POV-Ray : Newsgroups : povray.general : Object Pattern in Media Server Time
15 Jan 2026 10:56:15 EST (-0500)
  Object Pattern in Media (Message 1 to 10 of 17)
Subject: Object Pattern in Media
Date: 26 Aug 2004 04:59:21
Message: <412da669$1@news.povray.org>
Last Night I tried to create a media density pattern based on an object and
failed.
Does anyone know if this is possible?
I noted that the manual says that Object patterns are block patterns, can
these be used in density statements?
Subject: Re: Object Pattern in Media
Date: 26 Aug 2004 05:03:45
Message: <412da771@news.povray.org>
and
> failed.
That should work fine. If it's not working it's probably for some other
reason.
If I were you, I'd consider, why are you using an object{} density pattern
when you could just use the object as the container for the media itself?
Do you *have* a media container? If not, you should; otherwise it's likely
that the rays are going so far into the distance that they're just not
sampling the area where the visible media resides.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 26 Aug 2004 08:28:38
Message: <412dd776$1@news.povray.org>
> reason.
I want to build a "object" shape for the media so that I can turbulate(real
word?) it.
The shape is/was contained in a larger sphere.
From what you say it seems that I may be having a syntax problem.
I've tried writing it as a pigment function, that can be used in a density
statement, is that the wrong way of going about it?
i.e.
declare myObject
declare myPigment, using myObject
declare myFunction using myPigment
create a sphere with interior media using myFunction as function for
density.
Date: 26 Aug 2004 13:28:15
Message: <412e1daf@news.povray.org>
turbulate(real
> word?) it.
Ah.
> i.e.
> declare myObject
> density.
That should work fine, though the creation of myPigment seems unnecessary
when you can simply use myObject directly as a pattern for the density. (I'm
pretty sure you can do just about anything to a density that you can do to a
pigment.)
Did you make the sphere (and all other surrounding objects) "hollow"?
If so, I don't know if we can help you without seeing any code.
 - Slime
Date: 1 Sep 2004 09:48:38
Message: <4135d336@news.povray.org>
My code's a mess.
Whats wrong with this snippet?
#declare myObject = union {
    cylinder    { <8,0,0>,<-8,0,0>,3 }
    sphere { <0,0,0>, 5 } } ;
... and then...
density {
    object { myObject 0,1 }
...  I just keep getting various sytax checking errors with everything I
try?
Date: 1 Sep 2004 10:16:26
Message: <4135d9ba$1@news.povray.org>
> density {
First off, make sure that's within a media {} block. Second, it may be
necessary to use "rgb 0" and "rgb 1" instead of just "0" and "1" (though I'm
not sure that that's the case).
> try?
What error are you getting?
Here is what I would try:
#declare myObject = ... // you seem to have this part correctly already
sphere { // media container
    0, 5
    pigment {rgbt 1} // clear
    interior {
        media {
            scattering {1, 1.0} // or emission or absorption or whatever you
want
            density {
                object {myObject}
                warp {turbulence .3}
                scale 2
                // whatever else
    hollow // necessary for media to show up
 - Slime
Date: 1 Sep 2004 10:40:48
Message: <4135df70$1@news.povray.org>
Thanks for your help so far Slime, but neither of the examples you've
suggested has hit the nail on the head as it were.
I've included the scene below, hoping you can see the obvious thing I've
missed...  Run it to see the current syntax problem...
  location  <0, 5, -40> look_at   <0, 0,  0>
light_source {<-200, 1000, -400> White}
plane {
  y, -20
  pigment { color rgb <0.7,0.5,0.3> }
        cylinder        {
                        <8,0,0>,
                        <-8,0,0>,
                        3
        sphere  {
                <0,0,0>
                ,5
 sphere {
        <0,0,0>,
        10
        texture { pigment { Clear } }
        hollow
        interior        {
          media   {
                                scattering {1, 0.1}
                                intervals 1
                                samples 5
                                method 3
                                density {
                                        object {myObject rgb 0 rgb 1}
Date: 1 Sep 2004 11:24:23
Message: <4135e9a7$1@news.povray.org>
After attempting your code, I can see that there is definitely some sort of
problem with using the object pattern in a density block. It doesn't seem to
accept any LIST_ITEM_A/B values as "3.5.11.23  Object Pattern" in the
documentation says it should, and if you don't specify anything then it says
"missing pigment".
I'm not sure if this is intended behavior. Regardless, it can be worked
around with a pigment_pattern:
density {
    pigment_pattern {object {myObject 0, 1}}
    color_map {[0 rgb 0][1 rgb 1]}
Which allows your scene to render.
 - Slime
Date: 1 Sep 2004 11:35:00
Message: <web.4135eb3615eefcd7c717c9af0@news.povray.org>
"Josh" <som### [at] microsoftcom> wrote:
>  density { object {myObject rgb 0 rgb 1} }
using
density { pigment_pattern { object {myObject rgb 1, rgb 0 } } }
seems to work OK.
Hope this helps,
Mike.
Date: 1 Sep 2004 11:37:46
Message: <4135ecca@news.povray.org>
of
to
says
> "missing pigment".
Yep, thats one of the errors that made me think it was my syntax
> density {
Ah - ha! "pigment_pattern" is a new one on me.  There's so much to learn.
Thanks very much for you help it is appreciated.  If you add ...
                                        warp {
                                             turbulence <0,3,0>
... to the density block, you'll see what I was attempting.
I was inspired by an image someone posted here that used media filled chess
pieces for a "Hollographic" look.
I want to try the same but have the media vaporise when the board gets shut
down.  It could be a mighty cool animation.
