POV-Ray : Newsgroups : povray.binaries.images : Blurred reflection comparison Server Time
28 Apr 2024 03:25:21 EDT (-0400)
  Blurred reflection comparison (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: Blurred reflection comparison
Date: 15 Feb 2018 19:31:55
Message: <5a86267b$1@news.povray.org>
Le 18-02-15 à 14:26, Mike Horvath a écrit :
> Here's my latest town render. You can see the pixelation in the
> reflections. I haven't been able to get rid of it using more focal blur
> and anti-aliasing. I will keep trying.
> Mike
It don't look like pixelisation but rather like some noise.
The possibilities to get rid if it are, in my biew :
1) Use +r4 +am2
2) increase the sample count of your camera's focal blur.
Increasing the maximum recursion level works great when using
reflection{roughness Something}. Most of the time, it have only a
negligeable effect on the rendering speed, but cause antialiasing to
work harder in those noisy areas. You also may want to reduce the aa
threshold from the default of 0.3 to something like 0.1 to 0.05.
Date: 16 Feb 2018 21:48:54
Message: <5a879816$1@news.povray.org>
>> blur and anti-aliasing. I will keep trying.
>> Mike
> 1) Use +r4 +am2
That worked well on my smaller scene. I tried on my larger scene too,
but it was taking a long long time to render. I will keep trying.
Mike
Date: 16 Feb 2018 23:10:00
Message: <web.5a87aa411a4227fa47873e10@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> // this method is faster, but requires a focal blur and/or extra
> antialiasing
> #declare BlurAmount = 0.1;
> #macro BlurredReflectionRegularNormals(InPigment, InFinish, InNormal)
> // texture
>   pigment { InPigment }
>   finish { InFinish }
>   normal { InNormal }
>   normal {bumps BlurAmount scale 0.001}
I didn't know that multiple normal statements would actually 'combine'; I
thought the 2nd would completely override the 1st or cause an error (like trying
to use multiple pigment or finish blocks.) Interesting if true! I need to check
this out.
Date: 17 Feb 2018 00:03:31
Message: <5a87b7a3$1@news.povray.org>
> this out.
I'm not really sure, but the effect might be the same as using a normal
map and averaging the two normals. Or not.
Mike
Date: 17 Feb 2018 01:40:01
Message: <web.5a87cd7b1a4227fa47873e10@news.povray.org>
Yeah, I just re-checked the documentation; you're right, there *can* be more
than one normal statement. (I obviously haven't taken a look there in awhile,
ha.) I probably never thought about it because of the 'caveat' that's mentioned,
about unpredictable behavior.
This is one of those situations that kind of bugs me: a texture can have more
than one of a *certain* kind of entry-- like normals-- but not another kind of
entry (like pigments). I know there are behind-the-scenes technical reasons for
this disparity-- but from a user standpoint, it does seem arbitrary. It's hard
to keep these 'special rules' (my phrase) in my head at all times :-/
Date: 17 Feb 2018 12:07:47
Message: <5a886163$1@news.povray.org>
Am 17.02.2018 um 06:03 schrieb Mike Horvath:
>> (like trying
>> to check
>> this out.
The latter, actually.
Date: 17 Feb 2018 15:28:25
Message: <5a889069@news.povray.org>
I posted five images to Flickr showing my experiments with blurred
reflections.
https://www.eurobricks.com/forum/index.php?/forums/topic/159291-pov-ray-surface-realism/
I asked on Eurobricks which is the most realistic image? I will also ask
here. Which do you think look the most like real LEGO bricks?
Mike
Date: 17 Feb 2018 16:01:26
Message: <5a889826$1@news.povray.org>
> reflections.
> Mike
I like #1 and #2. In all cases, the black road is way too reflective for
lego (although I like black reflective on principle).  Unless Lego has
changed a lot since I was a kid.
dik
Rendered 920576 of 921600 pixels (99%)
Date: 17 Feb 2018 18:24:41
Message: <5a88b9b9$1@news.povray.org>
>> reflections.
>> ask here. Which do you think look the most like real LEGO bricks?
>> Mike
All my bricks are so old and scarred I can't really come to a conclusion
on my own. For instance, holding a brick so it reflects light from my
lamp, I can make out the bulb pretty clearly as well as the lamp shade.
But other nearby objects are barely visible. I don't know if brand new
bricks would reflect more.
Mike
Date: 18 Feb 2018 06:25:01
Message: <web.5a8962621a4227fab244fcf0@news.povray.org>
> >> reflections.
> >> Mike
> Mike
I have another observation for some blur reflection material, some surface is
more blur when you look it perpendicular. Just like variance reflection(aoi
pattern reflection amplitude), the blur has its aoi pattern.
But I don't know this is suitable for lego.
