POV-Ray : Newsgroups : povray.unofficial.patches : Is this right? Server Time
5 Jul 2026 20:08:09 EDT (-0400)
  Is this right? (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Is this right?
Date: 14 Sep 2000 15:07:51
Message: <39C113DD.88D6975@peak.edu.ee>
Warp wrote:
>   Is the radiosity data independent of the camera location?
>   If yes, does it mean that you can get the same effect as in the
> "regular" radiosity used in scanline renderers, that is: Calculate radiosity
> once, render same scene from different camera locations many times?
AFAIK, no. It would only work only if the new image doesn't include areas of the
scene invisible in the original image.
First level radiosity samples are only taken at points hit by the camera (or
reflected/transmitted) rays, so for the rest of the scene radiosity information
would be isufficient. Of course there should usually be a fair amount of samples
generated during secondary bounces, which can be reused to speed up the process.
Margus Ramst
Date: 14 Sep 2000 15:12:46
Message: <39C122A9.64481A57@pacbell.net>
But wouldn't secondary and tertiary bounces return lower values
than a primary bounce value ? If so then what value would it
add for speeding up the process ?
Date: 14 Sep 2000 16:59:13
Message: <chrishuff-425F2C.16010814092000@news.povray.org>
In article <39C### [at] peakeduee>, Margus Ramst
> areas of the scene invisible in the original image.
I think it will compute extra samples for areas that weren't sampled
before, so that isn't the problem. However, if the scene is dynamic, for
instance, if there is a ball rolling through it, things probably won't
work right. In other words, the only kind of animation you can do with
this method is one where only the camera moves.
Christopher James Huff
Date: 14 Sep 2000 18:08:06
Message: <39C13E1C.219CBE6@peak.edu.ee>
Frankly, I might have been wrong here. AFAICS they _could_ be reused if their
current recursion level is stored, but I don't know if it is.
Margus Ramst
Date: 14 Sep 2000 18:10:33
Message: <39C13EB1.BE3C6504@peak.edu.ee>
Yes, but you _will_ have to take extra samples if the viewpoint changes, unlike
in "real" radiosity where the entire scene is energy-balanced before rendering.
Margus Ramst
Date: 15 Sep 2000 02:48:09
Message: <39c1c629@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: Yes, but you _will_ have to take extra samples if the viewpoint changes, unlike
: in "real" radiosity where the entire scene is energy-balanced before rendering.
  On the other hand, calculating radiosity only where it's needed and not
everywhere saves rendering time and memory.
Date: 15 Sep 2000 11:50:44
Message: <39c24554@news.povray.org>
What if one were willing to invest the time and memory for calculating the
radiosity of the whole scene? Wouldn't that be cool? I mean, you process
once, and then you can do a flythrough throught any point of the scene as
many times as you want to, without having to reprocess. I would do it. :)
Date: 15 Sep 2000 18:07:09
Message: <39c29d8c@news.povray.org>
Tony[B] <ben### [at] panamac-comnet> wrote:
: What if one were willing to invest the time and memory for calculating the
: radiosity of the whole scene? Wouldn't that be cool?
  The whole scene? Even if it has things like infinite surfaces (eg. planes)?
  Even in finite scenes it may spend days and consume gigabytes of disk
space for the entire scene.
Date: 15 Sep 2000 20:43:38
Message: <39c2c23a@news.povray.org>
planes)?
Really? Wow. I didn't know it was such a tall order... Could it perhaps be
completely calculated for a bounded space?
Date: 21 Sep 2000 23:02:54
Message: <39cacbde@news.povray.org>
"Tony[B]" <ben### [at] panamac-comnet> wrote...
not
How would this save any calculation time?  Let's say we go with the current
implementation, and set some options to make sure it doesn't take extra
samples if it doesn't need them.  We do one fly-through of the scene,
keeping the data along the way.  After that, we know that we've got all the
info we need for another fly-through, and not any extra.  We can then do
another fly-through very quickly.
Also, if we wanted to do a fly-through backwards at that point, we could do
that, too.  We might end up having to do more calculations to get the
back-sides of objects.  But think about the situation where you never do the
backwards fly-through.  If you had pre-calculated everything, you would have
done work that didn't need to be done.  You would have "wasted" computation
time, and the whole process would have taken _longer_ (assuming you're using
the same algorithm in both cases).
-Nathan
