POV-Ray : Newsgroups : povray.general : object pattern & solid mesh? Server Time
23 May 2026 22:50:58 EDT (-0400)
  object pattern & solid mesh? (Message 1 to 10 of 10)
Subject: object pattern & solid mesh?
Date: 23 Sep 2002 17:52:19
Message: <3d8f8d13@news.povray.org>
Hi:
From the error message I'm getting, I assume that a "solid mesh" does not
qualify a what the "object pattern" expects as a "solid". Right? Any ideas
on any alternative method for converting a mesh into an isosurface?
Thanks...
P.D.: the error was "Illegal texture or patch in clip, bound or object
pattern".
Jaime Vives Piqueres
http://www.ignorancia.org
Subject: Re: object pattern & solid mesh?
Date: 23 Sep 2002 18:56:21
Message: <chrishuff-2F6817.18540423092002@netplex.aussie.org>
In article <3d8f8d13@news.povray.org>,
Solid meshes should work fine in the object pattern, however, the object
pattern is not suitable for isosurfaces. The object pattern has an
infinite gradient at the surface of the object, the isosurface algorithm
does not work well with this type of function.
> pattern".
I don't know what that error means...maybe you are specifying a texture
for the object.
http://tag.povray.org/
Date: 24 Sep 2002 03:40:32
Message: <3d9016ef@news.povray.org>
  Well, I've not arrived to that point... but I'm fearing most of all the
render speed of this approach.
>> pattern".
> for the object.
  In my case I think it means "Illegal patch in object pattern". I can use
whatever except a mesh (solid). And I'm sure it has no texture: it's a file
generated by Clothray, and I revised it carefully. I tried even with a
little solid mesh created by hand and still got the "illegal patch" error.
  Anyhow, I must think on another solution. Even if it worked, this is too
slow for a human life...
Date: 24 Sep 2002 04:19:54
Message: <3D90202A.B4A09B1C@gmx.de>
Jaime Vives Piqueres wrote:
> Hi:
As Chris Huff explained the object pattern won't work for that purpose
anyway.
There is a. 'IC_Triangle()' macro in IsoCSG:
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/docu02.html#Triangle
and ABX is working on an IC_Mesh(), but that won't be very fast (in fact
incredibly slow for large meshes).
Date: 24 Sep 2002 08:55:53
Message: <3d9060d9@news.povray.org>
> anyway.
  Well, I don't understand very well why, but I trust you both. :)
  That mesh *is* large. Anyhow, don't worry: I just discovered that I was
trying to do a very stupid thing that makes no sense... but I will never
admit it, of course. ;)
Date: 24 Sep 2002 09:36:51
Message: <Xns92939F9A08E0Cseed7@povray.org>
in news:3d8f8d13@news.povray.org Jaime Vives Piqueres wrote:
> Any ideas
Make a solid mesh, cut it up it in thin slices, build a df3-file of the
slices and use it in an isosurface. You may also want to use some focal
blurr on the slices so the gradient for the isosurface won't be too high.
Ingo
Date: 27 Sep 2002 03:50:21
Message: <q638pusrlo26r7qjlacev5s50c0682dhp9@4ax.com>
On Tue, 24 Sep 2002 10:19:54 +0200, Christoph Hormann <chr### [at] gmxde>
There is more important limitation than speed. Finite number of constants for
functions engine. Even simple famouse teapot balances on limit border in my
experiments.
ABX
Date: 27 Sep 2002 04:25:43
Message: <3D941607.77AE00AF@gmx.de>
> experiments.
Does the hard coded triangle function help there?
Date: 27 Sep 2002 04:48:26
Message: <6f68pusjkj6kif101igccv3sbft5kso4pj@4ax.com>
On Fri, 27 Sep 2002 10:25:43 +0200, Christoph Hormann <chr### [at] gmxde>
> > experiments.
Partially. It decreases number of floats but not eliminates it. So while mesh
can be as big as memory, iso_mesh can be as big as floats stored as contants
in virtual machine.
ABX
Date: 27 Sep 2002 04:57:02
Message: <3D941D5D.F8AEF070@gmx.de>
> in virtual machine.
That's what i assumed.
There are probably more useful approaches generating an isosurface
function based on mesh data anyway, see for example:
http://www.cc.gatech.edu/gvu/geometry/implicit/modeling.html
