POV-Ray : Newsgroups : povray.off-topic : Laptop keyboards Server Time
19 Mar 2026 22:17:32 EDT (-0400)
  Laptop keyboards (Message 1 to 10 of 10)
Subject: Laptop keyboards
Date: 11 Oct 2011 11:16:58
Message: <4e945dea@news.povray.org>
If you have a laptop that has the wrong keyboard layout, don't try to
change the keyboard. Just learn to live with it, or plug in an external
USB keyboard.
I failed to heed this warning. I just spent about 2 hours trying to
replace the keyboard on a Dell laptop. In the process, I caused
irreparable damage to the old keyboard, irreparable damage to the new
keyboard, and also slightly damaged the laptop itself. The laptop has
gone from having a working keyboard with the wrong layout, to having a
non-functional keyboard. I'm now dripping wet and utterly frustrated.
And if I ever see another flexible edge connector, I may just lose my
sanity.
LFMF!
Subject: Re: Laptop keyboards
Date: 12 Oct 2011 11:12:13
Message: <4e95ae4d$1@news.povray.org>
> sanity.
Well, there's your problem ... Don't change your laptop's keyboard in
the shower!
~Mike
Date: 12 Oct 2011 11:33:39
Message: <4e95b353@news.povray.org>
>> sanity.
> the shower!
In fairness, if I /had/ done it in the shower, at least I wouldn't be
covered in sweat by the end of it...
Date: 13 Oct 2011 00:08:46
Message: <4e96644e$1@news.povray.org>
This and other reasons led me to conclude that never try to fix a
portable device that is not mine and even so I'm very careful; when
people ask me I redirect to a specialist, my life is so much happier
since then. The bath of sweat is normal, you have to relax be stay
relaxed while doing the notebook, for more reference how to disassemble
them go to the website of the brand and check on technical support, they
have instructions for technicians to open them, at least it used to be.
Good luck.
Date: 13 Oct 2011 04:24:00
Message: <4e96a020$1@news.povray.org>
> portable device
This.
> Good luck.
The Dell website provides some minimal instructions. What they
completely fail to explain is how to connect the flexible edge
connectors. Unlike other models I've seen, these have some sort of weird
clip on them. Of course, being so microscopic, I can't actually see what
the hell I'm doing. (And, naturally, our entire office is always half
dark because it would cost too much money to illuminate it adequately.)
If only I had a magnifying glass...
Date: 13 Oct 2011 05:56:42
Message: <4e96b5da$1@news.povray.org>
No workshop should be without one of these or similar.
http://www.maplin.co.uk/22w-fluorescent-daylight-magnifier-lamp-47980
http://www.maplin.co.uk/12w-magnifying-lamp-225722
http://www.maplin.co.uk/wide-lens-22w-magnifier-lamp-222690
Although some people I've worked with preferred something like this.
http://www.maplin.co.uk/2-led-magnifying-visor-219971
Regards
Date: 13 Oct 2011 06:13:43
Message: <4e96b9d7$1@news.povray.org>
I'm not sure my office is big enough for that...
Yeah, that would probably work better. Then you don't have the problem
of the lamp constantly being in the wrong place as you wrestle with the
laptop.
Ultimately though, even if I could see what I was doing, I would
probably still have broken the hair-thin spins on this damned connector...
Date: 13 Oct 2011 09:46:41
Message: <4e96ebc1$1@news.povray.org>
It must be small then. Surely you have a workbench where you can lay out
equipment. The anglepoise one takes up very little space and can be used
as a lamp. We had one of those when I worked on the Murchison (off
shore) and it was invaluable.
> laptop.
I've never been able to replace those. There must be a knack to it.
Regards
Date: 13 Oct 2011 10:31:10
Message: <4e96f62e$1@news.povray.org>
> equipment.
It's big enough to fit a desk and a chair. I suppose technically you
could fit a second desk in if you don't mind not being able to open the
door. And, in fairness, if I cleared some of the junk off my desk, there
would probably be room to put this. Currently, there isn't enough space
to fit the laptop.
>> connector...
There is: Use a machine.
Seriously. The factory where they assemble these things surely does this
by machine. They can't possibly be using a human to do it.
The "normal" flexible edge connectors are hard enough, but these ones
have a tiny flap or clip that goes over the top. Except I managed to
snap that off too...
Date: 13 Oct 2011 18:20:38
Message: <4e976436$1@news.povray.org>
http://www.google.com/search?q=flexible+edge+connectors&hl=en&client=seamonkey-a&rls=org.mozilla:en-US:unofficial&prmd=imvns&source=lnms&tbm=isch&ei=KF2XToTNPMni0QHo_uyuBA&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CDIQ_AUoAQ&biw=1360&bih=586
check the light strips, if you could get really white lights you could
illuminate anything, you don't need much power, LEDS take 0.7V and
little amperage since they seem to be connected in parallel.
