POV-Ray : Newsgroups : povray.off-topic : Be very afraid... Server Time
31 Jul 2026 13:28:08 EDT (-0400)
  Be very afraid... (Message 31 to 40 of 65)
Subject: Re: Be very afraid...
Date: 24 Sep 2009 05:36:37
Message: <4abb3da5$1@news.povray.org>
> It's news to me that POV supports splines in the first place.
It does bezier patches which are the closest you are going to get to
describing "any curved surface" mathematically.
> Only if you have the original curve to hand.
What if you designed the curve by seeing how it turned out after
sub-divison?  Blender works like this, you can edit the vertices of a very
rough triangle mesh and see how the perfectly smooth surface reacts in real
time.  You are then defining the "original curve" by the crude mesh.
> If you *insist* on using triangles, you're going to need a hell of a lot
> of them to fake the appearence of a good curve. That means you either need
> a triangle mesh of absurd dimensions, or you need to generate the
> triangles on the fly.
Exactly.  This is what all film-quality renderers do.
> What all known computer games do is use a static, very low resolution
> triangle mesh and then smother it with lashes of low-level trickery to
> give a vague semblance of curvature.
Of course, because that method gets the highest quality output in realtime.
And it's very easy to have two (or more) versions of a mesh at different
resolutions, eg for stills rendering, close-up real-time rendering, far away
rendering etc.  When you have a mathematical surface rendered directly it's
very difficult to speed it up!
Date: 24 Sep 2009 05:40:39
Message: <4abb3e97$1@news.povray.org>
scott wrote:
>>> Imagine how long that would take to render in POV, media, DOF,
>>> refraction! And I don't think the result would be *that* different
>>> (maybe the refraction would look slightly different, but a normal
>>> person probably couldn't tell which one was correct, especially
>>> during animation).
>> It wouldn't have all those glitches that games have though. (Like
>> grass that rotates as you run past it, or "mist" that has sharp edges
>> where it intersects things.)
> I don't think modern games have those glitches anymore, the grass is
> true 3D geometry not just billboards, and the mist billboards usually
> compare depths of existing pixels to avoid the hard edges with
> geometry.  Some games even have true 3D volume textures and rendering
> for smoke and mist, I don't know if Crysis uses this or just cheats with
> multiple billboards.  Maybe the glitches you mention are on a game from
> 5 years ago or on a very badly written modern one.
HalfLife 2: Episode 2 has mist in one section. Looks really
impressive... until it intersects something.
Mind you, POV-Ray has the exact same problem, until you turn the
settings up so high that it takes 82+ hours to render a single frame...
Date: 24 Sep 2009 06:41:00
Message: <4abb4cbc$1@news.povray.org>
Ever heard of subdivision surfaces, Andrew?  You can get a perfectly
round sphere out of a plain cube cage by specifying up to 5 iterations.
  This is the norm in the industry, and there's also NURBS.
Pixar got its own gig with REYES in Renderman, basically an automatic
triangulator breaking down every geometry on screen into triangles until
they are less than one pixel wide in the final resolution.  It probably
breaks them down by subdivision as well, since one of the well-known
algorithms has the name of one of Pixar founding fathers...
No one designs multibillion triangle meshes by carefully moving them one
by one.
BTW:
http://www.3d-coat.com/v3_voxel_sculpting.html
Date: 24 Sep 2009 06:43:34
Message: <4abb4d56$1@news.povray.org>
Yes. But the resulting surface can only be controlled by the 8 original
cube corners. That's not much control.
> by one.
And yet, in all known editors, moving triangle corners around one at a
time is the only available editing operation...
Date: 24 Sep 2009 07:46:38
Message: <4abb5c1e$1@news.povray.org>
If you need refinement, you do loop cuts over the control cage and extrude.
>> one by one.
You have your head in the 80's.  Do you ever click on the links I provide?
Date: 24 Sep 2009 07:50:06
Message: <4abb5cee$1@news.povray.org>
>>> one by one.
Really?
Everybody says that Wings3D is the best editor going, but all it does is
manipulate triangle meshes, one point at a time. Last time I checked, it
didn't exist in the 80s.
Date: 24 Sep 2009 08:03:26
Message: <4abb600e@news.povray.org>
>>>> one by one.
>>> a time is the only available editing operation...
>> provide?
> Really?
I'm used to Blender, not Wings, but I'm pretty sure they share the same
operations and that means extruding and controlling and selecting
friggin' amounts of vertices at the same time by mean of vertex loops
and rings.  Let alone by sculpting like in the link I provided.
Not knowing how to use such operations doesn't mean they don't exist.
Almost never I've had to move a single vertex alone.
Date: 24 Sep 2009 18:14:38
Message: <4abbef4e$1@news.povray.org>
Invisible wrote:
> scott wrote:
>> I don't understand the fascination with perfect mathematically
>> described surfaces, they are inflexible and slow to render.
> Really? I was under the impression that splines can describe any
> possible surface. Triangles, on the other hand, can only give a crude
> approximation to curves.
This is not true.  Just like triangles splines can only approximate most
curves, they just give a different approximation.
Back to the initial topic -- the main reason why I like the ability to
support arbitrary surfaces is that isosufraces are such a useful
modeling tool.  Sure you could always tessilate them to triangles, but I
don't think that doing so correctly, quickly, and automatically is that
easy of a problem -- particularly if you want to treat the normals
correctly.
Of course if you have a really nice modeler the added value of
isosurfaces is less, so it makes sense to go with a pure-triangle
approach.  For a text-based editor like Povray, however, I think having
a larger vocabulary of surfaces is extremely handy.
Date: 24 Sep 2009 22:07:48
Message: <4abc25f4$1@news.povray.org>
scott wrote:
> I don't understand the fascination with perfect mathematically described
> surfaces, they are inflexible and slow to render.  If you use
> sub-divided triangle meshes you can make the output perfectly smooth all
> the time and of course do whatever transformations you like very easily
> by just transforming every vertex.
True, as long as you dynamically adjust the subdivision level so that
triangles aren't too large.  Unfortunately, nobody actually does that.
In reality, everyone pre-subdivides the meshes.
Mathematically described surfaces don't have to be subdivided, because
they're rendered at the pixel level.
...Chambers
Date: 25 Sep 2009 05:06:08
Message: <4abc8800$1@news.povray.org>
It's very simple to add in more control points, every time you want more
control you simple add in another point, this leaves you free to have
certain areas with very few control points, and other areas with lots of
control points, yet the result will be perfectly smooth.  For example when
modelling a car the large flat roof might only need a handful of control
points, but something around the wheel-arch might need many more to get the
curvature correct.
Another benefit is that you can instantly switch between the level of
subdivision, so you can have a 10 million triangle mesh for perfectly smooth
rendering, or a 100k mesh for use in a game, both coming from exactly the
same control points.
Watch this for a demo of it working (in BLender);
http://www.youtube.com/watch?v=ckOTl2GcS-E
around 0:47 you can see him editing the control points and the perfectly
smooth surface is following.  This is how you design smooth triangle meshes,
not point by point of the individual triangles!
Haha, do you *really* think that people haven't thought of a better way to
edit triangle meshes? LOL
