POV-Ray : Newsgroups : povray.newusers : stbenge Fastprox fast SSS Server Time
5 Apr 2026 08:14:21 EDT (-0400)
  stbenge Fastprox fast SSS (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: stbenge Fastprox fast SSS
Date: 25 Aug 2009 18:25:00
Message: <web.4a9462586629da5ee0503b6a0@news.povray.org>
stbenge <not### [at] hotmailcom> wrote:
> stbenge wrote:
> > Mr wrote:
> >> I am trying to use Fast SSS 2 from Stbenge macro but can't manage to
> >> get an
> >> ordinary finish with it. any specularity seems to cover up the effect.
> Here's a simpler version:
> object{obj
>   texture{
>    pigment{
> fastSSS2(obj,lpos*100000,min_extent(obj)-0.5,max_extent(obj)+0.5,<1,1,1>*8,3,20)
>     colour_map{[0 rgb 0][1 rgb<1,.25,.5>]}
>    finish{phong 1 phong_size 200 reflection{.002,1 falloff 2} ambient .5
> diffuse 0}
> I hope that indentation turns out all right.
> Sam
Thanks a lot for your support. Before I dive straight into editing my shader in
PovWin, I also would like to ask if you think there may be a solution to this:
The exporter I'm using (Bend2pov) doesn't allow me to call
for the object that is declared automatically. I can append texture blocks to it
or anything inside the object block or even in the globals I can declare stuff.
But the real object, a blender model, (So there's no point in completely
writing it down as a mesh2 myself...) That object, said I, to which I want to
apply the macro can't be called inside any of these blocks as if it was written
after the call is parsed. I tried declaring a dummy object with the same name,
but it doesn't get overridden by anything automatically generated maybe the
#local directive can be used for something like that? Or Is Even this call to
obj really necessary? Any clue can help as I'm a PovNoob
Date: 25 Aug 2009 19:00:00
Message: <web.4a946bfd6629da5ee0503b6a0@news.povray.org>
Don't bother actually, I just found the way to do exactly what I wanted with the
exporter, This app combination could become a killer.
(Big joy now!)
For those who would want to try it, I just had to declare the lpos and light in
the Init text file. Then anything referring to the object I put in the PovMat
text file which is appended late enough in the pov files to be able to call for
it after it has automatically been declared.
Is it true That if I directly include the macro inside my scene instead of
including and calling for it wherever it is, it will render faster...?
Date: 25 Aug 2009 21:21:24
Message: <4a948e14@news.povray.org>
> (Big joy now!)
I'm glad you got it working!
What version are you using? It used to be true. This problem seems to
have been fixed in the newer 3.7 beta releases.
Sam
Date: 25 Aug 2009 21:39:13
Message: <4a949241@news.povray.org>
>> instead of
It is generally the case that macros defined in an external file parse
slower than macros copied to the file in which they are invoked.
Or, to be more precise, the /invocation/ of a macro defined in a
different file adds some constant overhead per invocation.
If you invoke just a single big externally-defined macro once, not much
time is lost.
If you invoke a small externally-defined macro hundred thousands of
times for some reason, it really bogs down parsing, even in 3.7. Maybe
the overhead has been reduced, but it's still there.
Date: 25 Aug 2009 21:48:32
Message: <4a949470$1@news.povray.org>
It depends.
If you use a big macro only one or two times, the overhead is negligible.
Keep in in it's include file.
If you use a small macro many thousands of times, then the overhead of
accessing the include will get huge.
Copy the macro into the file where it's used.
Date: 25 Aug 2009 22:11:47
Message: <4a9499e3@news.povray.org>
clipka wrote:
>>> instead of
> time is lost.
Ah, that's good to know, thanks.
Date: 27 Aug 2009 08:35:01
Message: <web.4a967d206629da5ef57a37420@news.povray.org>
> stbenge wrote:
> >> get an
> object{obj
>   texture{
>    pigment{
> diffuse 0}
> Sam
Do I need the pigment_pattern?
I would like to layer this over something else but it generates an error.
Date: 27 Aug 2009 13:35:00
Message: <web.4a96c36c6629da5e356795ba0@news.povray.org>
Clipka explained to me that pigment patterns should'nt be a problem. Thanks
Date: 1 Sep 2009 14:45:01
Message: <web.4a9d6ade6629da5e88154c6f0@news.povray.org>
Here is what I have so far with the skin shader I'm trying to do... not much :(
maurice.raybaud.eu/images/stories/FastSSSradFlicker.avi
I used FastSSS2 macro to get render times below 6 minutes per frame (I was
aiming for below 3 But it's still faster than true SSS.
The problem is I had to use radiosity So now I wonder if the flickering I get on
the backlit side is because of fastprox or because of radiosity.
Here are my settings,
- for FastSSS:
#declare thisSSS=
pigment{pigment_pattern{fastSSS2(OBSuz,lpos,min_extent(OBSuz)-0.5,max_extent(OBSuz)+0.5,<1,1,1>*24,2,11)
cubic_wave}}
texture{
 pigment_pattern{thisSSS}
 texture_map{
  [0
  pigment{rgb <0.73, 0.25, 0.145>}
  finish{
   diffuse 0.8, 0.7
   ambient 0
   //phong 0.35
   //phong_size 1
   brilliance 4
   specular 0.1
  [1
  pigment{rgb<0.83, 0.45, 0.225>}
  finish{
   diffuse 0.8, 0.5
   ambient 0.2
   //phong 0.35
   //phong_size 1
   brilliance 4
   specular 0.2
- And the parameters for radiosity:
      pretrace_start 0.08
      pretrace_end   0.08
      count 22
      nearest_count 8
      error_bound 2
      recursion_limit 1
      low_error_factor 0.3
      gray_threshold 0
      minimum_reuse 0.05
      brightness 1.0
      adc_bailout 0.01/2
 always_sample off
Date: 2 Sep 2009 01:39:40
Message: <4a9e051c$1@news.povray.org>
Unless you make use of POV-Ray's mechanisms for storing and re-loading
of radiosity samples, some deal of flicker is virtually inevitable with
radiosity - the lower-quality the settings, the worse.
(Of course it doesn't help that if your scene contains any moving
objects, you'd theoretically need to recompute radiosity for every frame
anyway.)
