POV-Ray : Newsgroups : povray.beta-test.binaries : Radiosity POV 3.6 vs. 3.7 vs. MCPov Server Time
21 Jul 2026 13:51:24 EDT (-0400)
  Radiosity POV 3.6 vs. 3.7 vs. MCPov (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Radiosity POV 3.6 vs. 3.7 vs. MCPov
Date: 19 Jan 2009 06:35:01
Message: <49746565@news.povray.org>
clipka wrote:
> Would you mind e-mailing the scene to "christoph (at) lipka-koeln (dot) de"? As
> of now, it's the only scene I've seen so far that shows this effect.
> Maybe you can strip it down to just the room and the tiles.
Will do so, but may take a little time.
> Another thought that just crossed my mind is "gamma": what if 3.7 interprets the
> sky sphere differently with respect to gamma? (Then again, that would probably
> look much different.)
> At the moment I'm suspecting the floor to pick up light from below for some
> reason. What is the floor made of, geometrically speaking?
I will also do some experiments to see if I can narrow down the problem.
-Ive
Subject: Got it!:
Date: 19 Jan 2009 08:10:15
Message: <49747bb7@news.povray.org>
  Just a box ;)
#declare W = 500.0;
#declare L = 664.6;
#declare H = 323.6;
// room
union {
// floor
   box { <0,0, 1> <W,-1,-L-1>  texture {T_Floor} }
  ... and a lot of more stuff
But here is the interesting thing:
#declare T_Floor = texture {
   material_map { png "Floor#2"
     texture {T_FloorMortar}
     texture {T_FloorWhite}
     texture {T_FloorBlack}
     texture {T_FloorBlack translate  79}
     texture {T_FloorBlack translate 255}
   rotate x*90
   rotate y*45
   scale 117.2/2
   translate <-20.0, 0, 0>
where each of the separate textures is a quite complicated layered
texture. Suspicion was that either the heavy layered textures or the
material_map statement did mess up things.
So a quick simplification:
#declare T_FloorWhite_simple = texture
   pigment {rgb 0.55}
   finish {ambient 0  diffuse 1}
#declare T_FloorBlack_simple = texture
   pigment {rgb 0.05}
   checker
   texture {T_FloorWhite_simple}, texture {T_FloorWhite_simple}
   rotate x*90
   rotate y*45
   scale 117.2/2
and the result is still weird! See picture 1.
But then:
   rotate x*90
   rotate y*45
   scale 117.2/2
works perfectly as expected (low quality aside). Picture 2.
This effect can be easily reproduced in any other scene.
So it seems to me that the problem is maybe not even related to
radiosity but it is to patterned textures. Maybe it has something to do
with he post by me to p.beta-test from 4/25/2008 "texture_map vs.
pigment_map" - that never got a response ;(
-Ive
Download 'musiclesson-simple1.jpg' (50 KB) Download 'musiclesson-simple2.jpg' (77 KB)
Preview of image 'musiclesson-simple1.jpg'
Preview of image 'musiclesson-simple2.jpg'
Subject: Re: Got it!:
Date: 19 Jan 2009 08:45:00
Message: <web.497483b127a78bab9b482c50@news.povray.org>
Now THAT is interesting; in fact, some - albeit less prominent - differences
between 3.6 and beta.30-rad1 I never got resolved do involve patterned
textures:
- The checkered floor in the balcony scene, which got brighter, uses basically
the same construction as your scene.
- The object_pattern scene, which shows some strange artifacts, uses an
object_map on textures.
I guess these are insofar radiosity related as they only show in radiosity
shots. There seems to be an issue with how the indirect illumination intensity
returned by the radiosity code is "post-processed".
Internally, the indirect illumination intensity is referred to as "ambient";
maybe this led to some mixup of variables, causing this indirect illumination
intensity to be mistakenly used as ambient term for additional texture layers -
or something along these lines. Or it is just summed up for layered textures,
instead of being weighted properly.
Date: 19 Jan 2009 09:24:09
Message: <49748d09$1@news.povray.org>
Just to make it clear. The layered textures did not cause this problem,
(maybe they cause artifacts if the max_trace_level is not high enough,
but this is another story). It is just the patterned texture statement.
   checker // or anything else
   texture {T1}, texture {T2}
And as mentioned in my other post, something strange does happen with
texture maps even when no radiosity is involved.
-Ive
Date: 19 Jan 2009 10:30:00
Message: <web.49749c6527a78bab9b482c50@news.povray.org>
>    checker
>    rotate x*90
>    rotate y*45
>    scale 117.2/2
Ta-ding!
You know what? That stupid Trace::ComputeLightedTexture() code passes the wrong
co-ordinates to the radiosity code!
Instead of "world co-ordinates" it actually passes the co-ordinates with the
texture translations applied. Incredibly stupid error. And a one-liner to fix.
In file "trace.cpp", locate the line reading:
radiosity.ComputeAmbient(ray, *ipoint, rawnormal, layNormal, ambCol, weight *
max_Radiosity_Contribution, ticket);
replace with:
radiosity.ComputeAmbient(ray, Vector3d(isect.IPoint), rawnormal, layNormal,
ambCol, weight * max_Radiosity_Contribution, ticket);
This actually gets both the "balcony.pov" and "object_pattern.pov" scenes
perfectly back to 3.6 look.
Thanks for your help! Your scene and experiments provided essential input for
fixing this issue.
Date: 19 Jan 2009 10:50:00
Message: <web.4974a03527a78bab9b482c50@news.povray.org>
Can you provide a sample scene for that, too?
I bet if there is *one* mixup of ipoint vs. isect.IPoint (IPoint and
Intersection->IPoint in the 3.6 code), then chances are there's more of this
kind to be found...
Date: 19 Jan 2009 10:55:52
Message: <4974a288@news.povray.org>
clipka escreveu:
>>    checker
>>    rotate x*90
>>    rotate y*45
>>    scale 117.2/2
> Ta-ding!
Good.  But his previous texture definition used a finish block with
diffuse 1 and that is too high, I guess.  The default is 0.6 if I'm not
wrong...
Date: 19 Jan 2009 11:10:00
Message: <web.4974a56127a78bab9b482c50@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> clipka escreveu:
> >>    checker
> >>    rotate x*90
> >>    rotate y*45
> >>    scale 117.2/2
> > Ta-ding!
> wrong...
Not an issue here, as the color is only rgb 0.55.
And the culprit for the weird look has been clearly identified and successfully
eliminated.
Date: 19 Jan 2009 11:10:46
Message: <4974a606$1@news.povray.org>
> kind to be found...
Attached is a simple SDL file.
 From my understanding T1 and T2 have to look identical, and they do in
3.6.1.
-Ive
Download 'us-ascii' (1 KB)
Date: 19 Jan 2009 11:13:29
Message: <4974a6a9$1@news.povray.org>
> fixing this issue.
You're welcome. Glad to be of any help, finally it's in my own interest ;)
-Ive
