![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Black Mesa is a Source mod that's basically a remake / total conversion
of Half-Life (using the modern Source engine).
If you liked Half-Life, you should definitely check it out. It looks
awesome.
More info: http://en.wikipedia.org/wiki/Black_Mesa_%28video_game%29
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And BTW, it's released, and donation-ware.
http://release.blackmesasource.com/
Check out the "download now" torrent bit. I haven't installed it, but I'm
told by those who do that you basically run the installer and you're good to
go, without having to worry about whether you already have Steam or any
other games with the same engine or anything like that.
"They're the 1-800-#-GORILA of the telecom business."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't know about that. It registers itself with steam and it requires the
Source SDK (which Steam downloads automatically when you run the game for
the first time). Since the SDK does not come with the game itself, I don't
know how it could run without Steam.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What I'm told is that if it doesn't find the SDK, it downloads it during the
install process. (And I don't think Steam comes with the SDK - just the engine.)
In any case, I can't test that bit, since I already have Steam and all that
installed, and it installed just fine.
Oh, I see. When you install it, it winds up in your Steam library. The first
time you launch it from Steam, it says "Yo, there's a Steam update for you,
this 4.7G thing called 'SDK'." So it treats the SDK install like any other
Steam update. I Hadn't actually gotten around to trying it until I was
already replying here. :-)
The installer offered to let me launch it (as installers are wont to do) and
I wasn't running Steam, but I don't know if that would have started up Steam
or what. Maybe it doesn't install at all if you don't have Steam. It *did*
install directly into my (non-standard) Steam games storage directory on my
alternate non-C: drive, so maybe it doesn't even start installing if Steam
isn't around.
I don't know how (or if) it runs without one having an actual steam account.
I'm just repeating what I was told by others.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> first time you launch it from Steam, it says "Yo, there's a Steam update
> for you, this 4.7G thing called 'SDK'." So it treats the SDK install
> like any other Steam update. I Hadn't actually gotten around to trying
> it until I was already replying here. :-)
Sounds like other Source-powered games I've played. (E.g., Dystopia,
Insurgency.)
It's powered by Source, it shows up in Steam, but it isn't distributed
by Steam, so it won't auto-update. (Although maybe that'll change in
future... It looks like Valve are looking into actually /distributing/
more independent games through Steam...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
They actually released it in the end? Man, I figured it was dead for sure...
> awesome.
Yeah, I read about this ages ago. I bet it won't be as cool as I'd hoped
though... Only one way to know. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > awesome.
I have liked it so far. It's not just one of those "let's upgrade the
original game with better models and textures". It has been, AFAIK,
developed from scratch. It follows the original game quite faithfully,
of course, but levels are often bigger and have more stuff in them, and
many puzzles and sequences are completely different from the original
(although the setting is usually the same).
Oh, and the voice acting is new, and quite well done.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 9/17/2012 1:28, Orchid Win7 v1 wrote:
> It's powered by Source, it shows up in Steam, but it isn't distributed by
Well, it used the auto-update mechanism built into steam to download the
SDK. It shows up in Steam as an external shortcut, tho. It's an odd combination.
That said, it has apparently been "greenlighted" on Steams "greenlight"
thing, so it'll probably be available properly through Steam in a few weeks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> combination.
The Source SDK is delivered through Steam. The game itself is not.
> weeks.
Yeah, so I hear. That should make things drastically easier if they
start releasing updates. (I remember from Dystopia that every time an
update came out, you suddenly lost the ability to play on all game
servers until you manually track down, download and install a several
hundred MB update. Not fun!)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Having had a chance to actually play this properly now, I'm liking what
I'm seeing.
(I didn't like that it took me almost half an hour to find a mirror
which would actually let me download the game.)
It's based on the HL2:EP2 engine. It does that same thing the other HL2
games do, with the menu floating over a scene from the game. The default
graphics settings it picked were a tad lower than what my graphics card
can actually handle. (It didn't pick the right image resolution for my
LCD, and it also decided not to turn on AA, which my mighty nVidia
GeForce GTX 260 easily handles.)
There's a rather obnoxious quantity of loading pauses during the iconic
intro sequence. A lot of the environments look a bit less *ridiculously
implausible* now. The environment sounds seem better too. On the other
hand, there seems to be a lower density of "cool glowy things".
This carries over to the rest of the game. A lot of the empty box
corridors now have windows into other areas, and the place seems more
like a buzzing hive of activity than it did before. Basically the place
looks less barren and more interesting. On the other hand, fewer lasers
and stuff.
The footsteps on carpet sound is pretty cool. And the music isn't bad.
The voice acting is... Well, it's certainly decent. I'd suggest it isn't
as good as the original, but honestly the original was recorded in such
low quality that it's hard to say. I notice that there are /female/
scientists now. And while in the original game, the occasional guy would
murmur "greetings", now the scientists seem to have a hell of a lot more
to say. (Even if most of it just foreshadows "everything's about do go
wrong", or is otherwise ironic.)
And then eventually I arrived at THAT room. You know the one. Ground
zero. The place were it all went wrong.
I like that it doesn't have parts of the machine just /levitating/ now.
It looks like a machine that could actually physically exist, and that
an engineer might design. I like the way the room lighting changes when
you switch it on. But shortly after that, the room starts to become
drastically over-bright, and the lighting changes aren't nearly as
effective. Given that this is arguably the single most important moment
in the game, it could have been slightly more cinematic.
Some of the models, textures and sounds are brand-new. Some of them I
clearly recognise from HL2. Some of the better voice clips sound like
they were voiced by Harry Robins himself, heh. The dialogue certainly
comes across as a little less wooden - no doubt thanks to the improved
game engine.
There were a few glitches. When the zombies first show up, one chased a
security guard into the lift shaft I just climbed up, and stood there
apparently stuck in a loop with him attacking and the guard not
returning fire. I walked off and left them to it, still unarmed. There's
a /lot/ of zombies here, considering I have no weapon. (I like how you
eventually find the crowbar wedged in a door.)
In the original game, you find the Glock just before you enter the area
where the houndeyes hang out. But not here, apparently. There's still a
dead security guard, but this time there's no dropped gun on the floor.
It's quite hard to kill the houndeyes with only a crowbar; you tend to
get fairly severely injured before you can finish them.
Eventually I did get a gun. But ammo seems to be /really/ scarce. For
that matter, there are a few health stations around, but almost every
single HEV charging station seems to be deactivated for some reason. I
spent almost the whole game so far with 0% suit charge. (The levels seem
to reward exploration though; there's a few power modules hidden around
the place.)
Likewise, for a good portion of the game I've been finding an awful lot
of magnum ammo considering I don't have the magnum yet. In one very
annoying instance, I actually found the magnum, battled a little further
on, and died. When the game reloaded, I forget to recollect the magnum,
and by the time I realised it was too late. So I /still/ don't have the
magnum!
I did eventually get the SMG and the shotgun though. A got as far as the
Blast Pit, and then decided I just couldn't be dealing with my
least-favourite room in the entire game this late at night with almost
no ammo left for any weapon...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
