A landscape sketch. The hills are height fields, and the plants are a single
mesh made in Blender, duplicated a number of times. The scene was rendered with
UberPOV using no_cache radiosity and scattering media. Total rendering time in
POV-Ray was 7 minutes, 31 seconds. Denoising and vignette are care of Blender,
and the final gamma and contrast were adjusted in IrfanView.
I'm fairly happy with the plants, but the land objects really need some work...
I want overhangs and high detail, but not the render times associated with
isosurfaces... So, I guess the other best option would be sculpted meshes ':/
Sam
Download 'mistlandb7m31s.jpg' (96 KB)
Preview of image 'mistlandb7m31s.jpg'
"Samuel B." <stb### [at] hotmail com> wrote:
> Hi,
> Sam
Nice work. Lighting, plants, and hills look very natural. I agree it's hard to
get the look of undercuts with a height field. Maybe just some mid-range rocks
or rougher terrain at the base of the hills?
There's some 'Megascans' style libraries out there - some free. Quixel has some
great models with even greater poly counts. :)
If you do sculpt some topo/rock forms in Blender, I'd be interested in your
process. I haven't modeling natural forms in Blender other than blobs.
I assume rendering time grow as triangles increase? It's been a while sense
I've work with mesh in POV.
Mike.
https://quixel.com/megascans/home?search=rock&search=cliff&type=3D%20asset&environment=tundra%20biome&assetId=wd4icipcb
Op 31-8-2023 om 00:51 schreef Samuel B.:
> Hi,
> Excellent, Sam. I very much like the mood of the scene and the plants
are great.
Indeed. I am also interested in sculpting meshes. Not sure at present
how to go about that: it would need to allow for erosion along natural
sedimentary planes and layers for instance. It is something I have had
the intention of doing for a long time but never got time to get my
hands dirty in earnest till now...
> Thomas
Hi Thomas,
It occurred to me that you might be able to do something like this with that
vine-growing macro. Have the "vines" grow along the terrain, and then translate
all of the mesh vertices straight down to the bottom of the "vine" and thereby
create a path of erosion.
Maybe change some of the vine-growing rules to instead of being random, seek the
lowest direction to "flow".
- BW
> > Hi,
> > A landscape sketch. [...]
Thanks Mike. Yeah, placing rocks would be a good idea, but this scene isn't set
up correctly to make it easy.
Thanks for the link. I tried Quixel a while back, but I was annoyed by the
always-online nature of the program and promptly uninstalled it. But looking
back: of course it needs to be online to download things! So, I might give it
another shot in the future.
I learned a neat Blender sculpting trick this year: use the flatten tool, and in
its advanced settings, check one or both boxes for the original normal and
plane. These will allow you to sculpt hard edges. It's not perfect, but it does
make sculpting rock forms much easier. And of course, make sure to use dyntopo.
> Mike.
Yeah, render times go up with higher triangle counts. But you can always try
decimating the mesh or using the simplify sculpting tool.
Sam
> > process. [...]
> I learned a neat Blender sculpting trick this year: use the flatten tool [...]
This just in: the scrape tool works much better if you want to avoid building up
beyond the original plane. In other words, it's more like using a chisel or
sanding block. And definitely still play with the original normal and plane
settings to make the best use of it.
Sam
> > Hi,
> are great.
Thanks Thomas. It's inspired by this image somebody posted once using Midjourney
ai:
https://i.ibb.co/DRqSGKD/Organic-Proof8059-Midjourney-Jedi-TOTL-Magazine-Triumph-of-the-Light.jpg
I want to recreate the overall feeling of the thick atmosphere, fuzzy plants
and, if possible, a similar futuristic structure.
> Thomas
Well, as far as sculpting goes, Blender is one option. It's free, but the
learning curve is steep. There's also ZBrush (paid), Sculptris (paid? free? I
think I still have an installer for an old free version I could share), Nomad
for Android (paid), and... I don't know what else.
As far as programs specializing in landscapes, you already know about World
Machine. There's also Gaea, which seems very interesting. And Terragen, of
course. And also Gaia, which doesn't seem to do geology as well as Gaea but is
more of an all-in-one program letting you place plants and structures, I think.
Overall, Gaea seems the best choice at the moment, but I haven't made an
extensive search.
Gaea: https://quadspinner.com/
Sam
Op 31/08/2023 om 23:12 schreef Bald Eagle:
Hmm... worth a try indeed. Thanks for the suggestion!
Op 1-9-2023 om 01:23 schreef Samuel B.:
> ai:
You certainly achieved to recreate the mood.
I must have an ancient Sculptris installer somewhere under the dust of
my archives. I shall have a look. Blender is still (and since many many
years) on my ToDo list :-/ Silo, which I have, may do something
interesting but it is not specialised in that direction. However, I
should have a more thorough look when I get the time.
> extensive search.
I find Terragen a bit disappointing (at least, the ancient version I
possess); I shall have look at Gaea.
> > Thanks Thomas. It's inspired by this image [...]:
Yeah, I got close. The sky isn't as warm. And somehow the denoiser failed a bit,
probably due to the noisy proximity pattern I used and fed into the albedo slot.
(Things look a lot smoother on tests where I leave it out.)
> > Well, as far as sculpting goes [...several suggestions]
Probably the same one I have. Use it only if you must, I say. It's hard to get
acceptable results with it, especially when trying to make rocks and such.
> Blender is still (and since many many years) on my ToDo list :-/ [...]
Yeah, I guess it all depends on how useful it'd be for your work. My previous
experience with anything close to it was LightWave 3D (v7) and Blender has, in
all respects, become so much better than that.
> possess);
My biggest issue with Terragen was that everything took a lot time to compute
and render. Maybe the newer versions (if any) are better?
> Thomas
Gaea really does seem like the best one for simulating real-world geology (or an
approximation of it, anyway), but I'm pretty sure to get anything useful from it
you have to pay for a full(er) version.
Sam
