POV-Ray : Newsgroups : povray.newusers : Setting the aspect ratio Server Time
20 Dec 2025 06:15:59 EST (-0500)
  Setting the aspect ratio (Message 1 to 9 of 9)
Subject: Setting the aspect ratio
Date: 8 Dec 2006 16:10:00
Message: <web.4579d374c1135f40e21d8a9b0@news.povray.org>
My problem is that my rendering outputs are distorted when I don't choose a
4:3 resolution like 800x600.
Now I know from the online help and from articles here that something like
this is supposed to work:
right x*(aspect ratio)
Unfortunately, it doesn't. In fact, that line doesn't have any effect at
all. May I be using another keyword that negates the effect or something?
May it have something to do with the fact that I'm working with a scene (and
a camera) which was converted over from a 3ds file with 3DWin5?
Here's my camera definition:
#declare P_cam = camera
  sky <0, 0, 1>                       // doesn't seem to have any effect
  up <0, 1, 0>                        // same
  right <1, 0, 0>                     // same. If I use 1 or 1.33 or 2 or
                                      // anything, always the same result
  location <22.695, -65.187, 31.461>
  look_at <-4.677, -4.445, 10.517>
  angle 45                            // I've read this can override "right"
                                      // settings, but I see no difference
                                      // if I leave it out
Thanks in advance.
Subject: Re: Setting the aspect ratio
Date: 8 Dec 2006 16:31:04
Message: <4579d998$1@news.povray.org>
Ansgar nous apporta ses lumieres en ce 08/12/2006 16:07:
The default is <0,1,0>
This and the previous are used to tilt the camera.
>   right <1, 0, 0>
Should be perpendicular to the "up" vector. Non-perpendicular leads to skewed image.
Those 3 should apears AFTER location, look_at and direction
This should be the first camera item.
Not the "right" vector but the "direction" vector.
> Thanks in advance.
Try this instead:
camera{location<22.695, -65.187, 31.461>
	direction z //not needed, default value
// this can be used instead of angle to change the field of view.
	look_at<-4.677, -4.445, 10.517>
	right x*1
	angle 45
If you have one lawyer in town, he goes hungry.
If you have two lawyers in town, they both get rich.
Date: 8 Dec 2006 16:35:00
Message: <web.4579d96753a4c05ec150d4c10@news.povray.org>
> Thanks in advance.
  up y
-tgq
Date: 8 Dec 2006 17:25:00
Message: <web.4579e54b53a4c05ee21d8a9b0@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
>   up y
> -tgq
I know that. The problem is it doesn't work.
Alain <ele### [at] netscapenet> wrote:
> Try this instead:
>  right x*1
>  angle 45
> Alain
Hmmm, I get a funny tilted picture that way, but at least the aspect seems
right now... strange, I think it is because I declared the camera as
#declare P_cam = camera{...
and used it later via
camera{P_cam}
When I just write camera{... like you, it seems to have a different effect.
That shouldn't be, should it?
Date: 9 Dec 2006 00:44:55
Message: <457a4d57@news.povray.org>
  That may be tempting, but not recommended:
http://tag.povray.org/povQandT/languageQandT.html#aspectratio
Date: 9 Dec 2006 00:52:15
Message: <457a4f0f@news.povray.org>
  An actual scene demonstrating the problem would have been helpful.
  I crated one and see no problem. The 'right' keyword is having the
proper effect. Try this with different values for 'right' (such as
<10, 0, 0>, the difference is quite clear):
#declare P_cam =
camera
camera { P_cam }
plane
{ x, 0 pigment { checker rgb 1, rgb .5 scale 5 } finish { ambient 1 }
  rotate z*-45 rotate y*-45
  Which version of povray are you using?
Date: 9 Dec 2006 04:25:01
Message: <web.457a7f8553a4c05e7d5894630@news.povray.org>
> camera{P_cam}
By tilted do you mean tilted completely over on it's side?  Considering your
sky & up vectors were 90 degrees off from each other in your original
camera, I wonder which way was up in your original file...  y or z?  Try
both sky y up y  and also sky z up z
Charles
Date: 9 Dec 2006 20:30:00
Message: <web.457b627853a4c05e4752160e0@news.povray.org>
Gah, I'm such a doofus.
I tested your program, Warp, and then checked back with my own code to find
out what went wrong. Turns out that there is an #include between the camera
definition and its usage, and in that included file, the camera is
redefined. No wonder that my changes did not have any effect.
Sorry guys, that was incredibly stupid of me... but well, sometimes you
don't see the most obvious things.
Everything's just fine now.
My apologies for wasting your time, but thanks everyone for replying. :/
Date: 10 Dec 2006 12:02:19
Message: <457c3d9b$1@news.povray.org>
Ansgar nous apporta ses lumieres en ce 2006-12-09 20:27:
No problem my friend! :-)
EVERYBODY get hit with something similar sooner or later :-(
