POV-Ray : Newsgroups : povray.binaries.images : Realistic bricks Server Time
4 May 2026 21:29:03 EDT (-0400)
  Realistic bricks (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Realistic bricks
Date: 2 May 2006 11:15:01
Message: <web.44577647782f552a731f01d10@news.povray.org>
Bill Hails <bil### [at] europeyahoo-inccom> wrote:
> generating the normals isn't all that hard.
> Each vertex is touched by three or more triangles.
> For each triangle you take a vector perpendicular to it's plane,
> of length proportional to the length of that triangle's two edges that
> intersect with the point in question (I think that's vcross() not sure
> now because it's been a while).
> Then you average those vectors to give you the normal at that point.
It wasn't the actual calculation that was putting me off, just the amount of
thought and coding required to implement it! It would indeed be vcross(),
and there's VPerp_To_Plane(v1,v2) in math.inc, although I fail to see the
difference between them to be honest.
Each vertex is touched by eight triangles, although I could probably get
away with averaging the normals to the four non-planar quadrilaterals
touching each vertex (which amounts to the same thing, at least in my
head). I'm going to have to re-write my main loop...
Well, I've thought about it now, so obviously I'm not going to be happy
until I've done it! :)
To be continued...
Bill
Date: 2 May 2006 14:07:05
Message: <MPG.1ec14e1d990869a7989f03@news.povray.org>
What are s.day and Bill Pragnell using for a news reader? Gravity, both
the older version and the new open source one refuse to decode the
messages and display them... Its quite annoying and frankly I hate every
other news reader I have ever tried to use.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 2 May 2006 15:28:02
Message: <4457b2c2$1@news.povray.org>
According to the headers, both are using the web-interface from
povray.org. I attached the source of Sean's message, perhaps you can
figure out what keeps your agent from displaying the messages.
HTH,
Florian
Date: Tue,  2 May 2006 09:45:01 EDT
Newsgroups: povray.binaries.images
Message-ID: <web.4457625d782f552aea4cafdb0@news.povray.org>
References: <web.44574b069e74fc96731f01d10@news.povray.org>
Mime-Version: 1.0
Content-Type: multipart/mixed; boundary="------boundary00xxzz99pov77ccvv44"
X-Source:
+BAE//ID/fz+6wj07ATuCDQTJR4GMSrrBS8ADwonAAkJJxAP3JWuwoG8i5/dlW2lyrmdxLN4m62A2q2Vr4uCwse4e6Ddv37Z
X-Newsreader: POV-Ray Web Interface
X-User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1;
.NET CLR 1.1.4322)
NNTP-Posting-Host: 203.29.75.35
X-Trace: news.povray.org 1146577800 203.29.75.35 (2 May 2006 09:50:00 -0400)
Lines: 12
X-No-Archive: Yes
X-Copyright: This copyrighted article comes from a private news server
and may NOT be distributed on USENET or other news servers.
X-POV-Header: --- --- --- --- --- --- --- --- --- --- --- ---
Path: news.povray.org!82.153.141.171
Xref: news.povray.org povray.binaries.images:99091
This is a multi-part message in MIME format.
--------boundary00xxzz99pov77ccvv44
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
Looks very interesting, I had a similar idea myself a while ago but
unfortunately did not know how to create the rounded box using meshes. I
would certainly be very interested in the source code when it is finished.
Sean
Date: 2 May 2006 15:46:00
Message: <4457b6f8@news.povray.org>
> "Patrick Elliott" <sha### [at] hotmailcom> wrote in message
news:MPG.1ec14e1d990869a7989f03@news.povray.org...
Looks like they're both using the web interface
"X-Newsreader: POV-Ray Web Interface"
Subject: Re: Realistic bricks [100 kb]
Date: 2 May 2006 16:13:06
Message: <4457bd52@news.povray.org>
Bill Pragnell wrote:
> Martin Magnusson <martin@-xx-blecket-xx-.org> wrote:
>>How about using smooth_triangles instead? In the example you showed, it
>>looks like you used "flat" triangles. That should make them look
>>smoother, and probably better, at close range.
> This is very true.
I believe it is only relatively true.  It has long been my intuition
that high-res, unsmoothed triangles would create more believeable
surfaces for many materials, especially skin.  Proving it is just one of
the many things on my to-do list, lol.  So I am looking forward to your
source if for no other reason than ease of running tests at different
resolutions.
FWIW a while back I was playing a bit with getting the weathering in
face stones.  The examples attached are in fact iso's using round box
macros from iso_csg.inc with some displacement, but the streaking
effects might interest you.
Download 'img.2009.jpg' (52 KB) Download 'img.2012.jpg' (54 KB)
Preview of image 'img.2009.jpg'
Preview of image 'img.2012.jpg'
Date: 2 May 2006 18:06:45
Message: <4457d7f5$1@news.povray.org>
You could try downloading my surface subdivision suite
(http://www.geocities.com/evilsnack/nsss.htm).  Feed it a simple
box-shaped mesh (you can use quadrilateral faces if you want), specify
sharp edges, subdivide it a couple times, add some perturbation, and
then use one of the macros to spit out a mesh.
John
Date: 3 May 2006 00:20:01
Message: <web.44582f18782f552a11c80c7b0@news.povray.org>
hey, man, call me old fashioned, but i still believe textured bricks have a
lot going for it. :)
Your post has challenged me to produce an impacting textured brick wall.
Hope you guys like it...
code:
camera { location .6*<-4.1,4.3,-4.1> look_at <-.8,1.6,0> angle 20 }
light_source { <-2,1.6,-.4>*10 1 }
light_source { <-.2,3.4,-4>*12 .7
 area_light 3*x,3*y,3,3 adaptive .0001 jitter
#declare n_brick_wall =
normal { brick
 normal {brick normal{ granite .3 }, normal{ gradient y } bump_size 2.4 },
 normal { average
  normal_map {
   [1.1 granite bump_size -.6 ramp_wave scale .32]
   [.9 bumps bump_size .7 turbulence .6 scale .62]
   [1.4 quilted control0 .2 control1 .2 bump_size 4.8 scale <8,3,3.8> warp {
repeat 3*y offset x*4} ]
 mortar .2
 bump_size 2.4
#declare p0 = pigment { rgb .8 }
#declare p1 =
pigment { bozo
 color_map {
  [0 rgb 1]
  [.46 rgb <.95,.68,.71>]
  [1 rgb .8*<.94,.64,.59>]
 turbulence 1.8 scale 6
#declare t_brick_wall =
 pigment { brick pigment { p0 }, pigment { p1 } mortar .34 turbulence .1 }
 normal { n_brick_wall turbulence .071 }
 finish { ambient .32 diffuse .34 specular .3 roughness .28 }
 scale .05
box { -.5,.5 scale <2.4,2,.2>
 texture { t_brick_wall }
 translate y
plane { y,0 pigment { rgb .9 } finish { ambient .3 diffuse .4 }}
Download 'brickwall.jpg' (105 KB)
Preview of image 'brickwall.jpg'
Date: 3 May 2006 02:20:01
Message: <web.44584afe782f552a3ccb4f150@news.povray.org>
Wow lot's of nice brick walls here. Very impressed with the textured-only
version.
It's funny, because just a couple of days ago I started putting together a
macro for creating brick walls - and I am trying to make it as flexible as
possible (offering (so far) 3 quality "settings" (plain boxes,
superellipsoids or isosurface blocks for bricks), variable dimensions,
randomness along X and Y, and mortar-settings).
I'm more than happy to post source code and images once I've worked more on
it, but I was going to ask first -
I'd like to include as many options as possible in my macro; if you have a
brick/brickwall/brick texture/etc piece of source code, do I have your
permission to include this in my macro?
Thanks!
Date: 3 May 2006 02:54:13
Message: <44585395@news.povray.org>
"nemesis" <nam### [at] gmailcom> schreef in bericht
news:web.44582f18782f552a11c80c7b0@news.povray.org...
a
Hmm... top and right edges of bricks show also the mortar texture. That is
not right :-)
Date: 3 May 2006 05:40:00
Message: <web.445879a6782f552a731f01d10@news.povray.org>
Whooooops obviously I meant six... :
