POV-Ray : Newsgroups : povray.unofficial.patches : Re: Hi from DKBTrace author Server Time
6 Jul 2026 16:40:58 EDT (-0400)
  Re: Hi from DKBTrace author (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Hi from DKBTrace author
Date: 20 Jan 2001 15:17:22
Message: <3A69F1CD.EBAC06D2@videotron.ca>
Chris Huff wrote:
> I think it's safe to say that most of the reason for choosing C++ is to
> allow making the source code fully object-oriented.
Is there any other?
Other than being allowed to use // comments.
Francois Labreque | In the future, performance will be measured
    flabreque     | by the size of your pipe.
        @         |             - Dogbert, on networking
   videotron.ca
Date: 20 Jan 2001 15:42:22
Message: <chrishuff-AD8B79.15432820012001@news.povray.org>
In article <3A69F1CD.EBAC06D2@videotron.ca>, Francois Labreque
> Is there any other?
The const keyword, stricter type checking, and overloaded
functions...probably a couple others. Some might like the memory
management better, you can use classes to wrap functions and data
together even if you aren't doing OOP.
Christopher James Huff
Date: 20 Jan 2001 16:28:07
Message: <3a6a02e7@news.povray.org>
"Chris Huff" wrote:
> I briefly considered this exact feature
Hmm...
> but there is no way I could do it. Maybe when POV 4.0 is
> available, and the source code is fully object-oriented
I expected that.
> Or a pigment map of several portal_pigments, and use the
> function pattern to change portals...(just use a single
> value as the function, it would act like the "solid" pattern)
I like our mutual understanding... :)
> The syntax would be pretty easy though...just something like
> the camera: the last world defined is the one that gets used,
> and you would be able to #declare them to allow you to refer
> to them from other worlds.
I don't think it makes sense to declare a world. I would rather just assign
each world an ID.
Maybe like:
world {
   WORLD_ID
   ...anything inside the world goes here...
Later you could add more things to the same world by using the ID of an
already existing world:
world {
   WORLD_ID
   ...add more things to the same world...
I envision the cameras being the keys to the worlds. Multiple cameras could
be located in each world, and each camera would have an ID.
world {
   WORLD_ID
   camera {CAMERA_ID ...}
Lastly you would define which camera to use as the active one. I don't know
how this would be done, maybe:
global_settings { camera CAMERA_ID }
The world in which the active camera is located is the active world. Default
would be to use the last defined camera.
For all portals you could specify which world should be the "target" for the
portal. If nothing is specified the current world would be default. (Where
"current" means the world in which the portal is located.)
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Date: 20 Jan 2001 20:59:23
Message: <chrishuff-6D00E2.21002920012001@news.povray.org>
In article <3a6a02e7@news.povray.org>, "Rune" <run### [at] inamecom>
> assign each world an ID.
My reasoning was that identifiers are only added to the with #declare,
#local, #macro...and that there wasn't a good reason to change that.
Also, the "keyword {IDENTIFIER" syntax is used in POV already, for
creating a copy of something already defined, and this would cause
needless confusion. "world {RedWorld" looks like it is creating a copy
of RedWorld.
Maybe each world would be limited to a separate file, and imported like
this:
#world WorldIdentifier "worldFile.pov"
But I would prefer the syntax that treats each world more like an object.
PS: "world" or "universe"? The latter seems more specific, but the first
is shorter...
Date: 21 Jan 2001 06:00:19
Message: <3a6ac143@news.povray.org>
> #declare, #local, #macro...and that there wasn't a good
> I would prefer the syntax that treats each world like an object.
Normally when something #declared is called, a copy of it is created. For a
world that would use way to much memory. Some other approach should be
found.
Once a world is created I think it should indeed "exist" (though not
necessarily visibly), and not just be waiting to be called.
> already, for creating a copy of something already defined
> imported like this:
I see the point although I'd prefer a solution where a world didn't have to
be in a separate file. Currently no features in POV-Ray *require* separate
files (except images etc.). Include files are optional and never required.
#world (WorldIdentifier)
   ...anything goes here...
How about this?
It could also be used like:
   #include "worldfile.pov"
> but the first is shorter...
I think "universe" is too specific, at least the scientific sense of the
word. The feature would probably often be used just to make different "sets"
"stages" or "scenes". Actually I think "scene" would be better than both
"world" and "universe" if it wasn't for the fact that POV-Ray files are
often referred to as "scene-files" which would cause confusion...
Rune
Date: 21 Jan 2001 14:53:04
Message: <3A6B3E85.303666C0@peak.edu.ee>
Chris Huff wrote:
> I briefly considered this exact feature, but there is no way I could do
> it.
Couldn't it be done as an extension of the light_groups philosophy? E.g. if the
the camera ray hits an object that is not in the camera's "world group" the
intersection is discarded; a portal would (among other things) redefine the
camera's group id, so further testing along this ray is done for a different
"world group".
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 21 Jan 2001 16:16:20
Message: <chrishuff-338C32.16172621012001@news.povray.org>
In article <3A6B3E85.303666C0@peak.edu.ee>, Margus Ramst
> E.g. if the the camera ray hits an object that is not in the camera's
> "world group" the intersection is discarded; a portal would (among
> other things) redefine the camera's group id, so further testing
> along this ray is done for a different "world group".
I think that would slow down the rendering of the world being directly
rendered, possibly by a lot. It also would probably lead to some highly
confusing multi-world files.
Date: 21 Jan 2001 16:32:37
Message: <chrishuff-5F1159.16334221012001@news.povray.org>
In article <3a6ac143@news.povray.org>, "Rune" <run### [at] inamecom>
> For a world that would use way to much memory. Some other approach
> should be found.
I don't see the problem...the memory is going to have to be allocated
for it anyway, and if the user makes another variable with the "world
{WorldIdentifier" syntax, they probably are expecting to get a copy.
There would normally be just one copy, though...
And you are still thinking in terms of how POV currently does
stuff...since it is practically impossible until POV 4.0's C++ rewrite,
things might change a lot.
Of course.
> > imported like this:
> have to be in a separate file. Currently no features in POV-Ray
> *require* separate files (except images etc.). Include files are
> #end
This looks good, with the exception of the parentheses...the macro
syntax would be similar, though the world wouldn't take parameters and
wouldn't be "called". How about:
#world WorldIdentifier |(optional file name)|
    ...scene stuff here...
However, you wouldn't be able to build on a "base" world with this
syntax...you would have to put the base world in an include file.
With the "world as object" syntax, you could do something like:
#declare BasicWorld = world {...checkered plane and bozo sky...}
#declare GreenWorld = world {BasicWorld ...green reflective sphere...}
#declare RedWorld = world {BasicWorld ...red reflective sphere...}
#declare ChromeWorld = world {BasicWorld ...chrome reflective sphere,
portals to RedWorld and GreenWorld}
world {ChromeWorld}
It would basically be a "super union" that could include global
settings, local variables, cameras, etc...
Variables in each world could be accessed with dot notation:
GreenWorld.FrontCamera, for example. The portal pigment could let you
specify what world you want the rays to reappear in.
> the word. The feature would probably often be used just to make
> different "sets" "stages" or "scenes". Actually I think "scene" would
> be better than both "world" and "universe" if it wasn't for the fact
> that POV-Ray files are often referred to as "scene-files" which would
> cause confusion...
How would "universe" be too specific? It describes exactly what is
happening...multiple virtual areas whose contents are completely
isolated from each other except were they refer directly to something
from another scene.
Date: 21 Jan 2001 16:46:01
Message: <3A6B58FE.5D934F76@peak.edu.ee>
Why? Only an intersection test would be done for objects not in the camera's
group - no reflections, lighting, textures, volume etc. Granted, it would still
be slower, but I don't think the performance hit would usually be that bad.
And why would the files be confusing? The way I see it, the syntax should look
pretty much the same as files using light_groups (new syntax), perhaps also with
a "global" modifier for blocks that are always rendered.
Margus Ramst
Date: 21 Jan 2001 20:42:11
Message: <chrishuff-E5181C.20431621012001@news.povray.org>
In article <3A6B58FE.5D934F76@peak.edu.ee>, Margus Ramst
> camera's group - no reflections, lighting, textures, volume etc.
> Granted, it would still be slower, but I don't think the performance
An intersection test can be quite costly...think about where most of the
slowdown of complex CSG or isosurface scenes is coming from. But you
shouldn't even need an intersection test, just skip checking the object
at all if the object's world ID doesn't match the current world ID...but
it is still an unnecessary piece of work to be done, especially for
adding features later...the coder would have to write code for handling
which universe their object/effect is in. And memory use would
increase...assuming a limit of 256 "worlds", by one additional byte for
each object/camera/light/glow/global_settings/any other entity in the
scene, ...which could add up to a lot, especially with highly complex
CSG objects.
Having each "world" be separate would allow essentially unlimited number
of worlds (not that anyone is likely to have more than 256...), have
lower memory overhead, eliminate any extra work during rendering, etc...
Extending the separation into the syntax means simpler parsing code,
easier to understand scenes, and would allow easily combining of scenes
that weren't originally written to support multiple worlds (you would
just include the scene file in it's own world {} block).
But of course all this is theoretical, since work on POV 4.0 hasn't even
started yet and we have no idea how different the scene language will be.
A jumble of cameras/lights/objects/global settings each belonging to a
different scene? Files get complex enough as it is...and it makes sense
to group the stuff for each virtual universe together. It just seems
like it would be easier to use...
