POV-Ray : Newsgroups : povray.off-topic : I need a new computer: RAID and other questions Server Time
15 Mar 2026 17:17:24 EDT (-0400)
  I need a new computer: RAID and other questions (Message 41 to 50 of 55)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: I need a new computer: RAID and other questions
Date: 28 Jan 2013 21:43:32
Message: <51073754@news.povray.org>
On Mon, 28 Jan 2013 17:16:16 -0500, Francois Labreque wrote:
>> It's a new feature in Windows Server 2007 (?).
> A new feature that Novell had in Netware 3.10 back in 1990.
I was thinking the same thing.  That was the migration feature IIRC.
Migrated data from fast disk storage to slower optical storage.
It's still supported in their current products, though I don't know any
vendors who support it on Open Enterprise Server.
On Linux, btrfs has this kind of capability as well.
Jim
Date: 28 Jan 2013 21:44:37
Message: <51073795$1@news.povray.org>
On Mon, 28 Jan 2013 08:10:07 +0000, scott wrote:
>> rsync + cron = backup goodness.
> Or robocopy + task scheduler if you're on windows. But both options
> assume your computer is on and the backup medium is connected...
Sure - and it's kinda hard to do operations with a machine that's turned
off and without backup media in place.  Kinda like running a tape backup
but not putting a tape in the drive every night.
I worked for a retail chain where store managers had to remember to do
that - and often didn't.  So the server would "prompt" them by sounding a
foghorn. :)
Jim
Date: 29 Jan 2013 03:55:11
Message: <51078e6f@news.povray.org>
And Amiga OS had premptive multitasking and a full GUI back when PC
users were still playing with MS-DOS. Your point?
>> Of course, then you need to buy backup software expensive enough that it
>> backs up the hidden previous versions as well as the visible files...
> No. You just need to load $Day's tape (or DVD) with $day's version of
> the file.
> Presumably, your backup software's DB will be able to provide you with
> $Day.
The idea being that if you edit the file three times per hour, then
three prior versions get stored. If your backup software is advanced
enough, it can capture all of those prior versions. If it isn't, you
only get the current version at the instant the backup happened. [Which
is still far better than nothing, of course...]
Date: 29 Jan 2013 09:07:07
Message: <5107d78b$1@news.povray.org>
No, I was just thinking of the SALVAGE utility that allowed you to
restore previous copies of files.  (a bit similar to Norton's UNERASE,
but that would work on non-contiguous files)
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 29 Jan 2013 09:28:20
Message: <5107dc84@news.povray.org>
That is is hardly a new feature.
>> the file.
>> $Day.
Most software (Office is - or was - famous for that.) no longer rewrite
the entire file when you do a "save".  It only appends a "changes"
section at the end of the file, so unless you do a "save as..." and use
the same file name, you  will not get multiple copies of the file on the
OS file system.
This being said, I wonder how Windows Server 2008 would know that it
should save multiple copies of a 5MB TPS Reports.ppt, but not multiple
copies of a 64GB payroll.dbf.
Date: 29 Jan 2013 14:35:41
Message: <5108248d$1@news.povray.org>
And *my* point is that _most_ new Windows features aren't very new at all...
I would rather dispute that. It seems to be that Microsoft Office is the
exception here, rather than the rule... And now that even MS Office uses
a zipped XML format, I don't think even that is true any more.
And even if it is, how does that help you recover prior versions?
I presume it doesn't. I would expect it to just blindly copy everything,
regardless of the dire performance implications. It's highly
sophisticated software, after all...
Date: 29 Jan 2013 16:44:57
Message: <510842d9@news.povray.org>
Oh, yes, that was also available on 2.x, I think.
The difference, though, is that there was no guarantee that a prior
version would still be there.  With SALVAGE, the blocks were marked as
freeable and the DET entry was moved to DELETED.SAV if the directory were
removed (I think in some cases it always was moved there, but at some
point it was just marked in the DET in the directory as deleted until it
was purged or the blocks were used).
If the blocks the file was stored in were needed for storage, though,
then the file would be permanently deleted.
Or, obviously, if the PURGE utility were run.
HSM, on the other hand, preserved copies of files on optical media, but
probably didn't catch all revisions.
Jim
Date: 30 Jan 2013 03:21:27
Message: <5108d807$1@news.povray.org>
 From what I could make out, it seems like Previous Versions only works
on files and folders that are set up under Windows Backup - so should be
trivial to prevent your 64GB payroll.dbf having previous versions kept.
Date: 31 Jan 2013 09:52:12
Message: <510a851c@news.povray.org>
> all...
Why would that be? It's been possible to append to an existing zip since
the early 90s.
And even if MS Office was the exception, most people in a corporate
environment do not use anything else that stores files on a networked drive.
[Depressing Story Bro]
One of my wife's coworkers: "I wish I could group my files logically
instead of having them all in the same place."
Other coworker: "Oh, it's easy.  All you have to do is start Word, and
click on File / Open...  From there there's an icon that allows you to
create folders."
My wife: "There has to be an easier way..."
Coworker #1: "Yeah, why don't you call your husband... He works in IT,
he should know"
[End DSB]
Because on Netware servers, "deleted" is just another attribute for the
file starting at sector XYZ.
So if the application deletes the existing file before recreating a new
one, the server will have two copies of the file on disk, with one that
has the deleted attribute.
So you could easily revert to earlier versions of the file by using the
SALVAGE command.
(And yes, server-based backup software are smart enough to back up the
deleted versions as well, if you asked them, just as they could backup
compressed files without decompressing them)
Date: 31 Jan 2013 09:55:01
Message: <510a85c5@news.povray.org>
Agreed.  Back in the days of servers with 120MB HDs, I had to purge them
on a regular basis.
