POV-Ray : Newsgroups : povray.off-topic : I need a new computer: RAID and other questions Server Time
15 Mar 2026 15:39:59 EDT (-0400)
  I need a new computer: RAID and other questions (Message 31 to 40 of 55)
Subject: Re: I need a new computer: RAID and other questions
Date: 27 Jan 2013 08:10:56
Message: <51052760@news.povray.org>
On Sun, 27 Jan 2013 05:53:32 -0500, Warp wrote:
> Jim Henderson <nos### [at] nospamcom> wrote:
>> On Sat, 26 Jan 2013 11:25:26 -0500, Warp wrote:
>> > The most typical backup program for other systems is something that
>> > you have to run manually, and most often than not with a horrible
>> > nightmare of a user interface. (For example you wouldn't believe how
>> > complicated it is to restore one single file with OpenSuse's system
>> > backup utility.
>> > Something that takes like 5 seconds with Time Machine can take at
>> > minimum 5 minutes with OpenSuse's system backup, often more. And of
>> > course it's in no way automatic.)
>> rsync + cron = backup goodness.
> I don't think rsync does incremental backups. In other words, if you
> wanted to restore an earlier version of a file, it's not possible.
There are ways to accomplish that, sure.
The search I suggested to Andy, for example, has a couple of examples of
how to do exactly that.
Jim
Date: 27 Jan 2013 08:25:01
Message: <web.510529f6ca79cfd9c2d977c20@news.povray.org>
> The problem with this is that it's easy to forget or to just be lazy and
> procrastinate (until the day that your HD breaks.)
Yeah, very true. I certainly don't back-up as often as I should. My basic
philosophy is to 'believe' in the MTBF specs of modern hard drives (probably a
mis-placed belief!) But I generate so *little* data during the week (even
usually during a month) that I don't worry too much about a loss of 'important'
data. (Except POV-Ray files!!) I do need to be more vigilant, though.
Date: 27 Jan 2013 12:16:15
Message: <510560df$1@news.povray.org>
> If you want to keep track of various version of a file, you need a
> revision control system (and then backup the repository), such as
> (<start holy war>): mercurial, cvs, rcs, svn, git, ...
> ( holy wars never stop, no end tag)
 From what I've seen, several revision control systems *claim* to
support large binary files, but barf if you actually try it...
There are plenty of other ways to achieve this though. E.g., find all
the files with the "archive bit" set, dump them into a dated folder,
reset the archive bit on all the files you just copied. (That's why this
file attribute exists in the first place, after all...)
Date: 27 Jan 2013 17:28:59
Message: <5105aa2b@news.povray.org>
subversion seems to handle them fine, FWIW.  I've seen it used to handle
multiple revisions of multiple-gigabyte vmdk files without a problem.
It's not terribly efficient at non-text files (it doesn't diff them, it
just stores each revision of the entire file).
I've also seen it used for binary FrameMaker files extensively, and it
versions those fine as well (though with the same caveat).
Jim
Date: 28 Jan 2013 02:59:45
Message: <51062ff1$1@news.povray.org>
Yes, svn is fine... as long as no-one activate the keywords substitution
on the binary file (and a binary file can be a word document) (and hell
opens with keywords set on, when Murphy put a $Rev$ or similar in the
binary)
Date: 28 Jan 2013 03:10:07
Message: <5106325f$1@news.povray.org>
Or robocopy + task scheduler if you're on windows. But both options
assume your computer is on and the backup medium is connected...
Date: 28 Jan 2013 03:12:33
Message: <510632f1$1@news.povray.org>
I don't know how our IT department at work manage it, but on all our
network drives you can right click and folder or file in Explorer and go
Properties->"Previous versions" and help yourself to whatever previous
version you want. I assume that all gets backed up somehow.
Date: 28 Jan 2013 03:42:30
Message: <510639f6$1@news.povray.org>
It's a new feature in Windows Server 2007 (?). AFAIK, it's only
available for the server edition of the OS. But yes, basically it
retains old versions of files for X days. The files are still on the
same physical volume, however. This protects against logical failures
(e.g., some doofus deleted the wrong file), but not against physical
failures such as a head crash.
Of course, then you need to buy backup software expensive enough that it
backs up the hidden previous versions as well as the visible files...
Date: 28 Jan 2013 03:43:21
Message: <51063a29$1@news.povray.org>
Fun fact: I actually did this at my last employer. For real. They
wouldn't cough up the money for a real backup solution...
Date: 28 Jan 2013 17:16:14
Message: <5106f8ae$1@news.povray.org>
A new feature that Novell had in Netware 3.10 back in 1990.
No.  You just need to load $Day's tape (or DVD) with $day's version of
the file.
Presumably, your backup software's DB will be able to provide you with $Day.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
