POV-Ray : Newsgroups : povray.binaries.images : iso_sphere_sweep Server Time
30 Mar 2026 00:06:52 EDT (-0400)
  iso_sphere_sweep (Message 1 to 5 of 5)
Subject: iso_sphere_sweep
Date: 3 Jan 2002 11:11:17
Message: <b6093uceia9d225oi3q92u48o4kcrmg49q@4ax.com>
Here is sample image of iso_sphere_sweep
Currently it is designed for linear sphere sweep with constant radius.
I'm working on float radius just like "traditional" linear sphere_sweep works.
Render time 11 min on P4 900 MHz iirc.
ABX
Download 'test.png' (63 KB)
Preview of image 'test.png'
Subject: Re: iso_sphere_sweep
Date: 3 Jan 2002 17:38:08
Message: <3C34DCEE.48D513F2@hotmail.com>
Wlodek, I too have been working on such a iso sphere
sweep feature as you describe here.
I don't know if you ever saw these two pictures
that I posted to this group earlier: (?)
"Iso-sombrero" (22. Nov. 2000)
http://news.povray.org/povray.binaries.images/13218/
news://news.povray.org/3A1BC496.F202B75C%40online.no
and:
"Outside It" (29. Jan 2001)
http://news.povray.org/povray.binaries.images/13533/
news://news.povray.org/3A75E2D9.BCDC99AE%40online.no
Both contains a kind of "iso-sphere-sweeps" and
both were made with Mega-POV.
But the "sweeps" within these images are not made
with parametric functions, as some other iso-sphere
sweeps I have seen in here. E.g. by Mike Williams.
He has even made web pages about this:
http://www.econym.demon.co.uk/isotut/splines.htm
I hope this helps.
Tor Olav
Date: 4 Jan 2002 03:01:02
Message: <ehna3u0e9r95e0u6clcl5pmuhgt39rnkgk@4ax.com>
On Thu, 03 Jan 2002 23:36:31 +0100, Tor Olav Kristensen <tor### [at] hotmailcom>
wrote:
> Wlodek
I saw, I just forgot them.
To find differences. I've designed macro to work this way:
#local APoint=array[5]{
  <1,2,3>
  <5,6,7>
  <1,5,0>
  <2,6,8>
  <1,2,3>
#local ARadius=array[5]{
  4
  2
  3
  1
  4
f_sphere_sweep( APoint, ARadius )
And as result of f_sphere_sweep() macro I've ready function of this linear
sphere_sweep and I can add some transformations, combinations and noises.
So they are designed only for one equation and not serve general method for part
of sphere_sweeps ?
> I hope this helps.
Without your sources not :-)
ABX
Date: 4 Jan 2002 22:50:21
Message: <3C367791.DA85CD68@hotmail.com>
I think I understand what you are up to.
Are you planning for non-linear sweeps
between the points as well ?
E.g. cubic splines ?
> of sphere_sweeps ?
Yes, that is true so far.
I.e.: You will have to provide an equation
that the iso sphere sweep can "follow".
> > I hope this helps.
OK, I'll clean up, simplify, re-write and
post the source code for use in v3.5.
(But not now, because I'm very tired now.)
Tor Olav
Date: 7 Jan 2002 02:43:44
Message: <h8ki3u41jciuji8b3afguckvuqc4gckpp1@4ax.com>
On Sat, 05 Jan 2002 04:48:33 +0100, Tor Olav Kristensen <tor### [at] hotmailcom>
Perhaps, I will try noise on linear coordinates first.
I'm looking forward
Me too
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
