POV-Ray : Newsgroups : povray.general : translating a texture Server Time
31 Mar 2026 18:07:57 EDT (-0400)
  translating a texture (Message 1 to 9 of 9)
Subject: translating a texture
Date: 28 Feb 2001 12:11:55
Message: <MPG.15074fbd5058b2529896f3@NEWS.POVRAY.ORG>
Is it to be expected that translating a texture (e.g. T_Col_Marble) to
extreme values, like 25000, gives results that differ very much from the
non-translated texture? Even for discontinuities to appear in the
texture, i.e. sharp boundaries between areas?? Is there a limit one
should not cross??? I could give examples of what I get...
Thank you old hands for helping me :)
Regards,  Sander
Subject: Re: translating a texture
Date: 28 Feb 2001 14:45:10
Message: <3a9d5546@news.povray.org>
I wouldn't think so, though some textures, such as spiral and wood wouldn't
be very interesting in those extremes.  Do you have examples where this
occurs?
Geoff
Date: 28 Feb 2001 14:51:36
Message: <slrn99qlma.ute.ron.parker@fwi.com>
Yes, there are some problems in the noise function out that far.  There's no
hard limit, but the quality of the function deteriorates sharply past around
10000 or so.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 28 Feb 2001 18:42:17
Message: <3A9D8DC4.6862A6AB@peak.edu.ee>
Yes, this is a known problem with patterns using the noise function in POV <=3.1
See thread "Bug in noise function" in povray.bugreports (dated 25.08.99) for a
short discussion.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 1 Mar 2001 16:19:11
Message: <MPG.1508db2b11ae572c9896f9@NEWS.POVRAY.ORG>
In article <3a9d5546@news.povray.org>, Geoff Wedig says...
> occurs?
> Geoff
I wil put an image in p.b.i. showing part of a cylinder with same
texture twice: the lower has the texture translated 100x more than the
upper, and the scale has been 40 in stead of 4 to get anything
acceptable. The lower shows what I was referring to: the texture seems
to be discontinuous along sharp vertical boundaries, for one thing.
There is more amiss, however...
Ron and Margus: thanks for the explanation! What a luxury to get answers
so quickly from you people :)  I will simply have to use less
translation and scaling, I suppose.
Regards,  Sander
Date: 1 Mar 2001 17:02:58
Message: <3a9ec712$1@news.povray.org>
I was stunned to see a mere 100 times change (and another 40 times making
for 4000) cause an affect so extreme as your example image in p.b.i.
Although it must be to do with the actual large numbers it turns into.  At
some 20 thousand units multiplied by 40 you end up getting a translate
distance around 800,000+ units.  We must always remember POV-Ray works
correctly within certain limits of large and small numbers.  Infinence is
not possible after all.
Bob H.
Date: 2 Mar 2001 02:41:09
Message: <MPG.15096d1817f116099896fa@NEWS.POVRAY.ORG>
In article <3a9ec712$1@news.povray.org>, Bob H. says...
> Bob H.
I do realize that I should have scaled first and then translate not to
make things worse than they already are, so to speak: I will try just
that and I suppose it will be all right. Thank you for all the help,
Regards,  Sander
Date: 2 Mar 2001 07:54:04
Message: <3a9f97ec@news.povray.org>
>> occurs?
>> Geoff
No need.  I can bow to the people below.  They obviously know more than I
about this.
Geoff
Date: 2 Mar 2001 11:36:54
Message: <MPG.1509ea9b5b05c3419896fb@NEWS.POVRAY.ORG>
<snip>
<snip>
My mistake: what I did was: first scale 40 then translate about
20.000... Is this the same as first translate 500 then scale 40? I
really get confused :(
Regards,  Sander
