POV-Ray : Newsgroups : povray.unofficial.patches : Bug in isosurface using pigment function? Server Time
25 Jul 2026 15:48:09 EDT (-0400)
  Bug in isosurface using pigment function? (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Bug in isosurface using pigment function?
Date: 24 Nov 2000 11:49:39
Message: <3a1e9c23@news.povray.org>
Christoph Hormann wrote in message
<3A1E9A74.B6428D71@schunter.etc.tu-bs.de>...
> Every CSG made of cylinders, spheres, cones, boxes, torii should be
quite
> easy to convert to a smooth isosurface function, the more difficult
things
> are lathe, prism and meshes.
yes, I know
but as I said I'm looking for universal method (equations)
perhaps to code in source code
ABX -> just look -> http://www.mdk.art.pl/
Date: 24 Nov 2000 14:11:02
Message: <3A1EBD44.ECD07DE8@club-internet.fr>
Wlodzimierz ABX Skiba wrote:
> Chris Huff wrote in message ...
> >In article <3a1e6b2a@news.povray.org>, "Wlodzimierz ABX Skiba"
> ><abx### [at] abxartpl> wrote:
> > > first I prepare CSG than I declare function{pigment{object{...}}} to
> > > describe interior of it and then I clone this as isosurface.
> > > Isosurface has artifacts even with accuracy 0.00005.
> > > I have calculated value (with eval) of max_gradient as 200000 but
> this
> > > not help.
> > The object pattern has two states: on and off. It doesn't have any
> > "in-between" values. Patterns like this have an infinite gradient, and
> > cause the isosurface algorithm problems. Other patterns that have this
> > problem are checkers, hexagon, brick, and any pigment that has sharp
> > lines.
> I know this but unfortunatly in current (unoficial) state of pov this is
> only way to play with described week ago nonlinear transformations.
> Everything is ok but normals.
The couple of images I posted a few weeks ago didn't use the object
pattern, but proximity.
I don't know if this is what you were talking abut though.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Date: 24 Nov 2000 18:01:31
Message: <chrishuff-EA7F65.18015924112000@news.povray.org>
In article <3a1e7cda@news.povray.org>, "Wlodzimierz ABX Skiba"
The proximity pattern will be better for this, but in it's current state
is too slow to make a practical pigment function.
> perhaps the problem can be resolved just like in smooth_triangle ?
I don't see how...in a smooth triangle, you manually specify the normal
at each corner. Isosurfaces don't have such convenient control
points...and the results would probably look horrible.
Christopher James Huff
Date: 24 Nov 2000 18:06:39
Message: <chrishuff-53E619.18070724112000@news.povray.org>
In article <3A1E9A74.B6428D71@schunter.etc.tu-bs.de>,
chr### [at] gmxde wrote:
> Every CSG made of cylinders, spheres, cones, boxes, torii should be quite
> easy to convert to a smooth isosurface function, the more difficult things
A sor should be pretty easy, a lathe shouldn't be extremely difficult. A
mesh may not be a huge problem either. Simple convex prisms also
wouldn't be hard, but concave or self-intersecting prisms could be a
bigger problem.
Basically the distance of the nearest point on the surface, with a
negative sign if inside the object and a positive sign if outside.
This is what my proximity pattern will eventually do.
Date: 25 Nov 2000 04:29:54
Message: <3A1F8692.ECF21C45@schunter.etc.tu-bs.de>
> bigger problem.
With linear splines this should be easy too, but the others would involve
some more complicated math that would probably be quite slow when not hard
coded.
proximity pattern is quite slow right now, but for linear spline
prisms/lathe/sor, i could think of a different algorithm dividing space
into segments where proximity only depends on a single plane, that would
use quite a lot of memory, but it would be fast.  Of course this would
also have some problems with concave shapes, but since the isosurface use
only needs good results near the actual surface, this is not that
problematic.
Date: 25 Nov 2000 04:58:35
Message: <3a1f8d4b@news.povray.org>
<3A1F8692.ECF21C45@schunter.etc.tu-bs.de>...
> proximity pattern is quite slow right now...
but don't need so much small accuracy and perhaps so big max_gradient
therefore this could be faster than pigment{object{}}
I'll tell you after (ray)tracing
ABX
VooVoo is not VooDoo -> http://www.voovoo.art.pl/
Date: 25 Nov 2000 06:20:51
Message: <chrishuff-8864ED.06212025112000@news.povray.org>
In article <3a1f8d4b@news.povray.org>, "Wlodzimierz ABX Skiba"
In order to get a smooth enough pattern that the isosurface algorithm
can use it, you need to use a huge number of samples. It has been tried
before, but was too slow to be of practical use.
However, I am working on an updated version that has specialized
proximity functions for each object as well as the existing sampling
function...this will be much faster for many objects.
Date: 26 Nov 2000 08:59:49
Message: <3a211755@news.povray.org>
sounds great
ABX
Date: 27 Nov 2000 03:25:49
Message: <3a221a8d@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: but
: his color_map is [0 rgb 1][0 rgb 0][1 rgb 0], which looks like a mistake
: to me...it is completely black, with no variation at all
  Did you actually try to render an object with that pigment?
  It's not completely black :)
Date: 27 Nov 2000 03:29:00
Message: <3a221b4c@news.povray.org>
: What are you expecting this color_map to result in? It starts out as
: white, but goes to black in 0 distance and ends in black, basically a
: black pigment...
  Try rendering a plane with that pigment.
