POV-Ray : Newsgroups : povray.general : POV64 Driving me nuts! Server Time
13 Oct 2025 01:18:29 EDT (-0400)
  POV64 Driving me nuts! (Message 1 to 10 of 11)
Subject: POV64 Driving me nuts!
Date: 26 Aug 2008 10:45:06
Message: <web.48b4168a42bd0f80a5d4a01d0@news.povray.org>
Well, I bought a new laptop over the weekend (I'm pretty excited about it--4GB
ram, Dual 2.0 GHz, NVIDIA 512, and a 64 bit system J), so I downloaded the 64
bit version of POV.  The problem is that all those little messages you get when
you first start using POV never go away!  You know, the ones that tell you how
you can change what happens when a render finishes, etc.  They all have the
nice little checkbox titled "never tell me again", but it ALWAYS tells me
again!  They won't go away!  Anybody have any ideas?
Subject: Re: POV64 Driving me nuts!
Date: 26 Aug 2008 15:35:00
Message: <web.48b45a94e3e105d89dc9af5b0@news.povray.org>
Ok, I think I know what's going on, but I'm not sure how to fix it.  Of course,
my new machine has Vista (that power-hungry control freak), and it doesn't want
to let any changes happen within the program files folder.  I'm guessing that
POV needs to update a file in its directory to actually turn off all the boxes,
but Vista is preventing it from happening.  I don't suppose anyone knows how to
fix it?  Probably not, you are all smart people, and chose not to use Vista at
all...
Date: 26 Aug 2008 15:50:01
Message: <web.48b45d90e3e105d89dc9af5b0@news.povray.org>
> all...
Ok, everyone else probably had this figured out from the beginning, but if you
want to know, I figured it out.  If you've got Vista, you need to go to the
control panel/user accounts and find User Account Control, and turn it off.
Then you can open up POV and tell it never to tell you all those little hints
again.  Afterward, you could turn user account control back on again if you so
desired.
Date: 27 Aug 2008 16:02:22
Message: <48b5b2ce$1@news.povray.org>
With Windows Vista, POV shouldn't be installed into the
"program files" directory, it will prevent user editing of
the POV .ini files, Vista considers all .ini files in the
"program files" directory to be system files.
Unfortunately the "program files" directory was the
default install location for POV with Windows XP,
and this change in MS policy toward .ini file extentions
means that applications like POV that use the .ini
extention for thier own editable files don't work correctly
when installed to the default location under Vista.
Other settings are stored in the registry, which is what
you enabled (I think), so your install is probably still
only partially working.  You might need to uninstall
and reinstall to a directory that won't conflict.
Date: 27 Aug 2008 22:40:00
Message: <web.48b60f8fe3e105d87b6a12450@news.povray.org>
"Kirk Andrews"
I've been using Vista 32-bit about a year now and have come across a similar
problem for any program that is installed in a Vista protected directory (one
of these happens to be a program files).  As long as you have administrative
rights ,as it sounds like you do, all you do is right-click either the povray
executable or a shortcut to it and select the "properties" option.  A window
will then appear goto the tab at the top named "compatibility" and click the
checkbox at the bottom that says "Run this program as an administrator".  Then
click "apply" or "ok" and all should be well.  Now this worked for 32-bit Vista
and I don't have access to a 64-bit Vista computer, but it should work.  Good
luck!
Date: 1 Oct 2008 19:45:00
Message: <web.48e40aaae3e105d8d8a103ef0@news.povray.org>
> desired.
This same thing has bugged me, but disabling UAC is not an acceptable solution
in my situation.  Is there any chance of a better solution which works within
the operating system instead of requiring interference with security?  Maybe
using whatever replaced the registry is a good idea; perhaps some folks who
write Vista apps can speak up.
Date: 1 Oct 2008 21:09:29
Message: <48e41f49@news.povray.org>
Mathuin wrote:
> Maybe using whatever replaced the registry is a good idea; perhaps some
> folks who write Vista apps can speak up.
Huh? The registry hasn't been replaced, and probably won't be anytime soon.
Date: 2 Oct 2008 00:05:00
Message: <web.48e447f3e3e105d8d8a103ef0@news.povray.org>
Cool.  I haven't looked that far under the covers, and I'd heard that Vista was
going to have some new thing in place of the registry.  That being said, would
that be an appropriate solution or is there something else?  I'm sure other
applications have faced this problem in the past, and have a solution that
doesn't involve disabling UAC.
Date: 2 Oct 2008 00:44:51
Message: <48e451c3$1@news.povray.org>
hat
This would seem to be the root of the problem:
Applications written with the assumption that the user will be running
with administrator privileges experienced problems in earlier versions
of Windows when run from limited user accounts, often because they
attempted to write to machine-wide or system directories (such as
Program Files) or registry keys (notably HKLM)[3]. UAC attempts to
alleviate this using File and Registry Virtualization, which redirects
m
write to that directory, the write will get redirected to
( http://en.wikipedia.org/wiki/User_Account_Control )
Normal users don't get to write to \program files any more. Per-user
data really needs to go in the per-user directories (or per-user
registry keys) in Windows, just like in UNIX. :-)
Altho last I asked, I was told this was fixed in the latest POV-Ray, so
once it's out of beta....
Date: 2 Oct 2008 12:57:32
Message: <48e4fd7c$1@news.povray.org>
I don't have Vista, but I wonder if it would object if you
just specified a location within your personal %APPDATA% folder
as installation target for the POV installation. Then the INI
files should be writable. Just for one user, of course.
