POV-Ray : Newsgroups : povray.off-topic : Linux: best way to communicate between processes? Server Time
15 Jun 2026 10:27:41 EDT (-0400)
  Linux: best way to communicate between processes? (Message 13 to 22 of 22)
Subject: Re: Linux: best way to communicate between processes?
Date: 17 May 2016 12:55:19
Message: <573b4cf7$1@news.povray.org>
Le 17/05/2016 17:48, scott a écrit :
>> PIGPIO and GPIOZERO don't need root anymore, the user just needs to be in the
>> gpio group
> Yes I did read that (and tried following the instructions to update), but either it
doesn't work or (more likely) I didn't update properly everything that needs updating.
If it worked, it would obviously be the most trivial solution to implement.
> I might just get another SD card and put the latest version of raspbian on there, if
that works OK then I'll copy over all necessary files from the old one.
If the current user is added to a group, it must relog to see the effect (current
session is not updated when such change occurs)
Date: 17 May 2016 13:44:15
Message: <573b586f$1@news.povray.org>
On Tue, 17 May 2016 11:44:03 +0100, scott wrote:
>> ... or you might look to see if the Raspbian kernel has "capabilities"
>> functionality that would let you grant a non-
>> root user access to the GPIO pins.
> I did look this up previously, and the solution seemed to be to change
> the permissions of the entire memory map, so that non-root users could
> access it. I don't like the sound of that either :)
Yeah, that sounds like overkill to me. I haven't done a lot with
capabilities myself (it's been a few years, too, when I was contracting
for a company that did a lot of work in Linux kernel process and resource
management - some pretty cool tech that unfortunately is now defunct
because the company went out of business - the kernel mods were OSS, but
the control daemons were all proprietary).
Jim
"I learned long ago, never to wrestle with a pig. You get dirty, and
besides, the pig likes it." - George Bernard Shaw
Date: 17 May 2016 14:23:28
Message: <573b61a0$1@news.povray.org>
Am 17.05.2016 um 09:18 schrieb scott:
> On 16/05/2016 18:21, Orchid Win7 v1 wrote:
>> On 16/05/2016 01:47 PM, scott wrote:
>>> What's the best way for this root process to "broadcast" to other
>>> (non-root) processes when that pin goes high? It will only happen at
>>> maximum frequency of about every 2 seconds, but any delay between the
>>> pin going high and the other processes seeing it should be minimal.
>> So you're mostly worried about latency. (?)
> Yes, but we're talking a tenth of a second being fine here, microseconds
> are not needed!
In that case, by all means do pick whatever method you find easiest to
wrap your head around. Tenths of a second, that's an eternity even for a
Raspi.
Alternatively, pick whatever method you most like to learn more about.
Dbus and MPI are certainly overpowered for your purpose; from what I
know, dbus is primarily geared towards high-performance bulk data
transfer (real-time audio signals would be a showcase example), and MPI
is actually a high-level interface standard to other inter-process comm
technology such as TCP/IP, dbus, or whatever.
Date: 17 May 2016 16:20:11
Message: <573b7cfb$1@news.povray.org>
On 17/05/2016 08:18 AM, scott wrote:
> Thanks for the ideas everyone.
No problem. I enjoy interesting problems. ;-)
> Just looked up named pipes - it seems you can only have a single
> "reader"? I need more than one process to be able to see the signal.
Yeah, you would need one named pipe per process.
> Sockets should work ok, or as you state, just create/delete an empty
> file somewhere. I'll have to experiment.
Good luck. ;-)
> I guess at some point I might
> want to expand the signal to more than one pin, so being able to
> communicate an "int" rather than a "bool" would actually be more scalable.
Sure thing. I can certainly understand that. Putting the contents into a
small file seems the simplest way. (I'm not 100% sure of the semantics
of multiple processes accessing a file concurrently - unless it's via
mmap...)
Date: 18 May 2016 02:56:33
Message: <573c1221$1@news.povray.org>
>>> gpio group
if that works OK then I'll copy over all necessary files from the old one.
I'm pretty sure I did that, but anyway there are some issues with the pi
camera (it stops responding after anywhere between 100000 - 400000
photos being taken and needs a power cycle) so a newer build hopefully
fixes that too.
Date: 18 May 2016 03:35:00
Message: <web.573c1a112b37d2ddd0f66c6d0@news.povray.org>
scott <sco### [at] scottcom> wrote:
> [snip]
> fixes that too.
Regarding the camera stopping, theres been a bug exposed lately with the V2
camera, concerning the I2C control bus of the camera. There's a fix in the
pipeline. https://www.raspberrypi.org/forums/viewtopic.php?f=43&t=147744
Regarding you IPC problem, generally I'd go for unix domain sockets. They behave
like network sockets, but are located in the file system.
Regards
Aydan
Date: 18 May 2016 04:26:47
Message: <573c2747$1@news.povray.org>
Glad to know it's an actual bug that's been worked on. Took me a long
time to figure out it was the camera just not responding rather than an
error I had made in my code. I currently have it set up to reboot itself
every day at 2am which has fixed it, a bit of a bodge though.
Date: 18 May 2016 12:52:01
Message: <573c9db1$1@news.povray.org>
I recently read about a similar firmware bug in a security camera. It
reboots itself every night at midnight.
I can't *imagine* how a security camera temporarily turning itself off
at a predictable moment every single night could *possibly* be a
problem... :-P
Date: 19 May 2016 04:49:11
Message: <573d7e07$1@news.povray.org>
> problem... :-P
You just need to buy their other camera, which reboots at 2am, and run
both next to each other :-)
Date: 19 May 2016 13:35:02
Message: <573df946$1@news.povray.org>
>> problem... :-P
To be fair, the main point of the article in question was that the
password to the camera's wire protocol was "12345". Hard-coded in
firmware. Cannot change it. Both the camera and the control terminal
have this hard-wired in firmware.
Then again, it was a dirt-cheap Chinese import.
(Presumably there are high-quality Chinese items somewhere... these are
not the ones I'm talking about.)
