POV-Ray : Newsgroups : povray.general : Storing height_field mesh between frames of an animation Server Time
31 Jul 2024 14:28:23 EDT (-0400)
  Storing height_field mesh between frames of an animation (Message 1 to 10 of 14)
Subject: Storing height_field mesh between frames of an animation
Date: 10 Mar 2007 20:34:16
Message: <45f35c98$1@news.povray.org>
Hi all,
I am using a heightfield in an animation that takes about 5 seconds to
process for each frame. Is there any way to store the heightfield mesh
in memory between frames, or perhaps write it to a file (although that
won't provide much speed up I think)?
Perhaps it is just my ignorance and it is possible, but it would be
really nice to be able to operate on POV-Ray's internal data structures
directly using SDL.
Cheers.
Subject: Re: Storing height_field mesh between frames of an animation
Date: 11 Mar 2007 09:16:36
Message: <45f40f44@news.povray.org>
scam nous apporta ses lumieres en ce 10-03-2007 20:34:
> Hi all,
> directly using SDL.
> Cheers.
If your heightfield is generated from a function, you can save it to a file
during the first frame. Then, you reload it for each subsequent frame. It should
be faster then recreating it everytime.
You can also preprocess it and save is as a heightfield image file, use hf_16 to
get beter vertical resolution. Save as a TGA file. That's the way it was dome
before the use of function was implemented.
Create the heightfield with an amplitude of 1 unit in a plane perpendicular to
the camera. Use an orthographic camera. Apply this texture:
texture{gradient z }finish{ambient 1}}
Change the gradient orientation if needed.
Everything can be filed under "miscellaneous".
Date: 11 Mar 2007 12:11:35
Message: <45f43847@news.povray.org>
  There's no way of storing a heightfield in a file. You can store a mesh,
but a mesh is not the same thing as a heightfield (lighting is different).
Date: 11 Mar 2007 17:35:01
Message: <web.45f482e0da84c92558a931fb0@news.povray.org>
How feasible would it be to write a patch whereby you could store an object
(like a mesh or heightfield) in memory, and then reference that object's
memory address as opposed to the object in your scene file?
If a function could be written that could store any povray object/data
structure in memory for later use I think many people would be able to find
a use for it.
Date: 11 Mar 2007 20:41:13
Message: <45f4afb9$1@news.povray.org>
scam wrote:
> Hi all,
I understand the situation, but I don't see what the problem is.
Unless you meant five minutes (still not bad for an animation) or five
hours (which would be something worth worrying about).
John
Date: 11 Mar 2007 20:46:01
Message: <45f4b0d9$1@news.povray.org>
Sure you can.  You have POV-Ray render the height_field with a gradient
texture running from rgb <0,0,0> to rgb <1,1,1>, with the hf_gray
setting on.  The high parts of the height_field are white, and the low
parts are black.  The height_field is saved as a picture in the render
output file.
Oddly enough, this is what Alain described.
If the original poster is generating a large height field from a
function or pigment pattern (which I did for a recent IRTC entry), he
can try breaking up the height_field into several smaller sections (of
equal precision, or he'll get cracks between sections), and test them to
see which are on-camera and which aren't.
Regads,
John
Date: 11 Mar 2007 22:15:00
Message: <web.45f4c4f9da84c92558a931fb0@news.povray.org>
> output file.
But won't the image file need to be converted back into a mesh at parse
time?
Just to clarify, I have 5000x5000 pixel png image that I have generated in
another program. When POV-Ray parses my scene it spends 5-10 seconds
processing the image, converting it into a mesh (which is what I believe
height_field does). Would this approach actually speed things up in my
case?
> Regads,
> John
This sounds promising, although most of the height_field is visible
throughout the animation.
Thanks for the suggestions all.
Date: 12 Mar 2007 08:08:46
Message: <45f550dd@news.povray.org>
> setting on.
  That's not a heightfield, that's an image file. The heightfield will
need to be generated from it. There's no advantage.
Date: 12 Mar 2007 08:10:00
Message: <45f55127@news.povray.org>
  Such a patch exists/existed for MegaPOV.
  POV-Ray 3.7 has been restructured in a way that will most probably easily
allow this in the future.
Date: 12 Mar 2007 09:14:06
Message: <45f5602e$1@news.povray.org>
Hmmm, that sounds very handy. I don't suppose you can remember the name
of the patch? I had a look on the MegaPOV site (both official patches
and other patches) but couldn't spot it. Thanks for your help by the way.
