  Assuming your walls are close to white, that is.
Date: 5 Nov 2008 14:47:56
Message: <4911f86c$1@news.povray.org>
Remember to save the config in a file first, tho. Makes it much easier
to put back. :-)
You're doing NAT, right? That gets rid of 90% of your attack vectors.
So turn off those two machines for the 10 minutes it takes to figure out
if your XBox connects. You're not running Amazon there. :-)
Date: 5 Nov 2008 21:48:04
Message: <49125ae4@news.povray.org>
>> I don't get why the heck the thing would be complaining it can't get one,
Yeah. Think I tried that before, but maybe not. The info online seems
damn useless, and mostly amounts to "reset everything back to defaults,
and if that doesn't work, either hardline it, or buy one that does
work", which I suppose is useful for some moron that has more money than
brains.. lol
Yep. It was set up to assign them automatically *every time* they
powered on and made a request. I reserved addresses for them, so that if
one was "offline" and I connected a wireless, it wouldn't assign the IP
for that machine to the wireless and mess up the values. Note, I did try
to set a "reserved" address for the MAC of the XBOX, but it demands a
"device name" or some such, which computers have, but which is
"unassigned" in the XBOX, as near as I can tell, or.. at least it
doesn't show one when looking at the data for the wireless clients while
its partly connected (but not yet with an IP). It does get far enough
that it "shows" as a wireless client in the router though, so..
somethings just going screwy after the it starts talking.
Hmm. Maybe was thinking of someone else I got guff from.. K-Mart, I
think. Brought a movie back that wouldn't play right (stupid default
audio channel was all screwed up and only the music came through) and
got the whole, "Well, we can't give you your money back, you just have
to buy a movie with the same value to replace it", BS.
>> have to.
Think I have some black... Hmm, no, actually I think I got rid of it,
and I am not sure it was CAT5E complaint anyway. Also, the closest on of
those is several thousand miles from here. :(
Huh, interesting idea.
void main () {
   else
Date: 5 Nov 2008 21:49:41
Message: <49125b45$1@news.povray.org>
> to put back. :-)
Yeah, its on NAT. And, can't turn off the machines. The one is usually
"off", and the other one is the one I need live to be able to change
settings in the router, which makes turning it off, a bit...
problematic. lol
void main () {
   else
Date: 6 Nov 2008 00:56:43
Message: <4912871b$1@news.povray.org>
I wish I could get my router to do that, but it isn't enough of a PITA
to buy a new one. :-)
What demands the device name? The router, or the xbox?
> think.
Yes. That's why they got replaced by Wal-mart, amongst other reasons. :-)
Whichever big store you have there. :-)
Inspired by running across the stuff while looking for the tools to hang
it up right. :-)
