POV-Ray : Newsgroups : povray.off-topic : My first C++ program Server Time
28 Jun 2026 15:42:34 EDT (-0400)
  My first C++ program (Message 60 to 69 of 149)
Subject: Re: (And in Haskell. Obviously.)
Date: 20 Sep 2008 12:54:30
Message: <48d52ac6@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> I think Haskell is line oriented. Commands end at the end of lines.
  What happens if the expression is very long? For example, a function
could take a large amount of parameters, all of which are long expressions
using long variable names.
  I think I'm starting to understand *why* Haskell people prefer using
short and cryptic variable names rather than long and clear ones: If they
did the latter, they would run out of space in their limited lines... :P
Date: 20 Sep 2008 13:41:50
Message: <48d535de$1@news.povray.org>
Put each argument on a seperate line, indented further than the function
name.
   foo
     arg1
     arg2
     arg3
Heh. Haskell programs *do* tend to end up with pretty long lines, that's
for sure. ;-)
http://blog.orphi.me.uk/
Date: 20 Sep 2008 13:55:01
Message: <48d538f5$1@news.povray.org>
I don't know. In Tcl, you put a backslash at the end of the line. Just
like bash or anything else.
Date: 20 Sep 2008 14:07:29
Message: <48d53be1$1@news.povray.org>
>> expressions
> name.
Or... make them local variables.
(That's more usually done if a certain subexpression is needed more than
once - since, obviously, putting it in a variable makes it only evaluate
once. But you can also use it to break things up - especially if what
you're doing is complicated.)
   let
     thing1 = ...
     thing2 = ...
     thing3 = ...
   in foo thing1 thing2 thing3
Notice that, unlike in "normal" languages, let is an *expression*, but a
*statement*, so it is valid absolutely anywhere an expression is valid.
That includes absurd constructions like
   (let x = 5 in x) + (let y = 2 in y)
which just means "5 + 2".
Subject: A test
Date: 20 Sep 2008 14:21:58
Message: <48d53f46@news.povray.org>
Nicolas Alvarez wrote:
> I understand the C++ one and the Haskell one looks like line noise.
OK, well how about this:
module Main where
import System.Random
main = do
   target <- randomRIO (1, 100)
   guess target
guess target = do
   putStr "Guess: "
   txt <- getLine
   let number = read txt :: Int
   case compare number target of
     LT -> do putStrLn "Too low.";  guess target
     GT -> do putStrLn "Too high."; guess target
     EQ -> do putStrLn "You win!"
Does that look like line noise to you? Or can you figure out what that does?
Subject: Re: A test
Date: 20 Sep 2008 14:31:06
Message: <48d5416a@news.povray.org>
  I think this line illustrates well what I wrote earlier. Just a list
of whitespace-sepaated words. No delimiters, no hints about what might be
a reserved keyword, what might be a variable, what might be a function.
  I'm no at all sure how that should be parsed. Could it, perhaps, be
something like:
    case(compare(number, target)) of
  What would be wrong with a syntax like that?
Subject: Re: A test
Date: 20 Sep 2008 14:38:18
Message: <48d5431a$1@news.povray.org>
All the functions in Haskell are curried. So it's really
   case (compare(number)(target)) of ...
But yes, this is exactly the kind of thing I have trouble with too, in
these sorts of languages. Especially when it gets a little more complex
and you get stuff like
    case bump . hither $ yo stuff of ...
or when people start writing binary functions that take values on both
the left and the right (in SML, not Haskell) and giving them names like
"o", with functions returning other functions composed by "o", which was
apparently not unlike the "." in Haskell.
    this o that value
OK, so what's the precidence on that in ML? Yarg.
Subject: Re: A test
Date: 20 Sep 2008 14:48:25
Message: <48D545BF.4090003@hotmail.com>
why would want you distinguish reserved words, variables and functions?
In C(++) they might be implemented quite differently, that does not mean
however that are fundamentally different on a conceptual level. Haskell
apparently does not make such arbitrary and implementation driven
distinctions. I think we can only applaud that.
Subject: Re: A test
Date: 20 Sep 2008 15:24:58
Message: <48d54e0a$1@news.povray.org>
Orchid XP v8 a écrit :
>   putStr "Guess: "
> does?
Honestly just from the strings that are being printed one can guess what
this program is meant to be doing... Should be true of any language.
Well one where the strings do not have to be somehow encoded of course ;-)
Vincent
Subject: Re: A test
Date: 20 Sep 2008 15:30:29
Message: <48d54f55$1@news.povray.org>
I'm pretty sure "reserved words" are conceptually quite different from
variables, yes. Unless you're talking about an extensible language like
LISP or FORTH or Tcl, the reserved words let you do things that you
can't do with functions and variables, and vice versa.
Knowing what's an argument and what's a function is also pretty
important for understanding how a given line of code works. If you can't
look at the code and figure out which function bodies get evaluated, it
makes it really rough to work out what's going on, even in a functional
language.
